Did anything else smoke or just the battery? Cables, relays, etc?
Reading Cathy's response to Stewarb's email; Wow! that's some serious faa lawyerese! In the event your reg fails . . . then your over voltage protection fails . . . and then the battery receives over 100 volts . . . and you fail to manually take the alternator offline . . . this CAN produce enough energy to induce a thermal runaway.
Now, I'm a big proponent of redundant systems, especially with regards to personnel and equipment safety, but how many layers do you need?! The typical charging system on a small aircraft already has redundant safety measures built into it. First off, an ammeter or voltmeter is required so that the system can be visually monitored. The generators and alternators both have breakers that open the output and/or field power circuits if they sense high current flow. And, finally, the regulator power circuit is run through one pole of the typical two pole master switch so that, when the master is shut off while the engine is running, the charging system cannot self excite. Bonus points if you have over/under voltage lights either in your volt/ammeter or connected to your regulator. AND, some manufacturers like Cessna use a stand alone over voltage module inline with the regulator power circuit. Then other manufacturers come along and build voltage protection into the reg itself.
NO BATTERY will with stand the circumstances described in Cathy's response. At some point the operator has to take control and isolate the problem, it can't just be 'ruled' away. Turn off the charging system when you see and over voltage or excessively high current flow. Or maybe when the light comes on to alert you. Don't keep operating with the above conditions present. Don't override circuit protection systems. At what point do you stop blaming the equipment design and just say 'I should turn it off'?
I'm still a fan of EarthX and I'm still installing them. I would like to hear about the Birchwood battery incident, however. Stewartb, could you share the details of this? If you want, PM or call me.
Web, is it possible for a failure in a system to put out 100 volts? Seems like a big number to me.
and then the EarthX BMS is the recipient of over 100V
http://www.matronics.com/aeroelectric/articles/Alternator_Failures.pdf A generator will self excite. An alternator will, should, not. You need to know your system to know what should happen when you dump the field or master switch during a runaway event.
Credit to Bob Nuckolls of Aeroelectricdotcom
An alternator will gladly put out more than that. The output is based on the field voltage... when regulator is functioning that’s less than half buss voltage. But when regulator fails it may put full buss voltage to field. So it just keeps increasing. Other styles of alternators grounds field to excite it, this style can run away because field wire get damaged and hits/rubs threw to a ground...
Technically it's the current that controls the output. But that's just semantics because higher voltage is needed to increase current flow.
Current flow through the field coils produces a magnetic field. In an alternator, these coils rotate with the shaft/pulley. This means that the magnetic field moves over the output coils to produce power. The regulator samples the output voltage and controls it by adjusting the current flow through the field. In an alternator there is no max current output limit as the output coils of the alternator begin to interfere with each other when you reach rated max current output. So if you had a thirty amp alternator and tried to get it to put out forty amps, it just won't do it. If you keep increasing the load above it's max, the voltage out will start to drop and no higher current out will take place.
Under normal conditions, when you measure the voltage at the field terminal on the alternator, it will NEVER equal bus voltage, even with power to the reg and the engine not turning. I can't vouch for other brands, but the Motorcraft system on the Cessnas usually read between two and three volts when the engine is running. That's all the voltage needed to produce enough current (amps) to start to recharge the battery and run a few lights.
Now imagine a scenario where full bus voltage is connected directly to the field terminal. With the engine running this would be 14.2 volts. And as the output voltage starts to rise, this means the voltage measured at the field terminal also rises. This scenario is a true 'runaway' charging system. The total voltage out will also be exacerbated by the speed of the alternator (engine speed). So if you pull back on RPM's the voltage will not rise as fast/far. But that's just temporary in a true runaway.
Unlike automotive alternator systems, aircraft alternator systems use external power to supply the regulator. This is why power to the regulator power comes from the bus bar, through the field breaker, through one pole of the master switch and THEN to the regulator. This way pulling the field breaker OR placing the master switch off will remove power from the regulator and prevent any further output from the alternator.
I've never rigged one just to measure the voltage, but if it did get that high, I can't imagine the alternator would last for more than e few seconds.
The regulator would have to be completely bypassed and the RPM of the alternator would have to be as high as possible.
Is it time to mount batteries in an external pod maybe under the gear cabane?
Why not add a temp probe to the battery if that's a concern? Just another gauge or caution light to monitor.
https://earthxbatteries.com/shop/5mm-led-fault-light-panel-mount-indicator
