Results 1 to 8 of 8
Thread: Dynafocal mount ring
    Mar 2016
    1,251
    I have an engine mount ring here from a Beech Skipper that carried an O-235. This utilized 2½" mounts to carry the engine.
    All the larger engines commonly mount with 2¾" Lord mounts.
    I know engine swaps have been done putting O-320 on with the smaller rubber mounts but what are some thoughts of mounting an O-360 with the smaller cushions?
    My gut feeling is to not use this mount ring.
    What experience and opinions are out there about this?
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    if needed i have 2 mounts for 0360 1 came off a cub crafters exp with oil cooler mounted to it and the other i think is a wag aero
    Mar 2016
    1,251
    Quote Originally Posted by skysigns View Post
    That may in time become of interest to me.
    Cub junkie's Avatar
    My Moms basement
    2,087
Name:	Dyna focal 001.jpg
ID:	41947Click image for larger version.
Name:	Dyna focal 005.jpg
ID:	41948I build my own rings but have used the aircraft spruce ring for customers. I like to use the Lord aerobatic cup since its smaller and much more rigid.
    Mar 2016
    1,251
    Is that Aerobatic cup in the 2½ size? if it is that would be the answer for the BE77 donor ring I have been sitting on for decades. I need to check locally if there is a case I can borrow to jig the mount as you are doing since i would like to position the case on my build table to tack everything together.
    Cub junkie's Avatar
    My Moms basement
    2,087
Name:	Dyna focal 007.jpg
ID:	41950Not in the shop right now or I would measure. 2 1/2 sounds bigger than what I use. Check out spruce part #08-03600. They are "homebuilders special" mounts. The cups in the picture I make off the Pitts print and put my own twist on them. They are easy lathe work from tubing and flat stock. The steel bushing in the pic is what I use for jigging, they simulate a compressed rubber mount. If you have a ring you find acceptable for your application I would go with it. The ring and ring kit spruce sells is asian sourced. The steel has that look under the hood when welding. Plenty good for non high G airplane. I don't have any fancy equipment so I still build mounts on the airframe. I get the best accuracy that way. I keep telling myself this is my last one but dam if I didn't also build a conical for this same airframe recently.
    Mar 2016
    1,251
    Spruce is stating 2" on that aerobatic mount, seems small but may well allow for use of the BE77 ring I have.
    Feb 2014
    1
    Where did you get the drawing for the Dynafocal engine mount?
    Likes astjp2 liked this post
  1. PA-18 150 hp dynafocal mount
    By have tools in forum Cafe Supercub
    Last Post: 10-05-2010, 06:53 AM
  2. Dynafocal Mount??
    By Sam Beckett in forum Cafe Supercub
    Last Post: 02-14-2004, 12:22 AM
