Results 1 to 7 of 7
Thread: Lake and Air Gear Advisory System Troubleshooting
    Feb 2008
    Central Texas
    26
    Our Amphib floatplane has the Lake and Air Gear Advisory System installed. Recently it has begun announcing the gear position constantly, even when flying at cruise speed. It seems that it does not re-set when the button is pushed. I wonder if the system is failing or if there could be something else causing the annunciations. Does anyone have any experience or suggestions for troubleshooting?
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,058
    I only pushed the button a few times on a 185 in Fl but thought it had to be pushed pretty hard. Missed a couple of times and hit it again, harder. Maybe like TV remote when the buttons quit working.
    Likes pfm liked this post
    10,988
    Remove the thing's voice and install a couple of convex mirrors out on the wings, so you can VISUALLY inspect the gear position.
    Thanks irishfield thanked for this post
    Likes mike mcs repair, skywagon8a liked this post
    irishfield's Avatar
    2,986
    Is it not activated by either flaps being deployed or low airspeed?? One or the others sensor/switch is baffed. Why I like same as MTV ... KISS... head out of the panel and out the window instead. If I want a woman nagging at me I'll go visit my mother in law...
    11,287
    it's either going off, because it grounded(wire rubbed through), or lost a ground( wire about broken)..
    just a guess, never studied one...
    assuming it actuates using micro switches...
    ( the wire parts/reasons above could also apply to bad micro switches?.. for same reason?)
    3,267
    Lol. If you chose not to go Mikes (Vivion) route:
    What advisory message do you hear? Have you adjusted the threshhold for airspeed trigger? Can you do the self test after you power it up, on the ground?
    9,300
    check wire and sensors for proper current.
  1. Wipaire Laser Gear Advisory System
    By Steve Pierce in forum Float Operations
    Last Post: 03-06-2018, 11:48 PM
  2. fuel system troubleshooting.
    By S2D in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 03-22-2015, 04:22 PM
  3. Electrical system troubleshooting
    By CubCouper in forum Modifications
    Last Post: 12-23-2002, 12:49 AM
