Page 2 of 2 FirstFirst 12
Results 41 to 78 of 78
Thread: My Oratex experience
  1. #41
    Jul 2016
    Anchorage, AK
    149
    Have you looked at using a printed/vinyl graphic rather than paint??
  2. #42
    Aug 2011
    Kenai AK
    99
    Yes
    I am not painting the Oratex
    just stripes - for now
  3. #43
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    902
    Clay bar to the rescue.
    Quote Originally Posted by bda View Post
    I thought I would pass on to those that are thinking about Oratex:
    I used electrical tape to mock up a paint scheme and it left permanent marks (stains?) in the Oratex coating.
    I have tried every solvent I can think of and they will not come out.
    alcohol
    citrisolve
    wd-40
    magic eraser
    oratex cleaner
    3m adhesive remover
    acetone
    mek
    and others
    So DO NOT PUT ELECTRICAL TAPE ON ORATEX.
    on the bright side, Oratex can handle a lot of different chemicals.
    Thanks bda thanked for this post
    Likes bda liked this post
  4. #44
    gntw's Avatar
    Mar 2005
    Ft. St. John BC Can.
    199
ID:	44281Click image for larger version.
ID:	44283Click image for larger version.
  5. #45
    gntw's Avatar
    Mar 2005
    199
    Oratex and vinyl stripes done in 12 days 2 guys 8 hr days
  6. #46
    Vermont
    401
    There is a spray cleaner called Greased Lightning. Seems to be a cross between Windex and paint stripper. I use it for gas stains on paint. Work fast. Test first.
    What's a go-around?
  7. #47
    Speedo's Avatar
    Jul 2002
    TN
    1,839
    GNTW, great looking plane. You must be pleased.
    Speedo
  8. #48
    Jul 2016
    Anchorage, AK
    149
    I'm planning an exp. build and have been researching fabric, paint and vinyl. My intent is oratex with vinyl emblems wanting to save labor and weight. Speaking to BAF they stated the vinyl should be breathable to avoid potential bubbling over time. Additionally the graphic shop stated their vinyl lifespan at 5-7 years. The vinyl lifespan concerns me as does potential bubbling. Any others with experience on the subject or a recommendation for a vinyl shop in anchorage ak?
  9. #49
    Vermont
    401
    On RC models, bubbles are something that happens only on installation. Pop with a pin, and the hole is barely noticeable on a 4 foot model. Probably invisible at full scale. My concern would be lifespan and pressing hard enough on unsupported fabric. Is breathable vinyl possible? Shiny on one side and adhesive on the other.
    I wonder if using solid color Monkote would work as trim. Much thinner and lighter. To use Monokote as trim you have to heat tack in a million places before an overall ironing. Otherwise it will shrink before it even touches the substrate. This is done routinely on models, Mono over Mono as trim. Would it stick to woven oratex? Monokote sticks pretty well to 400grit sanded wood.
    What's a go-around?
  10. #50
    mike mcs repair's Avatar
    11,773
    Quote Originally Posted by vj88 View Post
    and that's why I only use vinyl for NNumbers (and I've had a few on different airplanes that I had to replace after only a few years...)
    the failure mode is they curl up from the edges... I will post a couple pictures of OLD vinyl failures locally(chugiak), not sure how old they are... (need to remember to take pictures)
    I doubt you save weight using vinyl.....
  11. #51
    gntw's Avatar
    Mar 2005
    199
    I have done 6 rebuild doing 2 super cubs this winter and that is all I use is vinyl numbers and strips.all are on aerothane paint .my cub was done 20 years ago with poly tone and vinyl stripes still looks great has 3000 hrs flying I all weather conditions up to - 35f.shows a little wear good for long time yet.one cub with aerothane all Mose as old less hrs .the 12we did with oretec is first one.
    Likes CharlieN, Backpacker liked this post
  12. #52
    Aug 2011
    Kenai AK
    99
    I have put Vinyl auto striping on my test piece w Oratex, and left out in the weather, 6 months so far - no lift no bubbles
    Oratex makes their own “vinyl” striping and graphics, comes from Germany, and very expensive, but they will do custom.
    Likes Backpacker liked this post
  13. #53
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    235
    Is anyone doing Oratex "commercially"... As in, If I needed my wings rebuilt and recovered, are folks out there using Oratex?
  14. #54
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,156
    I'm sure any good all around fabrics guy would take it on, one who wanted to see what all the buzz was about. They could get educated on the stuff, on your nickel, why wouldn't they? Others, more conservative, may take a pass.
  15. #55
    Aug 2011
    Kenai AK
    99
    There is a guy here in Alaska, Birchwood I have heard, that is covering w Oratex.
    After my experience, I would not hesitate to tell some one they could do it themselves.
    but,
    I would not pay someone to learn on my airplane. It is just too different from “regular” fabric precess.
  16. #56
    11,773
    ..others, more conservative, may take a pass.
    pass!!!!
  17. #57
    Herc's Avatar
    Aug 2014
    Big Lake, Alaska
    136
    Mike, I remember you talking awhile back about someone that covered with Oratex and it was in rags the next season? I ask because I'll be recovering my cub in the near future and am considering Oratex but leaning towards Stitts. Would you elaborate on your observations of the Oratex?
  18. #58
    11,773
    Quote Originally Posted by Herc View Post
    i don't remember saying that.......
    but I much prefer stitts or dope, ZERO chance of me using this
  19. #59
    Herc's Avatar
    Aug 2014
    Big Lake, Alaska
    136
    My apologies. It's been a couple years, must have been someone else.
  20. #60
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,156
    I can for sure see how someone who makes a living using traditional covering techniques, would not take on a Oratex job, why rock the boat? I also know there are shops out there, maybe a bit hungrier, that may be a bit more open to new techniques and material, that would welcome the chance to do an Oratex job. Maybe even at a discount, as it would be understood there would be a learning curve.
    My only personal fabric experience is 100% Stits/Polyfiber/Polytone, 5 planes, and I'm real happy with it. My current 13 year old plane, kept hangared, 2500 hr TT, still looks great with no issues. But I'm also a weight weenie, and saving maybe 15 to 30 (I've heard all kinds of numbers) pounds would for sure make me strongly consider the O option next time. I also don't really care about the cosmetics, more about ease of repair, light of a weight as possible, and longevity, in that order.
    My only first hand knowledge of the stuff is that Hal Stockman, winner of the STOL Oshkosh event this year, and a long time experiential builder and pilot, and a fellow weight weenie, used it, and just said that after a bit of a learning curve (as compared to his previous Stits work) he liked it, and FOR SURE it paid off in the weight department.
    Thanks super stol thanked for this post
  21. #61
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,336
    There is an IA in Wasilla that uses Oratex on his working Cub and installs it. Also an installer I know that does it for a living (has heat gun will travel). While I know both of them, I receive no compensation or perks of any kind by sending business there way. If anybody wishes to contact them, send me a pm.
    "Always looking up"
    Likes bda, Paul Persinger Jr. liked this post
  22. #62
    Aug 2011
    Kenai AK
    99
    Just an update,
    Have 2 years or so on the Oratex fabric.
    Had a bad fuel leak along the way, no damage, but there is a distinct blue stain from avgas, it seems to be fading tho.
    Everything is holding up very well. I did have a few small spots where I did not heat the tape enough to trigger the glue, and they lifted a little, but easy to fix with the heat gun.
    After the initial install, when I wheeled the plane out in the cold the fabric was too loose, it seems that it will only shrink so tight. So I "froze" the airframe and reshrunk when cold as the frame was smaller, it has stayed tight in all temps since then.
    I had a persistant oil leak for the first 10 hours or so, so the belly got pretty oily, no effect.
    I have also had some pretty hard "dings" that left an impression in the fabric that I thought I would have to shrink out, but they tightened up on their own - still not sure how that works. Very sure that one of those would have gone through "regular fabric"
    All in all I am very happy with it.
    It does not have that fancy airplane shine, but I don't wash my plane enough to care about that.
    It is VERY tough.
    I am going to do some mods in the near future that will require cutting and regluing, I will update after thatClick image for larger version.
Name:	beach plane.jpg
ID:	57602Click image for larger version.
Name:	cabin plane.jpg
  23. #63
    nanook's Avatar
    Aug 2002
    northern alaska
    1,761
    I wonder if, instead of waxing Oratex, you used Aerospace 303? Maybe someone has tried this, Lars?
  24. #64
    Aug 2011
    Kenai AK
    99
    Nanook, I will try it when I get home.
    The beauty of Oratex is the ability to repair it with out mek and paint/silver/dope etc. You just paint the glue on, let it dry, then heat it up until the reaction happens, and then shrink.
    But
    If there is something weird on there, it can be hard to clean well enough to get the glue to stick. I have heard that the Ceramic coatings are really hard to get off.
    A word to the wise: do not think you will save some money by cutting Tapes out of your scrap fabric. Looks like crap. The Oratex tapes are really good now, and nearly disappear when done correctly. You can hide alot of ugly with them.
    Thanks marcusofcotton thanked for this post
    Likes soyAnarchisto, skukum12 liked this post
  25. #65
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,336
    A word to the wise: do not think you will save some money by cutting Tapes out of your scrap fabric. Looks like crap. The Oratex tapes are really good now, and nearly disappear when done correctly. You can hide alot of ugly with them.[/QUOTE]
    I made tapes once for one elevator and will never do it again. Far too much work and a horrible outcome.
    "Always looking up"
    Likes courierguy, pzinck liked this post
  26. #66
    Nov 2015
    Fairbanks, AK
    132
    Quote Originally Posted by nanook View Post
    No data to back this up but, like Armorall, Aerospace 303 has silicone as an ingredient I’m fairly certain. If you ever want a prayer of ever repairing your (insert covering system here, including Oratex) and hope to have the patches stick and remain where you put them, DO NOT spray that stuff on your covering. Silicone is a wicked evil substance to remove once it’s on a surface when it MUST be removed for these purposes. Ever tried to paint where any RTV has been? Takes monumental effort to escape the fisheyes caused by the contamination that’s impossible to even see.
    That’s my nickels worth. Inflation has stricken the 2 cent info supply.
    Cheers, Oz
    Likes BC12D-4-85, Bill Rusk, tedwaltman1 liked this post
  27. #67
    nanook's Avatar
    Aug 2002
    northern alaska
    1,761
    Hey Oz, where are you seeing that 303 contains silicone?
    Likewise, people ask, does 303 Aerospace Protectant contain silicone?
    Unlike many products, 303 Aerospace Protectant does not contain silicone, oils, waxes, glycerin or petroleum distillates. Clear Vinyl Protection: 303 Aerospace Protectant provides effective UV protection for clear vinyl and leaves an optically enhanced finish for clearer vision.
    Quote off the internet from some expert...
    Thanks OzAK thanked for this post
  28. #68
    Nov 2015
    Fairbanks, AK
    132
    Nook, I humbly stand corrected, and in some sort of defense, I did say “no data to back this up” but should have dug into it a bit further before posting. I’ve used several products, like Armorall, that left me wishing I had tried something else. Like the time I used it on the seat on my snow machine back in high school. There are lessons we only have to learn once, that was one such…….
    I truly hope that the 303 is a good and better solution than the Oratex wax. It’s definitely a great product. In any case, I would still caution to do a test patch on a surface that’s been treated so you know the compatibility of the glue and the protectant and how easy it is to clean off etc.
    Cheers, Oz
  29. #69
    gpepperd's Avatar
    Aug 2005
    Wasilla, Alaska
    235
    Silicone removal can be a bear. If in doubt whether or not silicone is present I alway treat the surface with “Polycracker” first. Saves the messy removal of fish eyeing paint. You can get that at your paint store.
    Good judgment comes from experience, and a lot of
    that comes from bad judgment. will rodgers
    "Anyone who would give up liberty for safety deserves neither" Ben Franklin
    Thanks Skywalker, OzAK thanked for this post
    Likes jrussl, OzAK, rotto789 liked this post
  30. #70
    nanook's Avatar
    Aug 2002
    northern alaska
    1,761
    Yeah Oz, I am impressed with 303s UV blocking properties but have never tried it on aircraft fabric topcoats. Mostly used on Royalex canoes and hypalon inflatable boats, works well on tires also...
    Likes mixer liked this post
  31. #71
    Nov 2015
    Fairbanks, AK
    132
    [QUOTE=gpepperd;825472]Silicone removal can be a bear. If in doubt whether or not silicone is present I alway treat the surface with “Polycracker” first. Saves the messy removal of fish eyeing paint. You can get that at your paint store.[QUOTE)
    I’ve fought the silicone/fisheye mess off and on for a long time. It truly is tough.
    Thanks so much for this info, I greatly appreciate this solution and also appreciate you and everyone else here that give so much to anyone seeking knowledge on so many subjects.
    Thanks Mr. Pepperd. Sent you a PM as well.
    Nook, it’s definitely good stuff, and your bringing it up has caused me to realize that it’s time for me to snag a new bottle as mine is about empty. Love it on tire sidewalls, bushwheels best friend and a myriad of other items also. Looks like it’ll get a test on this beast I’m working on after I get the Oratex on it.
    Cheers, Oz
    Likes Airguide liked this post
  32. #72
    nanook's Avatar
    Aug 2002
    northern alaska
    1,761
    I have an Oretex test kit here somewhere…I’ll glue and shrink it to a frame, put 303 on and set it out in the sun for a bit.
    Likes silflexer, tedwaltman1, Hardtailjohn liked this post
  33. #73
    Mar 2015
    61
    I have to say, I love the stuff. But not necessarily for all of the reasons many do. Yes it is lighter, yes it's non toxic, yes it is durable and it saves time...
    My experience, it shapes extremely well with heat, it grips the air frame way, way better than polytack, but here's the kicker... I love it because it takes urethane paints like nothing else in terms of fabric. Simply looks amazing.
    I know you guys have almost totally shunned toxic products, I get it. I've spent much of my life painting, Lars thinks I'm nutz you probably do too, but I've spent a lifetime developing the skill, hell I even like sanding.... so ya, I'm a bit goofy i know.
    I've been shooting an aircam with an elaborate scheme and of all the surface material types on the ac the otex looks the best.....hands down.
    If you like hot rod quality glossy finishes oratex will perform and be significantly less weight than any other painted fabric.
    Oh... and yes for any nervous Nellie's.... yes I exercise proper ppe protocols.
    Thanks brown bear, OzAK thanked for this post
    Likes 40m, rotto789, OzAK, Hardtailjohn liked this post
  34. #74
    Yooper Cub rotto789's Avatar
    Mar 2009
    Mi. ( Yooper)
    214
    I am considering using Oratex 6000 on my new Javron build, while I was at Airventure Oshkosh I visited the nice people at the Oratex booth on the advise of my good friend Rick Pap, his Carbon cub was the red one they had on display. I had quite a few questions for the sales people and most were answered within reason. after a rather lengthy discussion about the product I then asked the big question: How much to cover a super cub? I know material pricing is changing rapidly in most if not all industries these days, mine included (General Contractor) but wow, I think my jaw hit the floor when she told me how much: about a 30% increase over some of the higher quotes I read on this thread from 2019 and not the 5K one. I am still considering the product for its huge time saving qualities and for its weight savings, but man, the price for building an aircraft is getting out of hand. I still like to look for the best value along with quality and convenience, but these days it is getting very difficult. There is no doubt that Oratex is a great product that is a proven performer. I do not know current pricing on any of the other fabric systems out there as of this date (I used Poly fiber my last build 2012) but I would guess they have all increased substantially.
    Just my observation,
    Rick
  35. #75
    Utah-Jay's Avatar
    Aug 2020
    Heber City, UT
    430
    @rotto789
    I just finished the last of my tail feathers yesterday (start the fuselage soon), I never seriously looked at legacy covering due to the faster speed and NO painting of the Oratex which as you pointed out makes for a faster completion time. I also like the idea the toughness of Oratex. When you add up the cost of fabric, paint, paint application tools (gun etc…) paint booth and of course time, I doubt there is my price difference.
    If you are looking for a show plane, I think legacy covering + paint is the way to go. I was looking for a tough covering, fast completion when I made my choice.
    Bearhawk Companion QB Builder
    Revo Sunglasses Ambassador
    https://www.instagram.com/jay_townsend_utah/
    https://www.youtube.com/channel/UCQ0...tBJLdV8HB_jSIA
    Likes rotto789, bda liked this post
  36. #76
    Mar 2009
    Mi. ( Yooper)
    214
    Quote Originally Posted by Utah-Jay View Post
    @rotto789
    Great points and definitely something to consider when choosing a fabric covering system, I am not looking for a show plane, however, I am a detail oriented person and want the end result to be as near perfect as possible. Utility along with a great finished product is my end goal and we all know that the better the end result the better the resale value for when the day comes we cant fly anymore.
    I already have all the tools and equipment necessary to cover and paint using the traditional fabric systems from my current cub, so no price consideration needed for those items. there will be needed specialty tools for the Oratex system which I will have to purchase, so some consideration there. I am not opposed to paying the extra money, its just a hard pill to swallow given the current circumstances.
    I am also not getting any younger, and want to get the next build flying sooner that later, don't get me wrong, I do thoroughly enjoy the build process but time is against me and I'd like to be up and flying within a max of two years after starting my project. the other problem is, life gets in the way
    Rick
  37. #77
    Nov 2015
    Fairbanks, AK
    132
    Quote Originally Posted by rsrguy3 View Post
    rsr, I have at least one question. I’m no pro painter so any help is appreciated. My build (Exp. PA-12) is coming together, my Oratex is in the shop waiting for that day. I’ve had mixed results with vinyl in the past so I’ve resigned myself to the thought that I’m going to do some painting. Heck, it’s a given anyway because I have to paint the cowling and other sheet metal parts, small parts and so on so no big deal.
    Question is this….For the Otex at the very least, you mentioned urethane paint. That’s a fairly broad brush so what is your go-to brand, type, etc? Any advice or quirks on types, what not to do, anything that makes for better outcomes and so on much appreciated. I know those answers can get complicated, generalities will work, anything helps so thank you in advance.
    I’ve often thought that if a guy could use some of the newer paints and especially paint colors the automotive industry is kicking out and apply them to fabric covering, it would be a beautiful thing. Seems you’ve found that answer. Well done!
    Thanks again!
    Oz
  38. #78
    Mar 2015
    61
    So there's a bit to unpack here. I've used a alot of aerothane, It shoots well and is flexible as well as durable....(I don't mind repairs either). Superflight is excellent as well. I’ve also heard good things about airtech. All are formulated for fabric.
    Lars mentioned Stuart paint so that must mean it works with otex. I personally don't care for it or some of the negative things the folks there think about those of us that don't care for it. It's been insinuated that those of us that dislike its special application requirements are trogladites, ludites and generally old school hicks incapable of change.. I have used stews, I had an excellent finish, but l won't use it again, I shouldn't have to use the force to get paint to flow out... Anyway I don't let my fear of chemicals or my wife dictate what material I shoot so I shoot traditional solvent urethane paint formulated for ragwings.
    Most of the aircams being shot these days are 2 stage high end ppg stuff, and they've been lasting well from what I'm hearing. My hunch is it would likely work well with otex... might even weigh less than shooting aerothane or sf as the base coat can cover well with one good coat unless your trying to shoot a terrible hard to cover color like yellow.
    Come to think of it I'd like to see a yellow otex cub with a light coat of cub yellow aerothane, that would look amazing and still shave a lot of #'s...
  1. Oratex Fabric
    By FullThrottle in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 10-21-2018, 10:18 AM
  2. Oratex system
    By skysigns in forum Cafe Supercub
    Last Post: 06-16-2018, 11:44 AM
  3. Oratex
    Last Post: 08-29-2017, 06:24 PM
  4. Oratex fabric covering
    By copter86 in forum Member to Member
    Last Post: 05-10-2017, 06:52 AM
  5. Oratex Fabric
    By Roger Peterson in forum Experimental Cubs
    Last Post: 12-25-2015, 08:29 PM
