Results 1 to 9 of 9
Thread: Fuel lever removal
    C130jake's Avatar
    Sep 2012
    Minnesota
    403
    Fuel lever removal
    I took the screw out but it won't budge. Afraid to manhandle it. 2yr old CCEX.
    Sent from my SM-G970U using SuperCub.Org mobile app
    C130jake's Avatar
    Sep 2012
    Minnesota
    403
    Quote Originally Posted by C130jake View Post
    Didn't upload my pic.Click image for larger version.
    3,563
    Put the screw most of the way in, then use a small puller from an auto parts store.
    Thanks C130jake thanked for this post
    19,341
    I have had to do it like Gordon posted with the gear puller. Also a faucet handle puller from the hardware store should work.
    spinner2's Avatar
    Montana
    1,759
    I had mine off a couple of weeks ago doing my Condition Inspection. I have to tug a bit but it should come off ok. Maybe put a bit of penetrating oil on it.
    I like Gordon’s suggestion too. A Phillips head screw will center the point of the puller.
    19,341
    3,983
    Get a plastic bag to catch the springs and ball bearings that will come out at about Mach 2
    Likes mike mcs repair, Chicken Hawk, 40m liked this post
    Scouter's Avatar
    Nov 2003
    Exeter Maine
    1,956
    I have found a lot of those type of things have a drop of loctite put on at assembly. I have to remove the valve awhile ago and just a little heat from a blow dryer made a big difference
    jim
    C130jake's Avatar
    Sep 2012
    Minnesota
    403
    Small gear puller did the trick, thanks. This site and you folks are awesome!
    Jake
    Likes Gordon Misch, mike mcs repair liked this post
  1. Throttle lever ?
    By portfield in forum Cafe Supercub
    Last Post: 11-24-2016, 08:47 PM
  2. Flap lever
    By Evan in forum Member to Member
    Last Post: 11-11-2008, 03:26 AM
  3. Flap lever
    By oliveros in forum Modifications
    Last Post: 07-03-2008, 11:06 PM
