Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: How would you retrieve a cub fallen through the ice?
  1. #41
    3,147
    During the late 80s a 185 with a brand new set of hydraulic wheel skis went to the bottom of Two Lakes when the pilot needed a pit stop after having been told by his boss not to land on that lake. That lake is known for having thin spots in the middle of the winter. As far as I know it is still there at 190 feet. I found it with a side scan sonar. It is right side up facing north out near the middle.
    Years ago, one of our local pilots (Cliff Larrance) heard about a Grumman Widgeon which had been been sunk in Tin Cup Lake , up in Yukon Territory.
    He made several trips up there in his float plane-- over time, he located it on the bottom, snagged it, and winched it out.
    His original plan had been to fly it out, as s
    upposedly it had been scuttled for insurance purposes & was undamaged.
    Nope, it was pretty beat up, so he had it hel
    icoptered it down to the nearest road & onto a truck to haul it home.
    He was a busy guy, a hard worker who owned a couple businesses,
    and he never did get around to restoring it before he passed away at the young age of 55.
    Sadly, 15 or so years later, I just saw in the newspaper that his widow (age 57) just passed away also.
    Thanks vj88 thanked for this post
  2. #42
    Apr 2011
    Western PA summer, daytona winter
    42
    Rick Fryeburg at SUBSALVE USA. (401) 884-8801 His enclosed salvage lift bags will lift 62 pounds for every cubic foot of air pumped into it. A standard 80 cubic foot scuba bottle will lift more than 2 tons in shallow water. With a bit of effort the smaller bags could be placed in the fuselage and some smaller bags under the wings and secured by the struts. A small gasoline powered compressor like those used for nailguns etc will certainly sufficient air. Grain sacks wilth garbage bags inside and filled with air have been used. One fellow I knew in the early 80s lived on a sailboat he raised with plastic milk jugs taken in to the cabin and partially filled with air, the water pushed out by partially collapsing the jug and capping it to counteract the air expansion from the reduced ambient pressure as it got near the surface.
  3. #43
    Jul 2010
    Elizabeth, WV
    583
    Another thought I had the other day was to take some type of inflatable bag, slide under the wing deflated then inflate. Would work like a jack but reduce the amount of damage. Now, finding two large air bladders...[/QUOTE]
    The towing companies that handle big rigs use airbladders to get trailers back upright.
    https://www.youtube.com/watch?v=VX__8NE_s3Q
  4. #44
    10,344
    What a small World! That man called me up one day to talk about raising sunken airplanes. I had a sunken Sikorsky S-39 which I was working on and he heard about it and the T-50 on floats which I also had. He told me that the Widgion had broken off it's bow in the classic Widgeon style which was the cause of the sinking.
  5. #45
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    778
    [QUOTE=mike mcs repair;736686]No. I like it. Put something on fuselage at lifting eyes to take some of the load and act like a ski. Wings would spread load out nice. Upside down plane don’t necessarily get hurt bad. Had one that didn’t even dent the spinner or break antenna
    For a cub:
    Wouldn’t take much to minimize wing damage. Remove antennas if you can. Two or three of those inflatable sledding inner tubes under the wings and skylight area to skid it on.
    Drag it to firm ice, pull the skis and the prop. Cut another hole in the ice under the engine large enough for it to swing through.
    Lift the tail until it is standing vertical, pivoting on the leading edge, with engine in the hole.
    The wheels must be on firm ice and anchored or tied to prevent sliding, and then pull it over onto its gear. The engine will simply lift up from the water as it pivots over onto the wheels. (Takes lots of help to pull onto its gear this way, or a good snow machine).
    Pull it it away from the hole and put it back together to fly or call a chopper.
    lots of visquene and a Herman Nielsen heater would be great at this point.
    Ive used a similar technique to get a flipped cub on tundra grass back upright. It flew home two days later.
    Ed
  6. #46
    9,299
    The big water toys would work great actually! Those big tubes for multiple folks- slide under the wing and inflate, lift the engine plane strait up, some of those are 3' tall? Get it up the first inflate, block up, stack snow under the wings with a trail path back, and do a second time. Tow both tubes and the plane backwards until skis over solid ice, release air.
    Someone try this out and report back... could work good, or cause lots of
  7. #47
    Bowie's Avatar
    Jul 2014
    West Milford, NJ
    124
    Ok. Lots of experience out there. How would or did you get a plane out of something like this?
    Oh... and with minimal damage. Give details please as it could really help someone in the future.
    Attachment 40779
    I would pick up Denny McCartney's book "Picking Up The Pieces" he makes it sound almost easy. Bright guy with an interesting life.
    https://www.amazon.com/Picking-Up-Pi.../dp/1553696026
ID:	40924Click image for larger version.
ID:	40925Click image for larger version.
ID:	40926Click image for larger version.
    Thanks TurboBeaver thanked for this post
  8. #48
    May 2007
    Palmer, Ak
    65
    Great guy Craig Elg.... miss him. Worked with him at Lake Hood in the 80's Flew with his Dad Rod also.....good people.
    Thanks tripper thanked for this post
    Likes Bowie, cubpilot2 liked this post
  1. Tribute to the Fallen
    By cubdriver2 in forum Video Vault
    Last Post: 01-05-2014, 10:19 AM
  2. Fallen Hero
    By Taledrger in forum Cafe Supercub
    Last Post: 01-05-2007, 12:32 AM
  3. Fallen Fathers
    By Scooter7779h in forum Cafe Supercub
    Last Post: 05-12-2005, 09:14 AM
