Results 1 to 11 of 11
Thread: Inspection cover buttons
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    Anyone have a part number or source for the buttons that secure the nspection plates in the floor on a 180.
    Jun 2013
    20
    S1878-1
    Thanks Eddie Foy thanked for this post
    4,927
    2,857
    Those'll come in handy.
    I'm up to about a #14 screw in some of the stripped out screw holes.
    2,857
    I took a count yesterday, I need 40 of them not counting the rectangular inspection cover aft of the flap tunnel.
    At 80 cents each for those Cessna studs, that's $32. Whew!
    That's almost an hours worth of mogas.
    Guess I'll stick with the stripped out screws until I can find a cheaper substitute.
    4,927
    The rectangular cover is the only one that's supposed to be screwed down.
    How much does your IA charge you to remove all those screws rather than just popping the covers up? False economy.
    Likes OLDCROWE, Steve Pierce liked this post
    Jul 2010
    Elizabeth, WV
    549
    I have found Cessnas with short machine screws and even nails with the shanks cut short in the floor. If carpet covers them and keeps them in the hole they work as well as the buttons that are a loose fit. Look closely under the floor in all the corners and you might find most of those that are missing.
    May 2017
    567
    You could try McMaster Carr 9563K81 1/8 nickel plated plug. Not sure if they would fit, but worth a try.
    2,857
    I'm gonna take a wild guess that my IPC will show those inspection covers being screwed down.
    As to false economy, I'm the one that removes all those screws at annual time.
    Like I said, I'll search out a less-costly solution.
    Mar 2018
    97
    No, IPC shows the 49330 studs for the floorboard plates. That stud p/n is superseded by S1878-1. The external inspection plates are secured by screws.
    2,857
    Just came from the airport, where I checked my IPC...
    yep, p/n 49330 stud, tri-mount.
    I stand corrected.
  1. Inspection cover help
    By slowmover in forum Super Cub Sick Bay
    Last Post: 08-31-2009, 12:02 PM
  2. inspection cover grommets
    By jr.hammack in forum Modifications
    Last Post: 02-12-2007, 07:31 AM
