Results 1 to 21 of 21
Thread: Telling stabilizer LH and RH apart
    Jan 2016
    Kalmar Sweden
    4
Name:	all essambly reinforce facing up.jpg
ID:	42471Click image for larger version.
Name:	reinforce facing up.jpg
    We are working on a P18 1954 and covering using the Stewart system. Everything has worked great sofar, except we realise the two stabilizers have different part numbers but we fail to tell them apart. As far as we can see they are identical except here are a couple reinforcing pieces that are welded on one side only. So you can choose to mount the stabilizer with these facing up or down. Any advice would be appreciated, perhaps its a non issue but.....
    Cheers
    Åke
    11,526
    Never knew there was a left and right. Choose whatever
    nd
    3,664
    can you show a picture of the reinforcing pieces? and are you using a new cross tube? you guys here, which stab takes the biggest beating from the prop?
    Likes KevinJ liked this post
    10,307
    The prettier surface goes up
    Likes 40m, CharlieN, Aake, Hardtailjohn liked this post
    7,276
    Don't turn around and look. Fabric wise, they both seem to survive. Those gear legs don't.
    Likes Aake liked this post
    Jan 2016
    Kalmar Sweden
    4
    Reply and pict
    Thanks for input Have included a pict facing down
    Thanks Mander thanked for this post
    nd
    3,664
    ive heard of but not seen it where the connecting tubes have broke because of being drilled a couple of times for the bolts, just wanted these guys to see if it was up in the tube connecting area. ive seen it on 180s where they will break the tube mounts off the frame. besure to look real close for any cracks where the connecting tube mounts are welded to the frame. how many horse is yours? On mine, i put a grease zerc where the connecting tubes go through. Just adding the only reason i can figure out for different rh and lh in the parts book would be drain grommets or the way it was covered on a covered stab, just a guess. and your reinforced one is like the univair one below and the other is like original. so maybe one was replaced at one time?
    Likes Aake, mike mcs repair liked this post
    nd
    3,664
    Aug 2002
    Talkeetna Alaska
    277
    I always thought an even part number was 'left', and odd numbers are 'right'.
    nd
    3,664
    Jan 2016
    Kalmar Sweden
    4
    You may be right with the grommets as reason for the left right part number since you buy them covered. Also I think your comment about the condition of the pipe and the holes is important we are just about to have a certified welder add curved brackets to the stabiliser tubes, alined with the holes in the tubes connecting the two halves.
    Thanks again for the comments
    Jan 2016
    Kalmar Sweden
    4
    Sorry for not getting the hang of how to post replies and pictures in logic order, but i hope to learn.
    Åke
    S2D's Avatar
    Montana
    4,253
    Put the plates on top so there is less chance of corrosion down the road.
    Likes Hardtailjohn, tempdoug, Rob liked this post
    Dec 2016
    Canyon, tx
    645
    No kidding! I scare my self to death every time I turn around and look at the tail feathers especially under high power and low airspeed. How they last I’ll never know.
    20,175
    Are you using new liner tubes? if not install them like they came off. The holes are not exact. If new liner tubes are used you will have to drill them in place so it won't matter. We put our seam on the bottom when covering.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,411
    I'm with Steve on the seam. When I teach our seminars, easiest way to remember this is put your first application of glue on the top of piece, pretty side up. That will put the seam on the opposite side, out of site on tail feathers. Rudder is a different story, you need to make both sides look nice.
    Marty
    N367PS
    www.marty2plus2.com
    Mar 2016
    1,553
    Quote Originally Posted by Marty57 View Post
    Marty
    I am either having an age related or dyslexic moment here.
    I visualize if putting first glue on top, this is applying the top skin first, which leaves the wrap from the lower skin to have the seam on top.
    I have always installed the lower skin first so that when the upper skin goes on last the seam is on the underside of the tail.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,411
    You are correct, you do put the lower covering on first. This image should help:
Name:	glue applicatioin.jpg
    First step is apply the glue and let it tack up (light green). Next, apply the blue layer of fabric on the side shown. It wraps past the tangent point, inside the tube where the seem will be hidden. Next, another layer of glue (dark green), let tack up. Next, cover top of panel with the red layer of fabric. This red layer of fabric ends with a surface seem on the under-side of the panel. This seem will be visible under the pinked tapes that finish off the panel, no seem on the top side. By applying the light green glue on what will become the pretty or view side first, it puts that seem out of sight on the bottom.
    Hope that makes sense.
    Marty
    N367PS
    www.marty2plus2.com
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    126
    Stab Covering
    I know nothing about this but this drawing seems to confirm things as Piper saw it.
    Stew
Name:	12790_Stabilizer Assembly-Sections.jpg
ID:	42482   Click image for larger version.
Name:	12790_Stabilizer Assembly-Covered.jpg
    Thanks Aake thanked for this post
    Likes mike mcs repair, Aake liked this post
    Mar 2016
    1,553
    Marty
    Just where my mind had the wrong image was the "glue on top" which is correct but I have always put the glue on a 270° wrap, as in your image here would be full contact of the lower surface. My mind saw it as top surface adhesive.
    I may well have always gone too far with that first application of glue but those were jobs I did in the mid 80's. We could only learn from who you could drive too back then.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,411
    When I teach covering, I try to convey the 270* as you mentioned. Easiest way for me to communicate the concept is that after the first application of glue, you should be able to set the piece flat on a table and no glue should touch the table. The second layer of glue should be same, not touch the table when applied. My drawing shows the dark green glue line a bit further than desired.
    I am amazed at the time and effort needed before the internet to communicate and get help. Anytime I have a question these days I just post it here and BAM ........ answers. AND ...... the answers are correct
    Marty
    N367PS
    www.marty2plus2.com
  1. FS: 180/182 stabilizer
    By Charlie Longley in forum Parts and Pieces
    Last Post: 12-23-2018, 09:20 PM
  2. SEL-55-01 Stabilizer - Tailcone and Horizontal Stabilizer Inspection
    By Steve Pierce in forum Cessna: C180/C182/C185
    Last Post: 04-06-2018, 06:12 PM
  3. Stabilizer channels
    By Yamandu in forum Super Cub Repair Facilities
    Last Post: 02-07-2012, 08:29 PM
  4. stabilizer
    By PA-22/20-160 in forum Experimental Cubs
    Last Post: 01-20-2007, 05:03 PM
