Likes Likes:  0
Results 1 to 8 of 8
Thread: Baggage compartment
    twoton's Avatar
    Sep 2007
    Dassel, MN
    95
    Baggage compartment
    Looking for suggestions on material to use for enclosing my baggage compartment, on a PA12 Dakota Airframe? Also looking for options on hanging the outside baggage door.
    StewartB
    Guest
    My Dakota fuselage came with the baggage door frame in place. The door is made of aluminum with two quarter-turn fasteners. If you go to the gallery and blow the photo up you'll see the rivets that are holding the perimeter stiffeners in place. Very simple.
    I isolated the upper baggage from the lower. Some guys put a sliding trap door in the upper baggage floor to reach into the lower. I chose not to. My side walls inside the upper baggage are fabric.
    My lower baggage uses Kydex sides and aluminum floor and is simply an extension of the main cabin. Don't forget to add some hard points for cargo tie-downs. In the picture the headliner and floor are powder-coated aluminum and the side panels are Kydex.
    Stewart
    twoton's Avatar
    Sep 2007
    Dassel, MN
    95
    Thanks for the feedback. This looks like a great idea!
    kiwicubber's Avatar
    Jun 2007
    Te Kowhai, New Zealand
    140
    StewartB Can you repost the photo showing the rivets holding the stiffeners in place please?
    Do the rivets go into the tube at the front of the door?
    cheers bill.
    Bill and Neroli.
    www.supercub.co.nz
    4,944
    Baggage compartment
    Bill,
    Sadly in the pre-cloud says I lost almost all my PA-12 pictures to a hard drive crash. As I recall the perimeter frame was welded angle aluminum and the hinge attached the door to tube. Perhaps Scooter 7779H will be able to take some pics for you since that plane has been his for several years now. Sorry I canít offer more help.
    SBClick image for larger version.
    Thanks kiwicubber thanked for this post
    kiwicubber's Avatar
    Jun 2007
    140
    Thanks Stewart, yup computers are supposed to help us :-0
    cheers Bill
    Bill and Neroli.
    www.supercub.co.nz
    10,671
    Bill,
    there a few pictures of your -12 in this album... https://photos.app.goo.gl/xVqnwWGZXDFNkC7g2
    you had tabs welded to longerons to attach sides to
    10,671
    some baggage ideas here https://goo.gl/photos/HmUX41Zzr5sDagzDA
    and https://goo.gl/photos/PuiR5ha2aBDbkUBS8
    and https://goo.gl/photos/GRXyyNHPoUik2V44A
    elevator cables were moved below tubes, rudder behind side panels
  1. extended baggage compartment for a pa-12
    By buckeye in forum Tales of the PA18
    Last Post: 04-04-2009, 10:56 AM
  2. Cruiser Baggage Compartment???
    By WSH in forum Cafe Supercub
    Last Post: 09-30-2007, 06:13 AM
  3. PA-12 Baggage Compartment Question
    By BES in forum Modifications
    Last Post: 02-16-2007, 10:25 AM
