Results 1 to 32 of 32
Thread: 170b/pacer/sedan
    strangeak's Avatar
    Aug 2003
    Wasilla, AK
    211
    170b/pacer/sedan
    Looking at planes... I had an arctictern...never felt overly co portable in a tail wheel even though its suppose to be an easy one (a bit of squealing and smoke a few times).
    It's been 7 years since I sold it to move...
    I am in a position to look at a few planes to replace it... I've found a few Pacers (some really well equipped, some with skins and floats, 3 sedans I might be able to afford, some with floats and some stock without (Lower priced) and a few fairly stock 170bs..
    I know the Pacers have a rep for a handful on the ground...
    The sedan and pacer seem to have to useful load edge...the 170 Bd sedan the ground handling edge..
    The 170 and sedans a bit more cost up front.
    Given that I am going to get a thorough check out/biannual prior to flying....which would you choose and why?
    Apr 2009
    AK
    129
    Buy whatever best suits your mission and learn to fly it well- don’t let rumors and hearsay influence your decision. I’d buy a Gee Bee racer if it was the best for my mission...
    10,229
    Quote Originally Posted by strangeak View Post
    Looking at planes... I had an arctic tern...never felt overly comfortable in a tail wheel even though its suppose to be an easy one (a bit of squealing and smoke a few times).
    Solve this issue first before you start looking at tail wheel airplanes. They can all be a handful if the pilot doesn't "get it". All three of those planes require the pilot to be able to handle tail wheels.
    Isn't there a fellow up Talkeetna way who teaches in Pacers? Of the three that you mentioned, that would be the one which needs the most attention. Go see him first.
    9,294
    Pete beat me to it- get yourself sorted out in tailwheel before you consider the above planes.
    In all honesty, stock in any of the three are very limited in other than airport use. Light they are just fine, but add more than two people and you really start needing some space to get them airborne. A B model 170 with a flat prop is amazing when light and a flat prop, but makes the Tern look like a racer in speed.
    Sedans with 180 hp are incredible for those that have learned to fly them, but that is an expensive upgrade.
    Pacers with the 150 hp will do well, but again, need to be light to perform well.
    If going off airport, it is not the useful load, but performance loads you need to look at. None will do what the Tern did.
    All that said- what is the mission? How will it be used, and how much stuff/people are you moving normally?
    10,229
    What happened with Bill Diehl's four place Tern? Is it still around?
    Aug 2009
    Nikiski , AK
    380
    Pacer's are not a handfull at all if gear is properly setup. We have 2 pa22/20's 160hp that are very docile on the ground thru all transition to flight. Just picked up a 170B last week in Tennessee and flew her 40 hrs. back to AK. very lethargic with the 0300D and a cruise prop. Ground handling / tailwheel steering is not as good as the pacer.
    Shiny
    Shortwing n spamcan driver
    Thanks suntiet thanked for this post
    19,661
    First off I know little about the Sedan but have been told by those that have owned them that they are a great airplane. Alittle experience with 170s both flying and working. Lots of experience with Pacers which in my opinion are the best bang for the buck. The perform well, are moderately priced and parts are readily available. That being said they are more demanding than a Tern.
    Likes DENNY liked this post
    WhiskeyMike's Avatar
    West Boxford MA
    931
    What Steve said. Pacer is clearly the most bang for the buck! 170 is nice but lethargic. Not necessary better in crosswind either.
    10,920
    As Pete said, figure out your "tailwheel thing" before you buy anything. If you just never fly the plane enough to get comfortable in it, you'll never really use and enjoy it. If you're willing and able to commit to flying the thing, then get a thorough tailwheel check out, and THEN decide what airplane would be best. It may well be that a 172 would be best for you.
    Also as others have suggested, what do you intend to do with this plane? Airport to airport? Gravel bars and beaches? Or ????? That's the single biggest question. You can learn to fly a tailwheel airplane IF you put in the time and effort, and STAY tuned up.
    But, if you buy an airplane that won't do what you want to do....
    2,022
    The other thing to consider is how is your IA. A good one can be hard to find and they are all busy. Lots of good deals can turn into 2 year projects/money pits. Find the IA before you start looking for a plane and have him/her approve of the relationship before you fall in love.
    WWhunter's Avatar
    Aug 2003
    1,474
    MTV beat me too it! If you are having that much trouble with the TW aircraft stick to a trike. Put bigger tires on the trike and go have a ball without your worries of screwing up a good plane. I've had my 172 for 32+ years and had it a lot of places. Nothing wrong with a trike if flown to it's limits. During these years of owning the 172, I have had a couple other planes that were TW. Actually still have an S-7 short tail which is a little on the squirrelly side when the winds get nasty. On those real bad days I take the trike and it sure makes landing/Takeoffs less demanding. Go get a trike, fly the snot out of it until you get comfortable in less than perfect conditions, then move to the TW. JM2C
    Likes hotrod180, mike mcs repair liked this post
    strangeak's Avatar
    Aug 2003
    Wasilla, AK
    211
    The tail wheel tune up getting fixed is a given.. I was thinking Don Lee just north of me for that
    The mission is 2 people usually..an occasional 3rd. Playing up in knik, sand bars for a bit of fishing, beaches for claming..always wanted to go to serpentine hotsprings.. general exploring alaska..
    5,139
    Given those choices? I'd favor the 170B. I've seen some impressive performance even with an 0-300. But I'm biased. I like Cessnas. I like Cessna flaps. I like metal plane durability for parking outside.
    Likes eskflyer, FdxLou liked this post
    Aug 2009
    Nikiski , AK
    380
    I love my shortwing pacers, but I have now been a converted fan to the 170B , yes the o300D is lethargic with cruise prop but if you put the 1A175SFC8040 oh her and 26" tires, BBwheel tailwheel , she climbs like a homesick angel and will get you onto and off again on beaches and off airport places. I LOVE THE FLAPS. I will be home in 2 weeks if you want to come down to KENAI and fly a pa22/20 and a 170B. Just pm me if you are interested.
    Shiny
    Shortwing and Spamcan driver
    7,086
    I love the 180. I would not have a 170, B or otherwise.
    Don Lee convinced me that a 160 Pacer is actually a good aircraft. His would do anything we asked it to do. But I have an aversion to steering wheels, so maybe a 160 Clipper?
    I think the Pacer gets an undeserved reputation due to toe brakes on the conversions. Right when you really need a touch on the brake the rudder pedal is up against the firewall.
    Likes eskflyer liked this post
    5,139
    Quote Originally Posted by eskflyer View Post
    Shiny
    Strange, that's a pretty sweet offer. Go find out which one you prefer. What an opportunity!
    I can probably get you a ride in a Sedan but it'd be on floats. Interesting airplane on tires or skis. You'll learn to be an aggressive slipper if you go with a Sedan. No flaps, no flap mods.
    Dec 2008
    Nova Scotia
    928
    I'm no help but having tailwheels all my flying life, and current owner of 0360 Bushmaster, if I were to try another brand it would be 0360 Aeronca Sedan in experimental category, from what I've heard and read.
    G44's Avatar
    Oct 2011
    SW Michigan
    545
    Quote Originally Posted by King Brown View Post
    Why experimental? What experimental category?
    G44's Avatar
    Oct 2011
    SW Michigan
    545
    Don't underestimate the capabilities or a 180hp 172 or 182 with a big nose wheel fork. If you have any doubts just look at some of the videos MotoDave posts. I would think a big tire trike would have no problem at Poly Creek or many places in Alaska. You would enjoy your flying more and be more relaxed while out exploring. Also consider, trikes are much cheaper to insure if you insure your airplane. Just my opinion.
    Kurt
    Thanks Poor Joe thanked for this post
    Likes spinner2, FdxLou, hotrod180 liked this post
    strangeak's Avatar
    Aug 2003
    Wasilla, AK
    211
    That is a great offer... I'll see if I can swing a trip down that way and let you know.
    Went to the talkeetna gross weight stol competition. No Pacers. A lot of 170s both 180hp and 145. that Bush air guy can really work that plane.
    Hardtailjohn's Avatar
    Marion, MT
    769
    Don't walk by a Stinson without looking at it too.
    John
    Likes cubdriver2, BC12D-4-85 liked this post
    Dec 2008
    Nova Scotia
    928
    G44, I'm musing on Sedan experimental; I couldn't go back to anything certified. Maybe Owner Maintenance; there must be a way! (I believe in miracles and magic.)
    L18C-95's Avatar
    May 2011
    Oxford UK
    494
    Nice PA16 for sale over here in the UK
    www.planecheck.com?ent=da&id=41805
    10,229
    $50,993 is a lot of money for a Clipper, even a nice one.
    Jun 2006
    Alaska
    357
    When I was looking a year ago I ended up settling on a Pacer, because you can get one with most of the desirable mods for 7-10k less than than a similar 170. Performance will be similar, fabric is easy to repair, and useful loads leans toward Pacers. Also O-320s have much better support.
    Likes DENNY, Steve Pierce liked this post
    2,022
    The STOL contests are fun to watch, however, real off airport landing is not the same due to the increased risk of landing short/long. Similar, if you multiply the distance X 2 or more. Lots of planes will do well off airport, they just don't compete well in a STOL event to a striped down big wing/big power plane.
    7,086
    I forgot about the Stinson. We had a dash 5 that would out-lift a C-180, and go practically straight up. It was a beautiful thing, and the back seat was the most comfortable sitting place ever designed by humans. The last thing I did with it was an aileron roll - it was really quick!
    But it was slow, and ate gas. The Lyc 180 conversion might be a better choice.
    A good Clipper might cost $25 grand. With a decent engine and radios, it is a very nice traveling machine.
    Likes Doug Budd, Hardtailjohn liked this post
    scout88305's Avatar
    Feb 2006
    Northern Minnesota
    1,738
    Don't discount the Cessna 175. Even some skilled and notorious aviators have considered them a worthy steed. Cool factor is still high enough up the scale that the chicks line up for rides; despite the pilots white legs coupled with a Hawaiian shirt.
    Thank a sheepdog today for they are standing guard!
    Likes cubdriver2, WWhunter, Dave Calkins liked this post
    10,184
    10,920
    Quote Originally Posted by scout88305 View Post
    Yeah, sorry for the glare off those legs.....
    Likes scout88305 liked this post
    Oct 2013
    28
    Quote Originally Posted by WWhunter View Post
    Attachment 43029
    I agree, you can do a lot of backcountry with a 172 properly set up.
    don
    744
    Flying tail wheel planes is not such a big deal. All what you're used to. Can't tell any difference when off the ground. Try to fly what ever well.
  1. Piper Pacer/Tri Pacer Question
    By m1fan in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 01-10-2019, 05:44 PM
  2. C-170B control yoke failure
    By BC12D-4-85 in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 12-19-2017, 09:57 PM
  3. Supercub pa-18-150 swap for 170B
    By bushmaster in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 01-24-2012, 10:57 PM
  4. continental 0-300 170b question
    By munro in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-20-2006, 03:21 AM
