Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
Thread: General C180 questions.
  1. #41
    Aug 2015
    Indianapolis
    134
    There’s a guy named Guy Ginbey who’ll make a silicone duplicate of any rubber part you send him. Great stuff at a great price. Google Gee Bee Aeroproducts. He doesn’t have a website, but sells through links on CSOBeech.com. Or you could join Beechtalk and PM him there.
    No connection. Just a customer.
  2. #42
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,475
    Do you mean a silicone mold?
    Quote Originally Posted by StuBob View Post
  3. #43
    Aug 2015
    Indianapolis
    134
    No, he makes parts of silicone rubber, if I understand correctly. I bought gas cap gaskets from him. They were blue, rubbery, and perfect.
  4. #44
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    335
    Thanks. I've bought a number of scat type hoses off Guy Ginbey on a Bonanza reno project before. Fantastic gear and Guy's very passionate about his gear. (you do have to push through the cryptic message pain sometimes, but well worth it)
    Thanks Eddie. I had looked at A/S site but hadn't had your success.
    On another note bloody aeroplanes consume a lot of money.
    A few weeks ago I ask a guy I know to look at the gyro driven AH and DG. Got them back with $2800 worth of work and bearings/gimbals. I guess not bad considering they're 45 years old.
    I had my engine mount blasted, and anywhere it's close to the exhaust, it's badly pitted. So it'll be off to the welder I guess.
    The moto of one of the many schools I went to was 'onwards and upwards'.
  5. #45
    G44's Avatar
    Oct 2011
    SW Michigan
    473
    Quote Originally Posted by ridiculousness View Post
    Fine Wire plugs are an obvious way to go as far as spark plugs. I have only ran slick Mags and don't change them very often... usually once maybe twice we change a left mag on an IO-540 in the 2400 hours we run them. I bought a Factory New O470-R it came with Slicks. I am going to switch to fine wire plugs at 500 hundred hours but wouldn't think twice about switching to Bendix mags, just because they are easier to rebuild.... it sucks to have to rebuild any mags but its part of owning an airplane you fly enough you will have an issue with a magneto at some point. If my engine came with Bendix Mags I wouldn't switch them out either.... so run iridium spark plugs and overhaul your mags with the motor who cares what brand they are.
    What ever you decide to run just make sure they are Tempest and not Champion.
    Thanks ridiculousness thanked for this post
  6. #46
    Feb 2002
    don
    723
    Looking to buy real nice Cessna 180. Everything looks good except some minor corrosion on bottom of upper wing skins. Minor that you can see some discoloration but can't feel it. Looks to have been treated. Moving it to Southern Idaho from Seattle area. Living where I do corrosion is usually not a problem. I know it won't heal but would I expect it to get worse in this dry area?
    Don
  7. #47
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,475
    No
    Quote Originally Posted by don d View Post
    Don
  8. #48
    Meanwhile,...
    5,107
    What do the insides of the wings and every else look like, does it have the seal plane kit with treated insides? My bird had some minor belly corrosion from a past life on floats that was treated and spot painted and if all else is good I wouldn't be that worried.
  9. #49
    texmex's Avatar
    Aug 2008
    335
    Hello All.
    My C180 tidy up is continuing. Engine is back and looks flash. Windows are out.
    The Nuffties who put on the Tanalian tailplane leading edge did so and then painted it. So there was corrosion between the leading edge and tailplane. Off it comes for a full strip and repaint. Tail is off and hockey stick STC mod is done.
    New titanium saddle and tail gear spring from 'The Landing Gear Works'. Plus an upgrade to 10" tailwheel fork.
    One new aileron hinge and all new control cables. I mention this as I installed it only a few weeks ago, and now McFarlane tell me that particular aileron hinge has a service bulletin out on it.
    But progress is slow, as I work full time and raise a family.
    So the pressing question I have now is, would someone be able to send some photo's of the dash eight fuel line coming from the firewall, passing through a JPI transducer into the carburettor? The line is short. Reading the blurb on the JPI side they say there should be six inches of line either side of the transducer. JPI answer emails promptly, but strangely don't have any photos to show of their FS450 fuel flow gauge set up.
    This is for a normally aspirated O-470 in a Cessna 180.
    Many thanks,
    Texmex.
    Photo's to come when I'm off the kids super slow desktop and on my new laptop in 6 weeks.
  10. #50
    2,680
    Not sure if pics will help much. It's just a couple of hoses connected to a block of aluminum.
    Use 'Mounting procedure 700923' in the install manual. It's easiest if you can fabricate your own hoses as you'll want to keep them as short as possible and it will be easier to figure lengths as you assemble them. Two rules for their transducers to keep in mind: the wires always need to point up and the the transducer needs to be lower than the carb inlet. If you cannot keep the transducer below the carb inlet, you'll need to put a 'hump' up in the line from the transducer to the carb. Either of these steps will help keep air bubbles out of the transducer. JPI wants at least two inches of straight leading to the inlet of the transducer. This means no 45* or 90* fittings on the inlet, straight fittings only. Other manufacturers recommend straight only on inlet and outlet so keep that in mind when making the hoses.
    When I install these, I try to keep the hose from the gascolator to the transducer as short as possible. Then figure out how much hose is needed to route from the transducer to the carb inlet. Cover the transducer with fire sleeve and secure it with metal bands. I like something removable 'just in case'. If you need to, use some adel clamps to secure the assembly to the engine mount. Just be aware of the movement of the engine in the lord mounts; there needs to be some flex in the hose or engine movements will wear the hose/fittings. And make sure the fittings installed into the transducer are steel not aluminum.
    Likes FdxLou, texmex liked this post
  11. #51
    4,944
    The only pic I took was to document the factory K factor, which was way off from where it is on my airplane.
    A bit of advice about the FS-450. Get in the habit of noting your total fuel quantity before you add more because I promise you you'll occasionally hit the buttons out of sequence and it'll indicate full tanks. I usually add 10-20 gallons and rarely fill mine. I can't count how many times I've hit those damn buttons wrong. Deleting fuel is a pain, especially from 75 gallons down to 25-30 gallons. Great instrument but now days I review the instructions every time before I touch the add fuel function! The good news is I can calibrate my FS with my fuel dip stick. My dip stick is still my best fuel gauge.
    Likes texmex, RaisedByWolves liked this post
  12. #52
    Nov 2017
    Vermont
    16
    Ran the new teflon hose to the left side for a better fit:
    Likes texmex liked this post
  13. #53
    texmex's Avatar
    Aug 2008
    335
    Many thanks to all.
  14. #54
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,475
  15. #55
    FdxLou's Avatar
    Apr 2004
    1,793
    Eddie
    Did you add Fire Sleeve after you took this picture?
    Lou
  16. #56
    4,944
    That's a gold cube from EI, right? My cube doesn't require fire sleeve. JPI's transducer does.
  17. #57
    Meanwhile,...
    5,107
    Eddie, that's a nice free flowing install, ought to have a good chance at being accurate and repeatable. Only comment is unless that strap around the engine mount is padded you might add some chafe tape under it.
  18. #58
    2,864
    ….. My dip stick is still my best fuel gauge.
    I dip my tanks after every fill-up, write down the tach time & fuel on board on a piece of blue tape & stick it on the panel.
    I can predict within a gallon where my fuel level is after a flight.
    Never saw the need for a fuel totalizer.
    And other than setting up fuel injectors or similar,
    never saw the need for a fuel flow gauge either.
  19. #59
    4,944
    I diagnosed a subtle carb issue with my FS-450. That alone made it a good addition. These days I lean by it. Simple and quick. I trust it more than my digital fuel gauges.
    Likes OLDCROWE, CamTom12, windy liked this post
  20. #60
    Jan 2016
    Vancouver, BC
    7
    I've heard that before, but never understood why. What about the fittings at the gascolator and carb...should those be steel too?
    Chris
  21. #61
    2,680
    JPI's specification. Probably so the threads don't gall. Shouldn't be for strength as all manufacturers warn against hard mounting to the gascolator or carb. I've seen aluminum, steel, and brass used for the hoses. Never had issues bit I always use thread lube on them. Most engine guys demand steel fittings on the accessory case for oil lines, to prevent galling, so maybe I SHOULD think about steel on the gascolator and carb.
  22. #62
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,475
    https://www.griplockties.com/
    Patey magic!
    Likes RaisedByWolves, OLDCROWE liked this post
  23. #63
    2,864
    Quote Originally Posted by texmex View Post
    Hi guys. I'm about to pull the engine out of my C180J. Along with the windows / windscreen. And dash. Where does it stop? ….
    So, a year later, I was wondering if you'd care to comment on your original question?
    Also, if you'd care to offer your opinion(s) on what you'd do differently,
    or recommendations to others starting down this road on what to do and what not to do.
  24. #64
    texmex's Avatar
    Aug 2008
    335
    Nothing enlightening. It’s been a bit of a slog. You can only spread yourself so thin. Busy at work, rural property to maintain, children to feed and educate. At the start of this my wife went back to work 4 days a week, for the first time in 25 years. That’s definitely a good thing the amount these aircraft cost, but it has slowed progress.
    One thing I significantly underestimated was the time spent in manuals, IPC, Genuine and Spruce finding parts and ordering bits. There is as much time doing such as actually putting spanners on the aircraft. And how does a shop pass on those expenses? Taking your aeroplane, car, boat or whatever to somebody that knows them intimately would help.
    I also underestimated the cost. But I guess everybody reading this has done the same before.
    On the positive, my 180 is in my hangar located behind my house, so no large hangar fees or time limits. And I’ve had some brilliant engineers come to me and help, as they live nearby. Technically I’m a licensed LAME, but working with these guys I realise what an amateur I am. The electrical man by day wires up helicopters and then swings by my place after work and is completely re-wiring my C180. And doing a fabulous job. So I’ve been very lucky.
    One area I thought I’d leave was the tail section. But then I found corrosion and also a Cessna service kit for the fin not done which requires more frequent SID’s inspections. So off comes all the tail section. I then found the hockey stick holes badly worn (which in reference to another post on such, would be undetectable without removing the stab) and I chemically stripped the tail gear spring which was not the correct thing to do. So from not intending to touch the tail, I found myself down a 11 k USD hole. Where does it end ��
    Oh, dare I mention the crappy currency I earn. From parity a few years ago, I now need to spend $1.50 for every mighty USD. That hursts.
    But no regrets. Popular opinion has it that you only live once. And I think a Cessna 180 should be in that life. I want to take my family away flying and therefore want it right. I pranged one of my fathers Ag Cats when I was 18 mishandling a minor mechanical defect, and I guess that possibility effects my desire to have my aircraft in good order. Or I’m just fussy.
  25. #65
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,475
    TexMex,
    I feel your pain. I spent 14 months and approximately 1100 hours redoing my 180. I am now on Spruce's Xmas card list. My reward? A light, great flying 69 180.
  1. C180 questions.
    By texmex in forum Cessna: C180/C182/C185
    Last Post: 09-09-2016, 12:03 PM
  2. C180 questions.
    By texmex in forum Cafe Supercub
  3. New C180 Owner - Few Questions
    By irishj3seaplane in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 04-05-2008, 01:34 PM
  4. Super Cub general questions
    By tgarrison in forum Cafe Supercub
    Last Post: 02-14-2005, 08:14 PM
