Results 1 to 8 of 8
Thread: 3 extended gear or stay stock?
    Feb 2019
    3
    Post 3 extended gear or stay stock?
    Hello all,
    Thinking ahead to when Ill be taking the super cub off floats and putting it back on wheels and wanted some opinions on the gear. Im thinking Id like to go with 3 extended gear and 26ABWs and keep my borer prop on with that extra clearance. Ive looked at the CC3x3 and the Alaska airframe products.. does anyone have any thoughts on which is better or if extending the gear is worth it over the stock gear?
    Also, does changing the gear to an extended version put the aircraft into an experimental class in Canada or does the stc take care of that?
    Cheers!
    (new to the mod world here btw if you cant tell already)
    Thanks Delta Cub thanked for this post
    Sep 2006
    corvallis,or
    414
    Airframes powder coated 3” extended are very nice and what I use.
    May 2013
    Alberta Canada
    55
    Extended Gear STC is valid in Canada
    18,760
    Atlee Dodge 3" extended gear is my choice. It has the correct attach and axle alignment. The 3x3 gear puts more weight on the tail, I could see it on a competition airplane but prefer the lighter tail of my 3" extended over the 3X3. All of them are STC'd and should be approved in Canada.
    Thanks JDWilliams thanked for this post
    Likes DENNY liked this post
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,815
    3+3 is good for O-360 installations, but for a 320 Cub I feel the same as Steve, don't move it forward. The tail gets heavy.
    3,807
    I put my tie down bag tied down in the back of the extended baggage. That helps a lot, and its always in the airplane. 3 ext cc gear
    4,655
    Quote Originally Posted by KBirss View Post
    Hello all,
    Thinking ahead to when I’ll be taking the super cub off floats and putting it back on wheels and wanted some opinions on the gear. I’m thinking I’d like to go with 3” extended gear and 26”ABWs and keep my borer prop on with that extra clearance. I’ve looked at the CC3x3 and the Alaska airframe products.. does anyone have any thoughts on which is better or if extending the gear is worth it over the stock gear?
    Cheers!
    (new to the mod world here btw if you can’t tell already)
    With 26" tires you'll appreciate any AOA improvement you can get. Don't forget to order new shock struts with the gear, and use the same mfgr for gear and struts.
    Likes mike mcs repair, Dave Calkins liked this post
    Jul 2006
    AK
    63
    I bought new gear a couple years ago. I went from standard to Atlee 3” gear. I never heard a down side about the 3” gear and haven’t found one yet. It’s just a touch more clearance for the prop. I would do it again.
  1. Stock PA-12 gear, stock fuel tank and strut questions
    By txfirefighter628 in forum Cafe Supercub
    Last Post: 06-16-2015, 10:48 AM
  2. PA-12 with 31's and stock gear.
    By lange718 in forum Modifications
    Last Post: 08-13-2014, 12:30 PM
  3. Stock gear vs 3 inch gear
    By 3689A in forum Cafe Supercub
    Last Post: 11-11-2007, 08:28 PM
  4. Stock Gear On Ebay
    By wingnut18 in forum Cafe Supercub
    Last Post: 06-29-2007, 07:25 PM
