Results 1 to 27 of 27
Thread: Oil Funnel on C180
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,806
    Oil Funnel on C180
    I have been using this very long plastic funnel for years to oil up the C180. I'm sure there are better alternatives as it takes up a lot of space in the back of the plane. Any suggestions?
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,536
    Cut the bottom off of an oil bottle. Instant funnel.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,806
    Yes, but not long enough to stick out of the oil door on top of a 55'
    Aug 2002
    Talkeetna Alaska
    267
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,536
    Didn't know they were different. Works great an a 69.
    Meanwhile,...
    5,144
    Phillips XC gives you a couple free spout extensions in every case, one more reason it's better oil
    Likes flynlow liked this post
    2,944
    I use a similar long funnel, in the hangar.
    What I carry in the airplane for adding oil is two of those blue extensions that Phillips puts in every case of their XC20-50 oil.
    It's a bit awkward but I hold my thumb over the end until I get the nozzle guided into the oil filler.
Name:	oil spout.jpg
    CenterHillAg's Avatar
    Texas Coast
    115
    I use a funnel similar to what SJ posted on my 182, only I cut most of the taper off of the bottom. It’s just long enough to where it can wedge into the oil fill tube.
    Likes Dave Sherwood, Dave Calkins liked this post
    Aug 2002
    Talkeetna Alaska
    267
    Nice feature with this spout is the shutoff valve - screw the spout on the oil bottle and stick it in the filler tube, open the valve - voila! When done, store it appropriately - it's only about 4-5 inches long. Cheap, works fine lasts long time...
    5,129
    I have a bunch of funnels around but only one I use for airplanes, because only one stays clean enough to use. The Skywagon oil filler isn't as bad as the Cub oil filler that's too small to fit an X/C bottle into.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    It will stick out of an original "54" cowl cause that is what I do. Then put it back in a plastic baggie for the next time.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,806
    Quote Originally Posted by CenterHillAg View Post
    That is what I need to do... why didn't I think of that?
    2,944
    I have one of these, used in conjunction with one (or more) blue Phillips nozzles might be the ticket.
    I'll have to experiment with them a little.
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    That’s what I used to think....
    nd
    3,469
    i know nothing about 180s, but cant you get different lengths of these.https://www.ebay.com/itm/Lycoming-Oi...UAAOSwSk5ceB79
    18180's Avatar
    Feb 2008
    Pennsylvania
    104
    I use the yellow antifreeze funnel.
    Jul 2010
    Elizabeth, WV
    561
    Over the years I have carried long transmission funnels in many different vehicles. Always a pain because when I needed the funnel, it was filthy from being loose in a trunk, toolbox, or compartment. My dear wife saved a torn pair of Levi's with a good leg for me. I cut off a good leg as long as I could get. I scrunched up the cuff end and wrapped it with a couple of turns of heavy mechanic's wire and twisted tight. Zip ties work too but the wire is more permanent. Now you have a long cloth bag. Put the small end of the funnel in first and then stuff the extra of the cut end into the big end of the funnel with a twist. My funnel was pretty much sealed in a denim bag and clean to use when I needed it.
    19,249
    This one will work after I finish the onion rings. Sorry, I couldn't resist.
    Likes OLDCROWE, RaisedByWolves, Ruffair liked this post
    2,828
    Makes me want to go buy some onion rings.
    And I don't even like onion rings . . .
    Mar 2018
    188
    I don't have a picture, but Northern Lights Avionics in Anchorage sells a little plastic tube with female threads to fit the oil bottle on one end and male threads to fit the cap on the other. In the middle is a butterfly valve. It's about 3 inches long and sells for about $2.50. They work great. I have them in both Continental powered planes and in the hangar... You screw it on the bottle, shut the valve, tip it into the engine, turn on the valve....etc. When you're done you just put the cap on the end and leave the empty attached until you need another quart. Always clean, always sealed, no messy funnels.. Since I found those things I don't even use a funnel for oil changes - I just switch back and forth between two of them and fill the engine in short order.. I'll try to take a picture and learn to upload it to this site if no-one posts one in the meantime.
    5,129
    Nice idea but some of us buy gallons.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,806
    I am going to do this next time. I rarely have to add a quart between changes on the 180, and it would sure save some top twisting!
    Mar 2018
    188
    Oh.. er.. well.. yeah you're right! Never even thought about that. Now I'm going to have to do a search to see if any are made for gallons...Gallon ones would probably be too big for filler, etc., but boy do the little ones help to stay clean. If you spend more than 1 quart of time away from home the little ones are a great way to have a civilized means to keep a spout in the plane and add a quart when needed..
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    342
    The trick with oil funnels is to keep them in an old fridge. One that still seals, but obviously doesn't need to work. All the dust and dirt from your shed stay out of the oil. Funnels, hoses and used oil bottles all stay clean.
    When on the road, I use the disposable paper oil funnels.
    3,514
    Zip-lock baggies. Easy!
    Mar 2018
    188
    Ziplocks are what you put my little valve things and empty bottles into.. with some paper towels... oil is messy.
    The funnels with screw tops on each end are a great step forward.. Ziplocks alone are fine until you reach inside one for your funnel..
    The perfect solution is easy in your hangar.. I speak more toward what is easy to pull out from under the back seat when away from home to add a quart. Those little valve things have proven so easy I use them in my hangar too.
    3,514
    I stuff a piece of paper towel into each end of the funnel, then into the zip-lock. Then once in a while change out the paper towel pieces. Oh yeah, and have a roll of paper towels in the same box as the oil and funnel. Easy. But then, I'm admittedly a bit redneck - valves and caps and such in / on funnels are kinda complicated for my simple mind.
    Likes 46 Cub liked this post
  1. 55 c180 ach, ak
    By Eddie Foy in forum Cessna: C180/C182/C185
    Last Post: 01-24-2018, 03:52 AM
  2. IO-470 for C180
    By texmex in forum Cafe Supercub
    Last Post: 08-17-2017, 04:59 PM
  3. Replies: 11
    Last Post: 05-31-2015, 09:51 AM
  4. Oil Funnel from Camguard Bottle
    By Darrel Starr in forum Cafe Supercub
    Last Post: 10-12-2008, 08:44 PM
