Results 1 to 5 of 5
Thread: Cessna control yoke swap?
    6,896
    Not sure of the details yet, but I said I'd help. Big fancy yoke with pickles, requires a different end on the shaft - so the plan is to bolt the new shaft in.
    I think we are looking at putting a 210 yoke in a 172 - not sure yet.
    The question - is this a minor alteration, or does it drift over into field approval territory? It is a sort of change to a control system, but it seems benign to me. I don't do the annuals on the 172, so it has to be documented.
    Thanks!
    10,643
    minor, installed by bolt in.... my $0.02 worth
    I wouldn't even bother logging it..... but that's just me...
    2,644
    No change to the basic design of the control system. Swapping Cessna parts for other Cessna parts. Minor.
    May 2017
    557
    So long as it is bolt in and the lever arm for the yoke is the same, I would say minor.
    I did a DER approval last year on a TriPacer that put a PMA yoke for a PA-28 in. The lever arm (yoke handle to center of rotation) was 1” shorter. I had to verify control forces wouldn’t exceed CAR 3 requirements. That was a major alteration.
    6,896
    Thank you. Just found out it is a late model 172 yoke on an early 172. I haven't checked for multiple type certs, but if all 172s are on the same TCDS, it is a logbook entry.
    Appreciate the insights.
  1. C-170B control yoke failure
    By BC12D-4-85 in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 12-19-2017, 09:57 PM
  2. PA-14 control yoke
    By Zeb in forum Experimental Cubs
    Last Post: 09-19-2006, 09:02 AM
  3. engine swap
    By Ken Gabel in forum Products, Purchases, Reviews & Prices
    Last Post: 09-13-2005, 11:21 AM
