Hello all,
Thinking ahead to when I’ll be taking the super cub off floats and putting it back on wheels and wanted some opinions on the gear. I’m thinking I’d like to go with 3” extended gear and 26”ABWs and keep my borer prop on with that extra clearance. I’ve looked at the CC3x3 and the Alaska airframe products.. does anyone have any thoughts on which is better or if extending the gear is worth it over the stock gear?
Also, does changing the gear to an extended version put the aircraft into an experimental class in Canada or does the stc take care of that?
Cheers!
(new to the mod world here btw if you can’t tell already8))
Cheers!
