Results 1 to 2 of 2
Thread: Electric Fuel Level Senders
    Dec 2017
    Portland, Maine
    3
    I am currently trying to replace the fuel level senders in my PA14. It has UMA (PMA'd/TSO'd) electric fuel gauges that work in the 30-240 ohm range, 23 gallon Dakota Cub wing tanks with the electric gauge plates. The current senders are a mixed used set from the shelf made to work that are now failing, no visible numbers anywhere on them. Has anyone used these tanks and if so what sending unit did you use and did you have to modify it to calibrate it correctly. Although the plane is currently in Experimental Exhibition I would like to use FAA approved parts on this. Aircraft Spruce has ISS senders but they are not approved. Any help would be appreciated. Thanks...
    10,584
    Quote Originally Posted by John Squier View Post
    Send me a private message in an hour and I can send you the Stewart Warner part number for the gauge. I keep on box top in my tool box at shop. No such thing as approved, they are tractor/ car parts that get a magical stamp that says they are special. The part number that sticks in my head is 818 A and 818 B. Might be right might be wrong. Been 20 years since I bought one.
  1. Replies: 25
    Last Post: 08-03-2013, 12:19 AM
  2. fuel level float
    By n612tm in forum Experimental Cubs
    Last Post: 10-01-2012, 10:17 AM
  3. Electric Fuel Gauges in a -12
    By KJC in forum Modifications
    Last Post: 12-13-2007, 11:23 AM
  4. ELECTRIC FUEL GAUGE - WHERE DO I GET ONE
    By OVEREASYGUY in forum Super Cub Sick Bay
    Last Post: 07-13-2005, 09:16 PM
  5. ELECTRIC FUEL PUMP TIE IN
    By 540T in forum Experimental Cubs
    Last Post: 03-16-2005, 11:40 PM
