Results 1 to 2 of 2
Thread: Brake pedal assembly
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,133
    Does anyone know why Piper angle cut the end of the brake pedal tube 45 degrees and caps it? Doesn't seem to be any sort of clearance issue, so all I can assume is that it would be for strength. The issue I have with that theory is the other end is left open and square.
Name:	Screen Shot 2019-04-12 at 4.56.19 PM.png
    81232-18 is just labeled disc, as in a welded cap.
    Mar 2016
    910
    I would rather have the end cap run up the tube a bit, whether or not it is square end or angle cut. Both ends personally but that matters more with thin tube construction.
    Likes Farmboy liked this post
  1. Brake pedal movement.
    By Nathan K. Hammond in forum Super Cub Sick Bay
    Last Post: 01-13-2013, 10:13 AM
  2. Brake Pedal Links
    By Binty in forum Modifications
    Last Post: 11-22-2012, 01:24 PM
  3. J-4a Info and Brake pedal 337
    By Staggerwingse17b in forum Modifications
    Last Post: 11-01-2006, 09:13 PM
