Update on the Longevity, I have had it on the plane for almost 4 years now - mostly hangered. my test piece has been out in the weather for 5+ years now, rain and snow, and sun.
Fabric on both is holding up really well. I did have another tape peel up, but same as the others, I just wipe w alcohol and add heat and that sticks it down, and it stays down. I used too little heat when I first applied them.
I have had several instances where "an object" has tried to make a new window - bush rash. The worst ones leave a "dent" in the fabric, that is easily fixed with a heat gun, like it never happened. And that right there is why I have Oratex Fabric, so I don't have to start calling the plane "patches" after a few years.
One other thing I have been really happy about is adding inspection holes for maint that I would not have done on legacy fabric because of the time and difficulty. It is just a few minutes to glue a new ring on Oratex and cut it out.
Thre are a few things I would do different the next time.
- Double fabric in the high wear areas - Yes I know I can still do that now.
- be more patient with the Tape install, and order/ install more different sizes of tapes instead of trying to use one size for everything.
- More Aluminum "penetration doublers"
