Results 1 to 21 of 21
Thread: Electrical Problem
    Bluebear's Avatar
    Jan 2011
    Westminster, MD
    45
    Electrical Problem
    Just installed new (to me) garmin radio and transponder in my -18. They work great. However, whenever I transmit, my EI bar-graph engine analyzer, which is also powered by the avionics bus, reboots. Iím guessing that the radio is drawing either current or voltage below some critical value, causing the analyzer to momentarily shut off. However, I donít seem to get abnormal indications from the ammeter or voltage indicator when the problem occurs. The alternator is an interav 12V 50A model. Anyone else seen this kind of issue? Ideas? Thanks in advance.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,018
    Quote Originally Posted by Bluebear View Post
    Yes, mine has always done that also.
    Sent from my Pixel using SuperCub.Org mobile app
    3,024
    Your Com coax cable is routed to close to the back of your gauge or it's bundled with the gauge wiring. Separate from ALL wiring and tape or tie it all by it's self.
    5,129
    Why would you power an engine monitor on the avionics bus?
    Likes wireweinie, FdxLou liked this post
    3,076
    FWIW I have a Garmin G5 electronic horizon in my C180.
    I have it wired to the avionics circuit, so it is off when I start the engine,
    then powers up (along with the radios) when I turn on the avionics master.
    If I had an engine monitor, I'd probably power it the same way.
    IMHO if there's a low-voltage or similar issue with my airplane's electrical system,
    it probably wouldn't matter which circuit the device is on.
    All the milk comes out of the same cow.
    behindpropellers's Avatar
    NE Ohio
    6,782
    How are your grounds wired? I would jumper a ground to your EI from the battery and see if the problem persists.
    Jul 2013
    30
    Because the EI says to in the STC installation instructions (i.e. mandatory to power the UBG-16 from the radio bus). Also, EI pilot's manual says to never start the aircraft with the unit powered on.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,580
    Electronics International recommends wiring their engine analyzers on the master bus. They told me it would be okay. So far, so good. Garmin also recommends wiring the G5 to the master bus.
    3,024
    The UBG seems a bit of an aberration. The other E.I. instruments show instructions to connect power to the main bus. This is the way I always connect engine instruments as they need to be on line to monitor said engine. Even if I need to shed power, engine instruments would seem to some of the last items I'd shut down.
    As for me connecting UBG's to the main harness all these years . . . I just feel awful
    3,076
    …. Garmin also recommends wiring the G5 to the master bus.
    F
    WIW I have the pre-STC'd version of the G5 in my airplane.
    I just read through the first 40 or so pages of the 152 page G5 user's manual--
    didn't see anything in there about connecting G5 power direct to the master circuit.
    Just showed both the power-in pins connected to 14v or 28v power.
    3,024
    Bluebear, let us know what fixes the problem. Pass the knowledge on to others so that they can avoid similar situations.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,580
    From the installation manual. A Garmin engineer told me that the main bus was OK.
    4.3.2 Power Distribution
    The circuit protection device for the G5 and GAD 29/29B must be a push-pull manually resettable circuit breaker or identically rated circuit protection device approved by the aircraft type certificate. See Section 3.2.1 for required circuit breaker part numbers. The G5 must be connected to the battery bus to supply power . (Note: some aircraft manufacturers may label the battery bus as “essential bus” or “main bus”).
    F
    Bluebear's Avatar
    Jan 2011
    Westminster, MD
    45
    The circuit protection device for the G5 and GAD 29/29B must be a push-pull manually resettable circuit breaker or identically rated circuit protection device approved by the aircraft type certificate. See Section 3.2.1 for required circuit breaker part numbers. The G5 must be connected to the battery bus to supply power . (Note: some aircraft manufacturers may label the battery bus as ďessential busĒ or ďmain busĒ).
    Bluebear's Avatar
    Jan 2011
    Westminster, MD
    45
    I will certainly share the ultimate solution. Iím out of town at moment. Many thanks to those who have suggested possible fixes.
    3,076
    That must be out of the manual for the STC'd G5 --
    The user's manual for the pre-STC version doesn't even have four sections, just two::
    Section 1: installation manual, and Section 2: pilot's guide.
    But like I said, the milk all comes out of the same cow--
    at least on small aircraft like most of ours.
    The "avionics buss" on mine is separated from the "essential buss" / "main buss" by a wire and a switch--
    A joggle in the power on the main buss is also gonna result in a joggle on the av buss.
    I do have the G5 circuit on it's own circuit breaker, as are the com, txp, and GPS.
    3,024
    The point of an avionics bus is not to have a separate source of power, it's to conveniently control the power to the equipment connected to the avionics bus. I.e. turn off avionics power on start up, with one switch or relay.
    All electrical power comes from the same source on all aircraft; a generator/battery system. Even multi engine aircraft. The power generation system is regulated to act as a single source. And aircraft with primary, secondary, and emergency busses have the ability to turn off or select individual engine driven generators and individual battery packs. But ultimately even the batteries are charged by that generation system.
    JimParker256's Avatar
    Aug 2015
    Farmersville, TX
    353
    I am absolutely no expert on this stuff, but I had always heard that the purpose of the avionics bus was to allow all the radios (the only sensitive electronics "back in the day") to be turned off with a single switch to avoid "power surges" on startup. But after reading most of Bob Nuckoll's "AeroElectric Connection" book and website, he seems convinced that a switched avionics bus is an ancient artifact, made obsolete by today's electronics which can handle most anything the aircraft's electrical system can throw at it. And that "expert opinion" appears to be vindicated by the installation instructions for pretty much every recent piece of electronic gear I've checked out for my Bearhawk Patrol build... With the caveat that I'm looking mostly at experimental stuff...
    Given that as background, and knowing the the EI UGB-16 is a bit "long in the tooth" compared to their MVP and CGR series products, I would suspect that the UGB series may not have the same level of internal protection as the later stuff. Thus EI's recommendation to wire it to the avionics bus. The Garmin G5 on the other hand is a thoroughly modern design, and as such can be (and is recommended to be) installed directly to the main bus.
    Personally, I would not want essential engine information switched off with the avionics, nor would I want to delay seeing oil pressure, etc. until I got to the "Avionics bus - ON" item in the checklist sequence... I want to see an oil pressure rise immediately after startup. If the UGB-16 actually is required to be switched off for engine start via the avionics bus, that would definitely lead me to at the very least add a backup "direct-reading" oil pressure gauge, or possibly even better, select a different engine monitor for my airplane.
    Jim Parker
    2007 Rans S-6ES
    Likes Eddie Foy liked this post
    3,024
    Instruments aren't avionics.
    3,076
    Isn't "avionics" a contraction of aviation electronics?
    So IMHO it covers more than radios.
    3,024
    Gauges are gauges. Other than the UBG, you'd be hard pressed to find an electronic instrument that calls for being connected to anything but main bus power. This is because engine instruments are intended to be online and operational whether the engine is off, running, or being started. Radios/nav are secondary to engine operation.
    As most radios, navs, transponders, etc, call for being connected to an avionics bus or at least be shut off during start up, my guess is that the power supplies in the engine instruments are filtered and conditioned to reduce the voltage spikes that occur during start up. If the 'avionics' units are powered down during start up, then they don't need the extra circuitry installed.
    Bluebear's Avatar
    Jan 2011
    Westminster, MD
    45
    Thank you to all for the great thoughts and ideas! It turns out that a simple loose ground was the cause of the problem. Nothing more complicated than tightening a nut on the ground bus. Back to normal ops.
  1. Electrical problem troubleshoot. Dummy needs ideas lol!
    By Texas 12 driver in forum Cafe Supercub
    Last Post: 09-06-2011, 12:56 PM
  2. Electrical/No Electrical that is the question
    By High Country in forum Cafe Supercub
    Last Post: 07-05-2008, 02:10 PM
  3. PA-14 Electrical Problem
    By SimonK in forum Super Cub Sick Bay
    Last Post: 08-29-2004, 12:42 PM
