Sorry nose wheel recommendations ..
Need some help from this experienced group of pilots, owners and Mechanics alike.
Understand this is not a normal tailwheel type issue - but I am sure this group has some great thoughts that will answer the below question
Question. Currently provided in kit form - what experimental airplane has the strongest airframe and nose wheel combination?
Looking for a kit that is;
Have I asked for to much? Does this kit plane even exist? I must be dreaming.
Again, the answer / recommendation must be found in a nose wheel aircraft.
Thanks up front for you ideas and thoughts.
Let the comments begin. All are truly welcomed.
Shep
- side by side seating, 2/3 seats.
- can support up to O-360 (200 hp)- only a Lycoming type / clone.
- all aluminum - every surface
- able to follow big tire cubs around - in the desert and soft dried river beds - within reason - min 8.50’s
- STOL
- 400 mile range
- Strong customer support
- When ordered all the pieces arrive at the time.
- Must be experimental
- Better than average visibility
- Construction can be pull rivets
- Not a first run product- want a kit company with a strong reputation
- Need not float.
- No light sport. After fuel would like 600 lbs useful load.
- Built in 800 - 1000 hrs.
Shep
