Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: 0-320 hp upgrade
  1. #41
    Nov 2017
    146
    Quote Originally Posted by barrie View Post
    I was stupid enough to file the required Major Modification report. The engine type is noted on the C of A so I didn't have much choice. The moral of the story is stay with the same type of engine.
    I hope you can succeed with them and be ready for the float season this spring! Hang in there!
    All the best.
  2. #42
    9,625
    barrie, I've been following your travails, yet I'm still confused as to what type of basic airplane that you have. When you say C-120, do you mean Cessna 120 on which you have installed a Subaru and have now changed to a 0-320?
  3. #43
    2,839
    Quote Originally Posted by RoddyM View Post
    Fair enough. How did Transport find out about the engine switch though?
    There's a guy here at my airport who switched from a ground-adjustable Sensenich prop to a Catto prop on his RV12.
    Talking to him yesterday about it, I was surprised to hear that he had to go through another period of "phase one" flight testing.
    Fool that I am, I woulda thought you could just hang the prop on there, sign it off (as the aircraft repairman) in the logbooks, and go flying.
  4. #44
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    705
    Yeah, but the additional phase 1 is very limited - like 5 hours or something like that. I think it’s meant to require flight testing on engine/prop combinations that may not have received formal testing (like in a TC or STC process).
  5. #45
    barrie's Avatar
    Jan 2019
    24
    It was a Cessna 120 with a whole lot of modifications. But, yes it is basically a 120 as far as the configuration is concerned. It initially had a Subie EJ22 160HP which worked very well; but due to hot start issues (especially on floats) we converted to the 0-320.
  6. #46
    9,625
    Thanks, Are you on EDO 1650s or some other type of floats?
  7. #47
    2,839
    Quote Originally Posted by GeeBee View Post
    If it is certified, you need an STC for the engine because you need authority to change the data plate. You can get that from LyCon. ….
    Not sure which model engine you have,
    but Art Mattson had an STC to convert the E2A from 150hp to 160.
    http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgstc.nsf/0/824317613f8458ad86257ed2004ebf70/$FILE/SE367CH.pdf
    as well as an STC for the installation of that modified engine onto a Cherokee.
    Looks like someone acquired Art's STC's after his death.
    https://www.aviationpros.com/press_r...ne-of-faa-stcs
  8. #48
    barrie's Avatar
    Jan 2019
    24
    It's on EDO 2000's with an 1850 lb. gross. Works really well.
  1. !50 hp to 160 hp upgrade
    By cub_driver in forum Cafe Supercub
    Last Post: 03-13-2009, 09:58 AM
  2. Upgrade a PA-18 to a PA-18-150
    By bob turner in forum Tips and Tricks
    Last Post: 02-11-2006, 12:32 PM
  3. C65 to C90 Upgrade
    By Lost Coast in forum Cafe Supercub
    Last Post: 11-24-2004, 11:10 PM
