Results 1 to 11 of 11
Thread: 2" SCAT Splitter
    Grant's Avatar
    At Work.....
    1,627
    2" SCAT Splitter
    We are installing a new exhaust (Sutton) and the previous system (Atlee Dodge) included an additional exhaust shroud for rear seat heat that ported that air over to a firewall valve. We need to split the main cabin heat duct from the Sutton and bring it up to the previously installed rear seat heat firewall valve.
    Now I am pretty certain that Aircraft Spruce had these nifty "Y" splitters, But they changed their website and I cant find it. Does anyone here have a source for such a thing?
    Southern Aero's Avatar
    Jan 2008
    kcco/1ga2
    182
    Ha, I know...… everything that was easy to find is now more difficult...….. it's under "heater"
    https://www.aircraftspruce.com/catalog/eppages/2diaytube.php?clickkey=10872
    ......... It doesn't cost any more to go first class! You just can't stay as long.
    19,093
    That is why I like the paper catalog, I know where stuff is in it and can plug the part number in the computer.
    Likes mike mcs repair, irishfield liked this post
    Jan 2008
    kcco/1ga2
    182
    Yep, then plug it in the 'puter for "will call" at AC Spruce. Drive a few miles and Madi hands it to me over the counter. Sure is great having them just a few minutes away!
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,186
    Quote Originally Posted by Southern Aero View Post
    That’s living large right there.
    Transmitted from my FlightPhone
    19,093
    That would be handy. I keep a running order till I get $200 worth and get free shipping through my dealer account.
    Sent from my Pixel 2 XL using SuperCub.Org mobile app
    Likes tcraft128 liked this post
    charlie husky's Avatar
    Dec 2017
    Crystal,Mn
    49
Size:  11.7 KBClick image for larger version.
ID:	42884Another good option is adding a mid-year Cessna 172 carb heat stack robber for cabin heat. On my Husky A1-B, I put the robber on #4, y-tubed with aircraft spruce Ytube into the cabin heat box. No messing with carb heat, so no field approval needed by Mpls FSDO. Is a minor alteration with log book only entry by mechanic per Mpls FSDO. Pic #2 is Sutton h.s.robber. Wentworth aircraft, KMIC, Mn has used ones, I paid $20 @2years ago. I also added carbon fiber heated seats front and back $50, and a 0.2amp computer heat sink muffin fan in the cabin heat box outlet ($9). Toasty now.
    Quote Originally Posted by Grant View Post
    Thanks cruiser thanked for this post
    May 2017
    570
    The only down side if that installation for cabin heat is the possibility of dumping CO into the cabin. Most cabin heat muffs take outside air, duct it through the heat exchanger, then to the cabin. They don’t normally take air from in the cowling where an exhaust leak at a joint could dump CO in the cowl.
    Likes DENNY, mike mcs repair, Chicken Hawk liked this post
    Dec 2017
    Crystal,Mn
    49
    True that! What CO2 detector for, mine is an A1-B, no insulation, quite leaky. Not a sealed up spam can.
    .....And a muffler factory heat shroud could be feeding CO into the cabin in the stock setup from an unseen crack under the shroud.
    Quote Originally Posted by dgapilot View Post
    Jan 2008
    kcco/1ga2
    182
    Was at AC Spruce earlier ............. Madi says Hi!
    RVBottomly's Avatar
    Sep 2017
    640
    I think I talked to her last week for my spruce order. Now I have a face to go with the voice.
    Sent from my SM-J320V using SuperCub.Org mobile app
  1. SCAT tube routing for exhaust heat muff
    By Gordon Misch in forum Modifications
    Last Post: 04-23-2011, 01:03 AM
  2. 45 Degree scat flange
    By tempdoug in forum Experimental Cubs
    Last Post: 01-20-2008, 10:18 AM
  3. J5A with A-75 Scat Hose Issues
    By rrb in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-04-2006, 07:58 AM
