I converted a 1959 Cessna 150 to an O-320 with the Delair STC back about 10 years ago. Was helping the owner change the vacuum pump the other day and I believe the cowling is still off if you need pictures.
Odd the “stop flying” came after the switch to a real engine from the Soob?? Transport has a lot of experience with standard aircraft engines, so the MDRA office’s appointed inspector should easily be able to say “this is the info we need.” Then you get that info to them. The MDRA’s inspectors are looking for safe properly built stuff. (There is something they don’t like about you’re engine change out). Ask them to tell you what it is specifically.That's right Hotrod,
These inspectors know very little when it comes to home-built aircraft. They are attempting to apply certified rules and all that I can do is try to comply as best as I can.
I guess I don't understand what the issue is?
It might be easier for others to contribute helpful information if you'd give us a better picture of what you're trying to accomplish.Sounds like......you have an experimental C120 which you pulled a Subaru engine off of, and installed a 160HP 320--
And now you need to document approval of converting that 320 from 150 to 160?
MD-RA loses control after the initial 25 hrs. is flown off. After that we are at the mercy of the regional TC airworthiness inspectors. The conversion is properly done and there's 60 hours on it. This is just a paperwork thing that has gotten out of hand.Odd the “stop flying” came after the switch to a real engine from the Soob?? Transport has a lot of experience with standard aircraft engines, so the MDRA office’s appointed inspector should easily be able to say “this is the info we need.” Then you get that info to them. The MDRA’s inspectors are looking for safe properly built stuff. (There is something they don’t like about you’re engine change out). Ask them to tell you what it is specifically.
Fair enough. How did Transport find out about the engine switch though?MD-RA loses control after the initial 25 hrs. is flown off. After that we are at the mercy of the regional TC airworthiness inspectors. The conversion is properly done and there's 60 hours on it. This is just a paperwork thing that has gotten out of hand.
I hope you can succeed with them and be ready for the float season this spring! Hang in there!I was stupid enough to file the required Major Modification report. The engine type is noted on the C of A so I didn't have much choice. The moral of the story is stay with the same type of engine.
There's a guy here at my airport who switched from a ground-adjustable Sensenich prop to a Catto prop on his RV12.
Talking to him yesterday about it, I was surprised to hear that he had to go through another period of "phase one" flight testing.
Fool that I am, I woulda thought you could just hang the prop on there, sign it off (as the aircraft repairman) in the logbooks, and go flying.
barrie, I've been following your travails, yet I'm still confused as to what type of basic airplane that you have. When you say C-120, do you mean Cessna 120 on which you have installed a Subaru and have now changed to a 0-320?
If it is certified, you need an STC for the engine because you need authority to change the data plate. You can get that from LyCon. ….
It's on EDO 2000's with an 1850 lb. gross. Works really well.Thanks, Are you on EDO 1650s or some other type of floats?
