Results 1 to 6 of 6
Thread: Belly Pod Attachment - Is quick release latch available???
    Oct 2018
    NE Pennsylvania
    1
    I'm new to the SuperCub group. Currently in the process of recovering my PA-18. It has the Airglas Belly Pod. Is there an option that could be installed on the straps that attach the pod to the belly making a quick release system for when the belly pod is not needed? It would be a nice option to be able to put it on or take it off as needed.
    Marty
    10,572
    They come off easy anyway. Going back on take a couple minutes more.
    Dec 2016
    Canyon, tx
    447
    Weld rear tabs on the fuselage if you haven’t already. I’ve spent as much time fishing the hangers out of the belly as I have putting the pod on.
    Likes RaisedByWolves, wireweinie liked this post
    spinner2's Avatar
    Montana
    1,742
    This is for the rear pod-attach strap.
    Behind the fabric clamped to a tube. This is a structural clamp with a tab welded onto it with a 10/32 tapped hole to accept an AN3 bolt.
    The front strap shouldn't be an issue if it is using some type of tab off of the rear gear bolt.
    18,952
    That's what you get for gettin' that purty Cub. My holes are big enough that it is a none issue now. Can have it on or off in 15 minutes or less.
    Dec 2016
    Canyon, tx
    447
    I’m guilty of thinking that every hole should be tighter than a mouse ear. Now that I’m older, I have grown to appreciate the ease and convenience of a larger hole
    Thanks irishfield thanked for this post
  1. Looking for Schweizer tow release
    By RAC cubs in forum Cafe Supercub
    Last Post: 02-15-2010, 04:11 PM
  2. ECI oil filter adapter quick drain, quick ?
    By 68D in forum Modifications
    Last Post: 03-18-2008, 05:48 PM
