PIPER J5.5
FRIEND
corvallis,or
Im speechless about the location of this antenna. I really am.
yes
This is where I usually mount them. As said above, occasionally there can be noise issues but rarely enough that I deal with them on a case by case basis. The Comant antenna works great but is spendy. I've used the TED 104-12 antenna for many years and had great performance. Also, drill one hole and the TED is installed.
When any antenna is mounted on a metal surface, the ground plane issue is usually taken care of with no further 'additions' needed.
Hopefully you survive the curse better than Carter's crew!
That recess may be less than ideal but I'd say it will work just fine. If I was installing this antenna for you, I'd keep it close to center, left/right, and roughly six inches from the rear edge of the boot cowl. And if the antenna is within 10 or 15 degrees of vertical, in level flight, it will function correctly. Remember that while vertical is perfect, it's made to work as the aircraft maneuvers.
Those cover panels look like they've been worked over pretty hard during maintenance. You could fabricate replacements fairly easily.
Pics like this really make me appreciate the ease of working under a C180's panel.
We put the gear doors through the metal bending rollers to give a nice continuous bend, after giving them a thorough clean and I covered the main pain chipped areas with orange vinyl. They now fit and look a lot better, although fitting the inboard hanger nuts and bolts was a nightmare!!!!View attachment 40846View attachment 40847View attachment 40848View attachment 40849
Using Garmin.
Test flew the transponder today and got an AOK from ATC [emoji41] Thanks to all for the feedback and advice!!
@Web I fitted the aerial just where you said and even at 1700’ AGL and 20 miles from the airport, everything worked 100% to specification and tolerance TOP advice!! THANK YOU!!!
I also put some self adhesive O section seal between the gear doors and false boot to dissuade the oil from creeping in there
View attachment 40916View attachment 40917View attachment 40918
Glad to hear that. Congratulations on a good install!
