I had a PM from one of you folks wondering about adverse effects of using QuikClot. A couple of years ago I did some research into the literature on this substance and found very, very rare adverse effects.
Having written that, it was pointed out that QuikClot is extremely effective in stopping bleeding. It is also difficult to clean out of a wound. It has been suggested that if you think you will be able to get the victim (yourself?) to an ER relatively soon, try to use direct pressure to slow down the bleeding. If you think it will be some time, or that the bleeding is too significant to control with direct pressure, use the QuikClot.
Here is a study out of the NIH that is representative of other studies...
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4268478/
I'll start a thread soon on techniques to stop bleeding, including use of tourniquets, direct pressure, QuikClot, etc.
Regarding Sams Splint, it is extremely useful and does not have to be removed in order to take xrays of the isolated limb. It is also extremely lightweight.
Randy
