Page 3 of 3 FirstFirst 123
Results 81 to 118 of 118
Thread: O-235 Oil Leak ID Line-Up!!
  1. #81
    9,268
    The ring gear just pulls off. I can't recall, yours may have two screws which will be in plain sight after the prop comes off. Then dig out the seal and glue in the new one.
    https://www.lycoming.com/sites/defau...il%20Seals.pdf
  2. #82
    Jun 2018
    England
    333
    Quote Originally Posted by Philly5G View Post
    Brill!!! Thanks! Weíve had the propeller and nose cowl off before, so itís just the ring gear thatís uncharted territory Does it just unbolt and then fit a new seal?
    Iíve just looked at the parts catalogue and although Iím a real engine newbie, it looks like this seal is internal and between the cases on the crankshaftClick image for larger version.
ID:	42167? Or can it be fitted/replaced when the cases are still together?
  3. #83
    Jun 2018
    England
    333
    I posted my last post after youíd posted this one, but before Iíd seen it Thanks for this!!!
  4. #84
    9,268
    That is where it is except that it slides back from the crank flange into the opening and is installed with the crankcase already assembled.
  5. #85
    Jun 2018
    England
    333
    Letís hope itís just the seal and that the crank case hasnít worn oversize!!! That service bulletin talks about complete engine disassembly if it has!!! 8(
  6. #86
    Jun 2018
    England
    333
    Found a YouTube video showing this seal being fitted to an O540 - boinnnnggggggggggggg!!!!!
    Is that special tool that curves around the prop flange essential?
  7. #87
    9,268
    It is not essential. However I have not done many one piece seals so I'll let others here give you the clues. The objective is to not damage the seal which could be easy if there is a nick on the flange.
  8. #88
    Jun 2018
    England
    333
    I didnít realise the seal was just a thick rubber ring with very elastic properties, until I saw the video today and now itís obvious how itís fitted You can probably see why I was wondering how on earth it could be fitted, before I saw it being stretched over the prop flange
  9. #89
    Jul 2010
    Elizabeth, WV
    520
    There have been seals replaced that continued leaking because there was a groove worn in the crankshaft by the previous seal lip. If you have such a groove you might stop the install of the new seal about an 1/8 inch from the bottom so the seal lip rides on a fresh surface. Another trick is to shorten the spring 1/4 to 1/2 an inch before reinstalling it in the seal before inserting the seal into the bore. Usually these tricks are done after multiple seal failures because the crankshaft seal area wasn't closely inspected for wear.
  10. #90
    Jun 2018
    England
    333
    Quote Originally Posted by N86250 View Post
    Thanks for this. Is it possible to ďeasilyĒ inspect the area where the old seal has been? and if not easy, whatís the best way to do the inspection?
    Do the replacement seals come with a spring? or is the existing one reused? Interestingly, I donít see the spring listed in the parts list?
  11. #91
    9,268
    The spring comes with the seal. Hooking the ends together is difficult for those with fat fingers. You might practice this away from the engine first. Sometimes it helps to preload a small twist in the spring to prevent it from unhooking.
  12. #92
    Jun 2018
    England
    333
    And here's the link to the how to video https://www.youtube.com/watch?v=sANfkgRBHpw boinnnnggggggggggg!!!
    I also found this very useful thread https://mooneyspace.com/topic/8244-c...-split-or-not/ which contains nuggets of gold like "Remove the spring, tape the crank flange good with electric tape to cover the sharp edges, warm the seal up in hot water lube everything up and it will actually go on easier than you think"
    Unfortunately it also says that "If the crankcase is building pressure, it will make the seal leak" and as regular readers and contributors of this thread know, it's likely that my crankcase IS building pressure from the oil control piston rings
  13. #93
    9,268
    I would change that "will" to could make the seal leak. A seal is more likely to leak if there is a buildup of crankcase pressure which can be from worn piston rings.
    Also it is easier to install the spring on the one piece seal than it is on the split seal since the split keeps moving and knocking the spring out of the groove.
  14. #94
    Jul 2010
    Elizabeth, WV
    520
    [QUOTE=Philly5G;743550]Thanks for this. Is it possible to “easily” inspect the area where the old seal has been? and if not easy, what’s the best way to do the inspection?
    A small mirror like a dentist's mirror can be useful. The new cheap flexible borescopes like the Vividia should be useful,too.
    Do the replacement seals come with a spring? or is the existing one reused? Interestingly, I don’t see the spring listed in the parts list?
    As Skywagon said the spring is part of the seal. The spring gets removed for installation for both the split seal and the one piece seal and then reinstalled. You may end up making tools out of safety wire or loops of dental floss or such to hook and maneuver the spring ends for reassembly. Somewhere I saw a suggestion for covering the prop hub with a plastic bag and lots of lube for one piece seal installation, the idea being to protect the lip from damage as much as possible. So far in my limited experience split seals have worked just fine when you follow the directions.
    Also check the parts book carefully by model and serial number. Some engine/seal combinations use retainer plates after the seal is installed. The retainers and an unobstructed vent line would eliminate the possibility of a seal blowout.
  15. #95
    9,268
    [QUOTE=N86250;743656]
    There are two bosses at 3 & 9 o'clock which can be drilled and tapped to be used to install a couple of retainer tabs. This will prevent the seal from migrating out.
  16. #96
    Jun 2018
    England
    333
    As oil continues to drip out of the vent tube into the drip tray after flying and for a couple of days afterwards, I suspect the vent tube is pretty unobstructed
  17. #97
    Mar 2018
    178
    I've found that leaky crank seals don't tend to leak much oil out of themselves but they do tend to send oil out of the breather. Don't know about that on Cubs but have seen that on other planes. For philly 55 g are you sure none of that oil is coming from between the case halves? Case fretting happens. If you attempt a fix involving retorquing all the cylinders without complete disassembly and line-boring you may invite more trouble than hoped for. Living with some oil leaks until ready for overhaul (which is just disassemble, inspect, and repair as necessary to service limits) might just be better than the alternative.
  18. #98
    DUSTERMAN's Avatar
    Nov 2009
    Heyburn, ID
    64
    if you watch you can find these in lengths up to about 12 inches.https://www.ebay.com/itm/One-1-NEW-7...uTr:rk:3:-Pf:0
    I'm no expert, but I ordered an extension for my O-235 and the threads were different on the one I received. It is a PITA to fill with no neck!
  19. #99
    Jun 2018
    England
    333
    Quote Originally Posted by 46 Cub View Post
    Iíve cleaned pretty much all the liquid(ish) oil off the engine in prep for the trip around the pattern oil leak test in the next few days.
    I already know that SOME oil is leaking from the starboard front pushrod tubes, SOMEWHERE above the generator, the starboard valve covers AND quite a bit from the breather/overflow tube IN ADDITION to the oil being burned and leaving its witness marks on the starboard inner gear tube. So I think the oil test will confirm these, although who knows, there MAY be revelation!!
    Iím certainly not intending to remove any cylinders etc, so unless thereís something obvious, crankshaft or pushrod seals or loose bolt somewhere, Iíll be filling up and wiping off until the end of the season and then calling in the proper engine boys to do the do
  20. #100
    Jun 2018
    England
    333
    Quote Originally Posted by DUSTERMAN View Post
    100% agree on the no neck fill PITA!! It now takes maybe 20 seconds to pour in 1 litre/quart of warm oil with no mess or drips, compared to the (at least) 4/5 minutes+ before AND no oil covered flexi funnel/tube to store!!!
    The used (Lycoming) oil filler extension/neck I ordered screwed straight and securely into the case and wirelocked in. The dipstick it came with has a chamfer on the lowest threads, so doesnít engage until the last turn, but feels secure enough. The biggest job was modifying the dipstick to add an extra 1.5Ē to reach to the 1 and 2 litre measurements, but now it looks FAB!!!Click image for larger version.
ID:	42219Click image for larger version.
  21. #101
    Jun 2018
    England
    333
    Success on phase 1 of the oil leak hunt!!!!!!
    I combined the new tailwheel test drive around the airfield with a decent engine run, before the flying the pattern test next week and I'm sooooooo happy to say that a couple of oil leaks have already shown themselves!!!!!
    Following the great advice in this thread, I cleaned the engine as well as I could on Saturday and it worked brilliantly!!!! as on shutdown today, the 2 leaks were immediately obvious!!!!!
    The first one is coming from the rear starboard, lower (rear?) cylinder base bolt(s)
ID:	42241 Click image for larger version.
    and the other one, somewhere above the generator bracket
    Further investigation is obviously needed to get to the source of the 2nd leak and I may remove the prop to remove the nose bowl. On the 1st leak, would tightening those bolts be an easy fix, or something to try? Or does it fall into the category of the warning from 46 Cub "If you attempt a fix involving retorquing all the cylinders without complete disassembly and line-boring you may invite more trouble than hoped for. Living with some oil leaks until ready for overhaul (which is just disassemble, inspect, and repair as necessary to service limits) might just be better than the alternative."
    I'm REALLY excited to be getting somewhere on this leak hunt
  22. #102
    9,268
    Leak #2 is likely the crankshaft seal behind the prop. A relatively east fix as we have described.
    Leak #1 is an "O" ring around the cylinder base which has dried out over the years. Leave it alone...put up with it. ​The fix is to remove the cylinder to replace it. With 1800 hours on the engine leave it alone and just wipe it off. Don't open that can of worms until you are prepared to overhaul the engine.
  23. #103
    Jun 2018
    England
    333
    Any mileage in putting "something sealantish" externally around this joint to help the O ring, without removing the cylinder and saying hi to the worms?
  24. #104
    9,268
    I've not done such a thing. Though I see no issue with using a sealant which does not harm the crankcase and cylinder metal. Something which can easily be cleaned off when the time comes to do the overhaul. Perhaps someone else here has used such a sealant? There is no pressurized oil behind this leak other than crankcase pressure. It's only messy.
    As I've told you earlier, the biggest issue that I've seen with the O-235 engine is oil leaks. When the time comes that the leaks exceed your patience for cleaning and putting up with them, then it is time to overhaul.
  25. #105
    Jun 2018
    England
    333
    Wiping oil off my aircraft is one of my very least favourite things, so my patience is pretty limited in this area to start with
  26. #106
    9,268
    There comes a time when the engine will talk to you and say "Phil it is time, open your wallet". You will know when this time has come.
  27. #107
    Jun 2018
    England
    333
    Ha ha ha ha ha!!!!!!!!!!
    Itís currently saying ďPhilly Iím in good shape, I start and run beautifully and Iíve been together with this body for 72 years. I know Iím a bit leaky and dribbly, but if you can help me out with some incontinence treatment or products, Iíll continue to do my best for you and PLEASE donít replace me with a younger model, or send me in for major surgery, IíM FINE!!!!!!! REALLY!!! xxxxĒ
  28. #108
    Jun 2018
    England
    333
    Hmmmmmmmm either I'm getting very lucky or getting very confused now!! I borrowed a Lycoming Cylinder base nut spanner and torque wrench set to 300 inch/pounds and checked the torque of the 2 (3/8") base cylinder nuts where the oil was coming from. The back one was fine, but I got maybe an 1/8 of a turn on the front one and felt disappointed they both weren't looser and this was therefore an easy find. I couldn't do any more work on the oil filler flap fabrication, as waiting for the Dzus to arrive, so put the lower cowl back on and went for a flight in the Spring sunshine
    I've done a lot of work on this aeroplane and everything worked beautifully and the whole flight felt like the end (at least the initial part of!!) of the journey. After getting back, on looking at the side behind the starboard cowling and the starboard undercarriage top fairing, after getting out, I noticed less oil spatter and runs than usual and on opening the side cowl, I was pretty amazed that there were was NO oil at all under those 2 cylinder base bolts and just a few large drops at the front of the base cowl, which I'm guessing are from the other oil leak, which we suspect is the crankcase oil seal!!! So either:
    1. That 1/8 of a turn made the difference
    2. Running at an oil level of 5.5litres (nearer 4 before) made a difference
    3. Running at 2350 (rather than 2400) for the bulk of the flight made a difference
    4. The leak is still there but the oil was blasted from there to the front of the lower cowl!!!
    Any thoughts please?!!!
  29. #109
    9,268
    Check the torque on all of the nuts to be certain that they are equal. A loose one can cause a tight stud to break by increasing the loads on the tight one. sounds like you are getting lucky.
  30. #110
    Jun 2018
    England
    333
    Good idea and I'll check the rest when I'm back out there tomorrow Do you think that even such a tiny 1/8 of a turn could make the difference to stop the leak?
  31. #111
    9,268
    Cylinder bases do start to leak over time. So I just assumed that yours were leaking due to the 1800+ hours on the engine. 1/8 of a turn loose is a lot. So yes it could have been the cause of the leak. It could have just been loose. It could have been loose since new. It could have a stud which is in the process of stretching and breaking.
    I have found those internal wrenching cylinder nuts hanging by their safety wire with a piece of stud still in the nut. Several on one engine even. The same engine also had cracks in the crankshaft flange between most but not all of the lightening holes.
  32. #112
    Jun 2018
    England
    333
    I've got to say, the engine looks really good from the outside, paint good etc and seems to be in pretty good condition. The aircraft was used commercially for aerial photography (and then basically sat pretty much unused for 16 years) and the fast drain oil valve and the no oil filler neck (I'm guessing oil pumped and not poured in) point to it being a working tool, so the engine probably got a fair amount of attention. I'll let you know about the other nuts and how they are against the 300 inch/pound torque.
    THANK YOU SkyWagon8a for your really brilliant and consistent help along this thread
  33. #113
    9,268
    You're welcome Phil. I'm not always right, but I try.
    Remember that there are two sizes of studs/nuts on those cylinders. That means that there are two different torque values.
  34. #114
    Jun 2018
    England
    333
    Thanks again my friend!!
    I thought there were 2 types of nuts, but looking at the parts manual https://www.lycoming.com/sites/defau...0PC-302B_0.pdf page 3-5, on the C models they're all the same - 32 * Part 11 - 3/8 nut and the torque settings in the limits manual page 1-35 (my O235-C being Chart A) https://www.lycoming.com/sites/defau...20Complete.pdf has the torque for 3/8 Cylinder hold down nuts at 300 inch/pounds, unless I'm reading this wrong?
  35. #115
    9,268
    As I said, it has been a while since I worked on an 0-235. It does appear that all 8 cylinder hold down nuts are the same size. 3/8-24 and the torque is 300 in-lbs. You are correct.
  36. #116
    Jun 2018
    England
    333
    I checked all the cylinder hold down nuts I could access without taking the baffles off and they were all 300 inch/lbs, or maybe more!
    I also checked the oil filter at the back/top of the accessory housing and no collection of metal filings in there at all!!
    I'm going to fly it quite a bit now and keep a close eye on the oil consumption and if the front leak continues, remove the baffles so I can see more clearly where it's coming from
  37. #117
    9,268
    ...I'm going to fly it quite a bit now and keep a close eye on the oil consumption and if the front leak continues, remove the baffles so I can see more clearly where it's coming from
    Chances are good that it is the crankshaft seal behind the prop. Not a big deal to fix.
  38. #118
    Jun 2018
    England
    333
    Yes, I looked at this the best I could with the top cowl off and peering through the nose bowl holes, could see some old oil inside the propeller boss, but nothing new. I'll keep a close eye on it
  1. Thrust Line Mod -- What is the bottom line?
    By JMBreitinger in forum Cafe Supercub
    Last Post: 02-04-2005, 05:13 PM
  2. O-290 oil leak
    By RobW56 in forum Super Cub Sick Bay
    Last Post: 02-06-2004, 06:08 PM
