Results 1 to 23 of 23
Thread: Strut-to-Wing Fairing, 185
    Aug 2015
    Indianapolis
    134
    This is what my 185 has where the usual plastic strut-to-wing fairing is. It obviously needs to be replaced, but my question is, is this a real part or something some Canadian stuck on there in its bush days? The only part in the Parts Manual is the plastic one, $99 from MacFarlane, $1 million from Cessna.
    The plastic part has to be prepped and painted, so Iím interested in rubber. I know from past experience that talking to painters is dangerous. My last casual conversation with one cost just short of $20k!
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    I found some fiberglass ones on Ebay. NOS. Biggest deal is dropping the strut unless you buy the plastic split ones.
    9,650
    Quote Originally Posted by StuBob View Post
    The plastic part has to be prepped and painted, so I’m interested in rubber. I know from past experience that talking to painters is dangerous. My last casual conversation with one cost just short of $20k!
    That is the original stock installation directly from Cessna. The 185s did not have fairings on the wing struts. They were optional on the 180s.
    Aug 2015
    Indianapolis
    134
    Maybe I’m reading the manual wrong, but it looks to me like there’s a part number for a fairing linked to my serial number. I can’t find this rubber thing anywhere. But the manual is 600 pages and I don’t really know what I’m doing. . . .
    10,663
    Itís a real part. Donít worry about it. No functionality to it.
    Aug 2015
    Indianapolis
    134
    It’s a real part. Don’t worry about it. No functionality to it.
    It’s sure ugly, though. . . .
    9,650
    Yes, It's ugly. Just a molded piece of rubber which fills a gap between the end of the strut and the wing along with the one at the fuselage. Get some white paint and touch it up.
    The 180s have a narrower chord strut than a 185 which makes it easier to fit a fairing at the fuselage without interfering with the door.
    spinner2's Avatar
    Montana
    1,747
    Stene Aviation makes fairings for Cessna struts.
    https://www.steneaviation.com/
    Likes jrussl liked this post
    4,919
    The split ones can be installed without unbolting the strut.
    https://www.steneaviation.com/collec...rut-cuffs+185E
    Thanks StuBob thanked for this post
    Aug 2015
    Indianapolis
    134
    Just leave the rubber doodads alone and put the fairings over them?
    4,919
    If they don't interfere, why not?
    Interesting that the 185F isn't on the AML.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    I didn't like the looks and fit of the split ones. Too flimsy and plastic. I bit the bullet and dropped the strut for the one piece fiberglass ones. Wasn't that hard.
    Aug 2015
    Indianapolis
    134
    How much shop time do you think it adds to drop the strut?
    9,650
    How old are your fuel tank bladders? Why? Because in order to lift the wing high enough to slide the fairings over the ends of the struts the rubber nipples at the outlets from the tanks will be stressed. Then it could be the cost of the bladders plus 20 hours labor.
    Also when the wing is lifted, the skin on top of the fuselage may scratch that $20k paint job.
    The choice is yours of course.
    4,919
    I don't remember lifting the wing when I helped do mine. Jiggling the wing to reinstall the bolt, yes, but otherwise it sat on the wing jack while we dropped the strut. Maybe I have a faulty memory?
    9,650
    You're thinking of your Cub stewart. The Cessna wings need to be lifted a bit because the end fittings go in several inches at both ends.
    Likes Dave Calkins, RaisedByWolves liked this post
    AkPA/18's Avatar
    Feb 2003
    Big Lake Ak
    665
    Pete I'm not a Cessna guy but could you unbolt the bottom of the lift strut and then unbolt the top and slide it down without lifting the wing much?
    http://thrustline.com/
    9,650
    Not really, there are several inches of fitting which protrude beyond the ends of the actual strut. Then you will need help supporting the strut because it would be easy to do damage in critical areas. This picture is one end partially removed. The other end is similar.
    Thanks AkPA/18 thanked for this post
    Aug 2015
    Indianapolis
    134
    My enthusiasm is flagging...
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    No
    Quote Originally Posted by AkPA/18 View Post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    I did it with an empty tank. A helper and a tall stand or stepladder with a cushion is all you need. Hardest part is removing the bolt. YMMV. I too was dreading it but it turned out fine. I would not do it unless the bladder was empty or very near.
    10,663
    Ruining the bladders was my first thought also!! When I read that today.
    Sep 2006
    Spokane
    132
    We left them off at both ends of the strut in Southeast Alaska on floats. They are all just corrosion traps
    Light Hauler
    Likes Utah 12 Driver liked this post
  1. Wing fairing brace?
    By aktango58 in forum Super Cub Sick Bay
    Last Post: 12-20-2011, 10:53 AM
  2. wing root fairing
    By DW in forum Cafe Supercub
    Last Post: 11-30-2007, 12:43 AM
  3. 12- strut/wing fairing bracket??????
    By WSH in forum Cafe Supercub
    Last Post: 12-16-2004, 12:27 AM
