Results 1 to 12 of 12
Thread: Revisiting Best Prop Options
    Dec 2017
    64
    Our PA12 with 150 HP has a Borer z(McCauley) 1A175GM 8144 Klip Tip. What’s your opinion on this prop? Im looking for the best short field performance without breaking the bank.
    Thanks flynlow thanked for this post
    9,381
    Without breaking the bank, that is a good prop.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,815
    What is clip tip? Was that to clean up a ding?
    You have a good prop but 44 is a lot of pitch for a 150. It kind of defeats the purpose of a climb prop. Mine's an 82/42 (150) and it's all the pitch I'd want.
    9,381
    A Clip Tip is a name given to the prop by McCauley.
    I have a 1A175GM80-46 which I used on my 7GCB with a 150 hp 0-320. The all around performance was excellent. The 81-44 will only be slightly more climb.
    Dec 2017
    64
    Thanks I’m going into annual and will have the prop looked at.
    10,475
    That’s likely the best all around prop for performance you’ll find....that’s legal, anyway. If you feel like you need a little more takeoff and climb performance, you could have it re-pitched to 42 or 43. That will give a LITTLE better performance, but slow you down on cruise. Re-pitching isn’t a huge deal, call a prop shop.
    3,364
    Mine's an 82/44 (150) and it's all the pitch I'd want.
    I thought you had 8242? That's what I have and I thought we had the same.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,815
    You're right, I do! I went back and fixed my original post.
    Dec 2017
    64
    After talking to one of the AK guys I’m beginning to believe the tips are rounded is due to years of filing. I’m probably going to have to start looking for a replacement. We’ll see what the shop says when she goes into annual
    don
    700
    What about Sensinich W80CM8 - 44 certified composite.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,815
    If the W80CM8 has the same thick hub and airfoil of the W80, its not a very efficient prop. I have a W80-40 and the 82-42 Borer beats it on all counts, except weight. Also, 44 would be significantly fat on pitch. All else being equal, that prop needs to be a couple inches shallower than the Borer for roughly equal performance.
    Dec 2017
    64
    I’ll definitely stick with the Borer Thanks for all the input.
  1. O-320 HP increase options and prop questions
    By roxiedog13 in forum Experimental Cubs
    Last Post: 06-14-2019, 08:54 PM
  2. Prop Options O-320 160HP
    By kevinbarton1 in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 01-17-2019, 08:11 AM
  3. Prop options for a 230HP O-360??
    By Dave Calkins in forum Experimental Cubs
    Last Post: 07-28-2007, 01:41 PM
  4. Replies: 17
    Last Post: 08-28-2005, 11:11 AM
