Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
Thread: My Oratex experience
  1. #41
    Jul 2016
    Anchorage, AK
    139
    Have you looked at using a printed/vinyl graphic rather than paint??
  2. #42
    Aug 2011
    Kenai AK
    93
    Yes
    I am not painting the Oratex
    just stripes - for now
  3. #43
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    842
    Clay bar to the rescue.
    Quote Originally Posted by bda View Post
    I thought I would pass on to those that are thinking about Oratex:
    I used electrical tape to mock up a paint scheme and it left permanent marks (stains?) in the Oratex coating.
    I have tried every solvent I can think of and they will not come out.
    alcohol
    citrisolve
    wd-40
    magic eraser
    oratex cleaner
    3m adhesive remover
    acetone
    mek
    and others
    So DO NOT PUT ELECTRICAL TAPE ON ORATEX.
    on the bright side, Oratex can handle a lot of different chemicals.
    Thanks bda thanked for this post
    Likes bda liked this post
  4. #44
    gntw's Avatar
    Mar 2005
    Ft. St. John BC Can.
    159
ID:	44281Click image for larger version.
ID:	44283Click image for larger version.
  5. #45
    gntw's Avatar
    Mar 2005
    159
    Oratex and vinyl stripes done in 12 days 2 guys 8 hr days
  6. #46
    Vermont
    381
    There is a spray cleaner called Greased Lightning. Seems to be a cross between Windex and paint stripper. I use it for gas stains on paint. Work fast. Test first.
    What's a go-around?
  7. #47
    Speedo's Avatar
    Jul 2002
    TN
    1,788
    GNTW, great looking plane. You must be pleased.
    Speedo
  8. #48
    Jul 2016
    Anchorage, AK
    139
    I'm planning an exp. build and have been researching fabric, paint and vinyl. My intent is oratex with vinyl emblems wanting to save labor and weight. Speaking to BAF they stated the vinyl should be breathable to avoid potential bubbling over time. Additionally the graphic shop stated their vinyl lifespan at 5-7 years. The vinyl lifespan concerns me as does potential bubbling. Any others with experience on the subject or a recommendation for a vinyl shop in anchorage ak?
  9. #49
    Vermont
    381
    On RC models, bubbles are something that happens only on installation. Pop with a pin, and the hole is barely noticeable on a 4 foot model. Probably invisible at full scale. My concern would be lifespan and pressing hard enough on unsupported fabric. Is breathable vinyl possible? Shiny on one side and adhesive on the other.
    I wonder if using solid color Monkote would work as trim. Much thinner and lighter. To use Monokote as trim you have to heat tack in a million places before an overall ironing. Otherwise it will shrink before it even touches the substrate. This is done routinely on models, Mono over Mono as trim. Would it stick to woven oratex? Monokote sticks pretty well to 400grit sanded wood.
    What's a go-around?
  10. #50
    mike mcs repair's Avatar
    11,773
    Quote Originally Posted by vj88 View Post
    and that's why I only use vinyl for NNumbers (and I've had a few on different airplanes that I had to replace after only a few years...)
    the failure mode is they curl up from the edges... I will post a couple pictures of OLD vinyl failures locally(chugiak), not sure how old they are... (need to remember to take pictures)
    I doubt you save weight using vinyl.....
  11. #51
    gntw's Avatar
    Mar 2005
    159
    I have done 6 rebuild doing 2 super cubs this winter and that is all I use is vinyl numbers and strips.all are on aerothane paint .my cub was done 20 years ago with poly tone and vinyl stripes still looks great has 3000 hrs flying I all weather conditions up to - 35f.shows a little wear good for long time yet.one cub with aerothane all Mose as old less hrs .the 12we did with oretec is first one.
    Likes CharlieN, Backpacker liked this post
  12. #52
    Aug 2011
    Kenai AK
    93
    I have put Vinyl auto striping on my test piece w Oratex, and left out in the weather, 6 months so far - no lift no bubbles
    Oratex makes their own “vinyl” striping and graphics, comes from Germany, and very expensive, but they will do custom.
    Likes Backpacker liked this post
  13. #53
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    220
    Is anyone doing Oratex "commercially"... As in, If I needed my wings rebuilt and recovered, are folks out there using Oratex?
  14. #54
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,978
    I'm sure any good all around fabrics guy would take it on, one who wanted to see what all the buzz was about. They could get educated on the stuff, on your nickel, why wouldn't they? Others, more conservative, may take a pass.
  15. #55
    Aug 2011
    Kenai AK
    93
    There is a guy here in Alaska, Birchwood I have heard, that is covering w Oratex.
    After my experience, I would not hesitate to tell some one they could do it themselves.
    but,
    I would not pay someone to learn on my airplane. It is just too different from “regular” fabric precess.
  16. #56
    11,773
    ..others, more conservative, may take a pass.
    pass!!!!
  17. #57
    Herc's Avatar
    Aug 2014
    Big Lake, Alaska
    127
    Mike, I remember you talking awhile back about someone that covered with Oratex and it was in rags the next season? I ask because I'll be recovering my cub in the near future and am considering Oratex but leaning towards Stitts. Would you elaborate on your observations of the Oratex?
  18. #58
    11,773
    Quote Originally Posted by Herc View Post
    i don't remember saying that.......
    but I much prefer stitts or dope, ZERO chance of me using this
  19. #59
    Herc's Avatar
    Aug 2014
    Big Lake, Alaska
    127
    My apologies. It's been a couple years, must have been someone else.
  20. #60
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,978
    I can for sure see how someone who makes a living using traditional covering techniques, would not take on a Oratex job, why rock the boat? I also know there are shops out there, maybe a bit hungrier, that may be a bit more open to new techniques and material, that would welcome the chance to do an Oratex job. Maybe even at a discount, as it would be understood there would be a learning curve.
    My only personal fabric experience is 100% Stits/Polyfiber/Polytone, 5 planes, and I'm real happy with it. My current 13 year old plane, kept hangared, 2500 hr TT, still looks great with no issues. But I'm also a weight weenie, and saving maybe 15 to 30 (I've heard all kinds of numbers) pounds would for sure make me strongly consider the O option next time. I also don't really care about the cosmetics, more about ease of repair, light of a weight as possible, and longevity, in that order.
    My only first hand knowledge of the stuff is that Hal Stockman, winner of the STOL Oshkosh event this year, and a long time experiential builder and pilot, and a fellow weight weenie, used it, and just said that after a bit of a learning curve (as compared to his previous Stits work) he liked it, and FOR SURE it paid off in the weight department.
    Thanks super stol thanked for this post
  21. #61
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,235
    There is an IA in Wasilla that uses Oratex on his working Cub and installs it. Also an installer I know that does it for a living (has heat gun will travel). While I know both of them, I receive no compensation or perks of any kind by sending business there way. If anybody wishes to contact them, send me a pm.
    "Always looking up"
    Likes bda, Paul Persinger Jr. liked this post
  22. #62
    Aug 2011
    Kenai AK
    93
    Just an update,
    Have 2 years or so on the Oratex fabric.
    Had a bad fuel leak along the way, no damage, but there is a distinct blue stain from avgas, it seems to be fading tho.
    Everything is holding up very well. I did have a few small spots where I did not heat the tape enough to trigger the glue, and they lifted a little, but easy to fix with the heat gun.
    After the initial install, when I wheeled the plane out in the cold the fabric was too loose, it seems that it will only shrink so tight. So I "froze" the airframe and reshrunk when cold as the frame was smaller, it has stayed tight in all temps since then.
    I had a persistant oil leak for the first 10 hours or so, so the belly got pretty oily, no effect.
    I have also had some pretty hard "dings" that left an impression in the fabric that I thought I would have to shrink out, but they tightened up on their own - still not sure how that works. Very sure that one of those would have gone through "regular fabric"
    All in all I am very happy with it.
    It does not have that fancy airplane shine, but I don't wash my plane enough to care about that.
    It is VERY tough.
    I am going to do some mods in the near future that will require cutting and regluing, I will update after thatClick image for larger version.
Name:	beach plane.jpg
ID:	57602Click image for larger version.
Name:	cabin plane.jpg
    Thanks 1934A, tedwaltman1, marcusofcotton thanked for this post
  23. #63
    nanook's Avatar
    Aug 2002
    northern alaska
    1,736
    I wonder if, instead of waxing Oratex, you used Aerospace 303? Maybe someone has tried this, Lars?
  24. #64
    Aug 2011
    Kenai AK
    93
    Nanook, I will try it when I get home.
    The beauty of Oratex is the ability to repair it with out mek and paint/silver/dope etc. You just paint the glue on, let it dry, then heat it up until the reaction happens, and then shrink.
    But
    If there is something weird on there, it can be hard to clean well enough to get the glue to stick. I have heard that the Ceramic coatings are really hard to get off.
    A word to the wise: do not think you will save some money by cutting Tapes out of your scrap fabric. Looks like crap. The Oratex tapes are really good now, and nearly disappear when done correctly. You can hide alot of ugly with them.
    Thanks marcusofcotton thanked for this post
    Likes soyAnarchisto, skukum12 liked this post
  25. #65
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,235
    A word to the wise: do not think you will save some money by cutting Tapes out of your scrap fabric. Looks like crap. The Oratex tapes are really good now, and nearly disappear when done correctly. You can hide alot of ugly with them.[/QUOTE]
    I made tapes once for one elevator and will never do it again. Far too much work and a horrible outcome.
    "Always looking up"
  1. Oratex Fabric
    By FullThrottle in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 10-21-2018, 10:18 AM
  2. Oratex system
    By skysigns in forum Cafe Supercub
    Last Post: 06-16-2018, 11:44 AM
  3. Oratex
    Last Post: 08-29-2017, 06:24 PM
  4. Oratex fabric covering
    By copter86 in forum Member to Member
    Last Post: 05-10-2017, 06:52 AM
  5. Oratex Fabric
    By Roger Peterson in forum Experimental Cubs
    Last Post: 12-25-2015, 08:29 PM
