Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
Thread: Worth Checking the CO
  1. #41
    Aug 2015
    MA & ME
    395
    BW Technologies GA24XT-M Nice auxiliary warning
    I buy one of these every 24 months. They are accurate (compared with handheld meter) and the alarm can be heard in spite of cockpit noise and noise canceling headsets. Also has flashing led alarm signal.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  2. #42
    Tom3holer's Avatar
    May 2012
    Cape Cod
    448
    In reading the manual I see the battery is replaceable and they are available for less than $5 on ebay.
    I wonder if the calibration is really needed as these are certainly far more accurate than the stick on patches.
  3. #43
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,550
    The new mufflers came with snacks!
  4. #44
    18,653
    Cracker Jacks for a Cracker.
    Likes mike mcs repair, RaisedByWolves liked this post
  5. #45
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    654
    Now look here, Jack
  6. #46
    Cubus Maximus's Avatar
    1,802
    Got the headache this day:
  7. #47
    sjohnson's Avatar
    Boise, ID
    663
    I use this device. Seems to work well.
    Available on Amazon.
    $99 3 yr life
    Attachment 41315
    I bought this, and unfortunately, it worked. It alarmed, showing about 15 ppm during initial climb, then decreased to zero during cruise. I have a Cub with an Atlee Dodge hot rod muffler. I suspect exhaust coming in the door. Anyone else with this experience?
    Idaho drinks more wine per person than any other state in the country.
  8. #48
    Tom3holer's Avatar
    May 2012
    Cape Cod
    448
    Can someone explain the life cycle of these devices?
    They say 3 years and I see some actually have a built in clock. So will that make them inoperative when the time runs out.
  9. #49
    Vermont
    228
    Smoke detectors work by either a change in ionization or light thru the smoke. CO detectors are chemical, just like the brown dot types. They do quite well lasting as long as they do.
    What's a go-around?
  10. #50
    Jan 2005
    Fowler, Ks
    525
    Quote Originally Posted by Tom3holer View Post
    Yes I had a drager and after 750 days it won't read CO.
    I bought a new one $200 and checked the CO in the cub yesterday. Normal cruise the reading was averaging 12ppm. I pulled cabin heat and the reading went down to 10 ppm, likely due to more flow of air thru the cabin..?
    I reduced power to 1700 rpm, flying tail low at 55 mph for a few minutes and the reading dropped to almost zero at times.....thinking my CO is entering at the tail like MTV mentioned and when the tail drops below the stream of exhaust my numbers come down...not sure. I didn't think of 'standing' on a rudder to see if that would also make a difference.
    I will look into sealing the tail area and see what the numbers do.
    I took the RV8 into Wichita a couple days ago and while taxiing with a tail breeze the numbers came up to 25-30 ppm but once i got to rolling for launch the numbers went to zero and stayed there the entire flight.
    Steve
    (thanks for starting this thread)
  11. #51
    Meanwhile,...
    5,002
    I have this deal in my 180, shows 20 in a hard climb, 14 in cruise but goes away if I open the side vent a bit. Same with the heater on or off, so I ordered a tail pipe extension from Texas Skyways, now I just have to convince myself I can put that round hole extension over the oval tail pipe and get it to seal up without a bunch of tape.
    In the cub I have the CO probe (located under the panel) on the CGR 30 and with the AD Hot Rod exhaust it would show a bit, especially in a climb, changed to Sutton with the longer tail pipe for other reasons and have never had anything above 1 since.
  12. #52
    May 2012
    35
    Are the readings in your 180 with cabin air on or off? What exhaust do you have?
    I had about the same readings in my 180 with stock exhaust. I Pponked and put a new AWI exhaust on and my readings are zero.
  13. #53
    Meanwhile,...
    5,002
    The exhaust is Kinsley and the muffler is pretty new. The readings were cabin air off (it was bloomen cold) and with the heater on or off. Went away with cabin air on about 1/4” of the vent open. There is exhaust staining trailing back from the cowl flap and wrapping up to the bottom of the passenger door making me suspect the door seal. We put this deal on this morning that should get the exhaust further out but it’s too gooey today for a flight. Click image for larger version.
  14. #54
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,411
    Please post the details about the extension.
  15. #55
    Meanwhile,...
    5,002
    https://www.txskyways.com/products
  16. #56
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,411
    I found that but there is only a photo. No additional info.
  17. #57
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,411
    What is the panel on the side of the cowl for?
  18. #58
    Meanwhile,...
    5,002
    Winter covers over the “Gill Vents.”
  19. #59
    Meanwhile,...
    5,002
    You have to call them, basically it is an STC’d ceramic coated elbow/extender. You remove it to pull the lower cowl.
  1. Checking in...
    By Beach Bum in forum Cafe Supercub
    Last Post: 08-03-2011, 10:06 PM
  2. Just Checking In
    By RobW56 in forum Cafe Supercub
    Last Post: 08-17-2004, 09:13 AM
