Results 1 to 23 of 23
Thread: Amphib Gear Maintenance Question
    Feb 2008
    Central Texas
    24
    We are having lots of problems with wheel bearings rusting and wearing out on our Wipline 2100 Amphib floats. We grease the wheels regularly but the bearings are rusting after only about a month of use. The airplane is used for training so we do lots of water takeoffs and landings but very few runway landings. Has anyone else encountered this problem? Is there any type of sealed bearing system similar to what is used on boat trailers? Any ideas, suggestions or recommendations would be much appreciated.
    Jun 2008
    sioux lookout
    544
    Change the type of grease your using? Aerocet has the best system i have seen, very simple and easy to maintain. My c180 on Aerocet 3400a's spends most of it's time in the water and no issues yet.
    10,812
    Quote Originally Posted by kwitte View Post
    I understand that Aerocet has developed a sealed bearing for their amphib floats. Whether they’d fit your floats? I dunno, but it’d be worth a call, I’m betting they’ve had that question in past.
    That said, I operated an amphib Beaver for several years in Kodiak. And, wheel bearings were a regular service item, and were replaced regularly. That said, I think those bearings lasted a couple hundred hours. Also, that airplane was in and out of salt water on many if not most flights. A bigger issue on that plane were the magnesium allow wheels, which needed attention constantly.
    id call Aerocet.
    Apr 2009
    AK
    114
    What grease are you using? Since switching to TRC 880 (Texas refinery Corp.)., we almost forgot what changing bearings was- far superior to aeroshell 22 and most boat trailer/marine greases I’ve used...
    Feb 2008
    Central Texas
    24
    Quote Originally Posted by ak49flyer View Post
    Thanks! I’ll check it out.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    976
    Sorry so late to this thread but here is what I’ve been doing. “Green Grease” is the best I’ve found and listed as a acceptable grease by Wipline. In-expensive and you can get it on line or Walmart. Then drill a hole in the outer seal ( small is the key) , pump a shot of grease in at the end of the day until you see the grease coming out of the hole.that way you always have the grease chamber full, no water. I’m on the second season on the same bearings.
    7,018
    Wip told us to grease them every single time after a water landing. Every single time! Seems to work. Water comes out. Messy.
    Bill Rusk's Avatar
    5,323
    Well......greasing the floats after every landing/day is not always very practical, when on a 3 month float trip in Alaska. That is fine if you leave your hangar.....go fly for an hour or two....then return to your hangar and spend a couple of hours cleaning and caring for the airplane. The Aeroshell #22 grease sucks. I switched to the TRC grease. I'll let you guys know how things look at the end of the summer. Carrying a grease gun, all the grease, a jack (you need to get the weight off the wheels to do a proper grease job), and rolling around on the ramp in Juneau in the rain is just not going to work for me.
    Pictures of my hangar.
    Very Blessed.
    Likes fwSAR liked this post
    7,018
    Keep lots of new bearings? Wip sells "Lake and Air" grease. Messy, but so far original bearings are ok.
    I admit: I don't like working on these things. I have done everything except structural repair, and I avoid them now unless my friends beg. I like my friends, so begging works. But once down there, how do I get back up?
    Jun 2008
    sioux lookout
    544
    Aerocets are like doing the lower unit fluid in your outboard, all sealed and use engine oil to lube the bearings. best system i have seen.
    Bill Rusk's Avatar
    5,323
    I have tried, repeatedly, to get Tom at Aerocet to make an amphib float for supercubs at 22 to 2300 pound gross. He says there’s just no profit in it. Too bad, I would love to have a set of Aerocets, but the Wips have been great so far and I’ve not been gentle or easy on them. But.....so far I have had to replace the wheel bearings every season.
    Very Blessed.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    976
    Well Bill when in Alaska do what we do , put the gear down and jump in and grease it. The cold water is mind over matter,lol. You can only do what you can.
    Likes Bill Rusk liked this post
    Jun 2008
    sioux lookout
    544
    did the same when i was shopping for my sportsman, i got the same answer. Kinda surprised Montana Floats didn't adopt the system as they seem to share a lot of parts. I believe Keith at Montana actually came up with the gear selector/advisory system Aerocet uses.
    9,970
    What is the part number of those bearings and races? Is there a C at the end of it? The C indicates that it is chrome plated and less susceptible to rusting. Also it is a lot more expensive.
    9,265
    Quote Originally Posted by Bill Rusk View Post
    How many landings a month do you do on salt????
    Ok, most has been covered. Better grease, and develop a method (like the hole for needle grease gun) to grease daily if you are doing lots of landings. If flying salt, fresh water rinse at the end of each day!!
    7,018
    I suppose once a year is expensive - are you getting the bearings from Wip?
    We found Scott wheel bearings for ten bucks each a while back at the NAPA aviation dept. They didn't say Scott - they say "Timken".
    I believe, but am not sure, that Grove makes the Wip wheels and brakes.
    Thanks Gordon Misch thanked for this post
    Likes Gordon Misch, aktango58, Bill Rusk liked this post
    3,563
    Is it possible to use boat-trailer spring-loaded grease adapters? The ones that you pump up prior to each launch, that push the water away?
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    646
    You’re talking about the bearing buddies right? Interesting thought! I haven’t worked on floats much. Just a little bit on whips on a 180 and Caravan. I don’t remember the exact layout. Might be able to do some type of STC.
    Apr 2017
    ND
    131
    Bit different operations, I fly once or twice a week, fresh water only, airplane sits in a hangar most of the time when not in use.
    I switched to “Green Grease” a few years ago, cheeper and easier to find than Wip’s special grease. I repack at the end of every season. I replace the keepers and drill the, I think #50 bit, hole in the “O” in the word NATIONAL in the outer (per Wip), opposite of brake side, keeper then fill with green grease. Green grease is thick, and I seldom re-service, doesn’t leach out like lighter greases.
    Two years ago, while repacking, I dropped one of my bearings, and it got a bit deformed, so I had to replace it. I found out that my bearings were at least 7 years old according to the manufacturer because they no longer made the stainless version that I had. I’ll see at the end of season 3 if there is a shorter life on a regular bearing.
    Ps. If grease is leaching out of the wheel rim holes, you need to replace the pvc inner spacer.
    Bill Rusk's Avatar
    5,323
    Resurrecting an older thread.
    Folks
    I thought I would bring this thread back to life so that if someone is searching for maintenance tips on Wip floats I might be able to help.
    Get your bearings from Summitracing.com. Same quality (Timkin) but much cheaper than most other suppliers.
    The TRC grease mentioned above is excellent. It makes a difference what type of grease you use.
    Here is a link for a "How to Rebuild Wip Amphib Floats" post
    https://www.supercub.org/forum/showt...l=1#post764992
    Hope this helps
    Very Blessed.
    Likes Idleclamp liked this post
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    976
    Hi Bill, hope you have a good season. I just did the annual on the Wip 3000’s we have on a M-7-260 Maule and the bearings were just fine. I did the drilling the outer grease seal on both mains ( about 3/16 or smaller) and went to “Green Grease” from Walmart. It’s listed on Wipline web site. Pump grease in until it comes out the little hole. Did it about once a month. All fresh water. This is the first year all the bearings were good. Note ; the seals are different sizes and can be damaged taking them out for maintenance, so keeping a couple of extras doesn’t hurt.
    7,018
    I think I heard you run grease through them after each day of water landings.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    976
    Try too but the boss doesn’t but has worked very well with the green grease
  1. Otter amphib gear down video.
    By pzinck in forum The Art and Science of Flying
    Last Post: 05-26-2010, 02:37 AM
  2. Want to Trade - 31" Bushwheels, ext gear, etc to Amphib
    By bwinston in forum Products, Purchases, Reviews & Prices
    Last Post: 11-28-2007, 09:42 PM
  3. amphib 160hp question
    By freestone in forum Cafe Supercub
    Last Post: 11-05-2005, 10:55 PM
