Results 1 to 14 of 14
Thread: Landes Fuel Only Pod Removal
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,613
    So, 4CC has a 31 gallon Landes fuel pod on it. I don't use it very often and was thinking about removing it - at least temporarily. Anybody else taken theirs off and on? Tips, pointers, etc?
    3,823
    You wouldn't think you'd need it to get to graham, except for headwinds. And still had to stop for fuel
    Thanks Oz. thanked for this post
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    335
    Leave it on, NO speed loss so why take it off and on as needed. It is set up now and works. Don't mess with it. The 180 HP will carry it no problems. I hope?
    I leave my cargo pod on all the time as it doesn't effect the airspeed.
    My thoughts
    Doug
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,613
    Quote Originally Posted by Colorguns View Post
    My thoughts
    Doug
    I have been charged with competing in a couple stol demo events this year and I thought maybe I'd lose a little weight...
    Sent from my Pixel using SuperCub.Org mobile app
    Meanwhile,...
    5,051
    Maybe time to reconnect that little prop controller switch with the guard on it.
    Likes SJ, RaisedByWolves liked this post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,426
    You or the plane?
    Likes SJ liked this post
    Bill Rusk's Avatar
    5,246
    Steve
    I have had mine off and on several times. It is not that hard. The back strap is the hard one for me. I put the pod in position then slide it as far forward as possible to give a little extra room for the back strap, get it started, then slide the pod forward a couple of inches and into position, then get the other straps started.
    Our airplanes should be about the same height, 3" extended and 31's,
    I use the stool as a lift. Put it under the pod then use the lever to raise it up under the pod.
    Seems to work pretty good. If doing it at a show get a buddy to lay under the pod and lift it. It is not heavy (assuming no fuel). Don't forget cotter pins if doing it away from home.
    Hope this helps
    Very Blessed.
    Thanks tripper thanked for this post
    Likes SJ, DENNY, RaisedByWolves liked this post
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,613
    Thanks, Bill! What would you say it weighs? (since I KNOW that you know... )
    sj
    Bill Rusk's Avatar
    5,246
    Steve
    Pod and mount hardware weigh 27.6. pds Fuel pump, lines, wires, fuses and switch add another 2.5 for a total of about 30 pounds. Obviously you are not going to remove all that so, bottom line,..... you can take out 27 pounds. That is pretty significant. Remove the rear seat and you will be close to 50 pounds. Go for it!!
    Hope this helps
    Very Blessed.
    Thanks SJ thanked for this post
    Likes SJ, FdxLou liked this post
    Sep 2006
    Spokane
    132
    Do what Laura says and go on a diet....
    Light Hauler
    May 2013
    Alberta Canada
    56
    Anytime I tell people I want to shed some weight from my airplane they all suggest I start with the pilot��
    9,841
    Steve
    Hope this helps
    SJ, if you leave it on at least you'll have an excuse.
    18,812
    Someone told me that a good pilot always has at least 3 excuses.
    I can have my pod on or off in 15 minutes but it is crago only, no fuel. I put a piece ofcarpet on the floor and put my legs under the pod and balance it with my kness till the turnbarrels are undone and set on the carpet and then slid out.
    You have paperwork with all the weights.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,613
    I must not be a very good pilot I only have two excuses..
    Likes Farmboy, Steve Pierce liked this post
  1. Fuel lever removal
    By C130jake in forum CubCrafters: CC18, CC11, CC19 Top Cub, Carbon Cub, and X-Cub
    Last Post: 04-03-2019, 05:40 PM
  2. Cracked Landes ski
    By A BELLAND in forum Ski Flying Forum
    Last Post: 01-04-2012, 05:15 PM
  3. Landes Ski Even on the Right
    By Flying Miss Daisy in forum Cafe Supercub
    Last Post: 01-01-2011, 11:29 AM
  4. Gary Landes
    By SJ in forum Gone West
    Last Post: 11-30-2006, 01:23 PM
