Mauleguy
MEMBER
GregI would like to use earth x but I am worried about having it inside the cockpit. I currently have it mounted on the firewall cockpit side. I was reading on EarthX web site they don't recommend having it inside.
It might be a few weeks but I will get some video and post it on Youtube.
Mauleguy, Is there a back seat which plugs into the baggage door when it is closed? Your plane looks great.
What material and thickness did you use for your flooring and siding?
Yes, it has a rear seat like the Maule for two passengers. I moved it forward around 7" from the stock position of a Maule. The passengers would get in the front doors now from either side and there legs when seated would go up to the main structure cross bar. It actually gives them more leg room then a stock Maule. I have not had it in since I did the fuselage build up but the wife will get a ride soon. I have about 7 hours on it now so still getting use to it but for the most part it feels like a Super Cub. The visibility is much better than my Super Cub both landing and taxing on the ground.
View attachment 41333that is all I have right now
