Results 1 to 9 of 9
Thread: King Katmai v. Cub
    sjohnson's Avatar
    Boise, ID
    675
    King Katmai v. Cub
    I was talking to a couple of friends the other day. One just sold his Carbon Cub and wants to buy a 182 for doing cross countries. The discussion got around to the King Katmai conversion by Peterson.
    Peterson advertises the stall speed as 31k at 3100 lbs. The original stall speed for a 182Q is 50 KCAS (dirty, power off, most rearward CG) at 2950 lbs.
    31 kts is 62% of the original stall speed, or about 38% kinetic energy. This doesn't seem aerodynamically possible without lengthening the wings, which I understand is not part of the conversion. There simply isn't enough energy in the airflow.
    Micro shows a 8% reduction in stall speed for its VGs. The Katmai canard might help a little, but it cannot be too powerful - if it overwhelms the tail, it could induce a deep stall.
    So how is this possible? Is the 31k number power on? KIAS instead of KCAS?
    Flight reviews (from the Peterson website) describe touchdown speeds ~35k, presumably indicated but not at gross.
    Landing roll goes from 560' to 290', which also seems suspect. Even at the published stall speed, given the energy change (assuming touchdown speed scales), the ground roll should be around 350'.
    The Peterson published numbers are roughly equivalent to stock Super Cubs, a plane with much lower power loading and just over half the weight.
    Anyone have experience with these?
    Idaho drinks more wine per person than any other state in the country.
    JDWilliams's Avatar
    Aug 2018
    24
    All those numbers are about right - hard to compare apples-to-apples when you’re talking about a wide variety of “runway” surfaces in bush flying. I’ve got some time in a late model Katmai and it’s pretty amazing. Mains off the ground at 30 to 35 knots in ground effect - more or less routine for takeoff. Same for landing. Nose wheel easily controlled. With even a little power the canard keeps the nose wheel off the ground. Hard to beat the envelope from stall to normal cruise airspeed range. Go fly one. It’ll make a believer out of you.
    Thanks sjohnson thanked for this post
    Likes 180Marty, Beaverpilot liked this post
    4,885
    i'd rather have a Skywagon.
    Likes OLDCROWE, hotrod180, FdxLou liked this post
    10,655
    Robertson listed the stall speed of the RSTOL Cessna 185 at 37 knots, and I firmly believe that number. So, pretty comparable reduction in stall speeds. I’d believe it.
    its a bitch to remove the cowlings on those Katmais though.
    Likes FdxLou, pzinck liked this post
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,394
    does the canard seem to get in your field of view?
    sjohnson's Avatar
    Boise, ID
    675
    Are the speeds you're providing KCAS or KIAS?
    My 182Q manual shows a pretty significant error: 50 KCAS is 38 KIAS. This would explain some of the apparent phenomenal results.
    9,151
    In the early years when the Wren conversion came out, there were a few up in Alaska.
    Bill Ellis had picked one up that had some issues and got it back flying; he was impressed with it's performance.
    Wish that conversion was available on the 206!
    Likes pzinck liked this post
    JDWilliams's Avatar
    Aug 2018
    24
    Didn’t bother me at all. The canards are positioned low enough not to impede forward visibility during ground movement and the span of each canard is inside the prop arc. So...since it’s a nose wheel, the taxi visibility is better than just about any taildragger and once you’re rolling for takeoff you’re looking well beyond the area blocked from view by the canard - even with the nose high soft-field takeoff.
    Thanks Dave Calkins thanked for this post
    May 2019
    2
    I fly a peterson modified 182 with canard. I have not landed it off runway and I havn't even begun to take it to its limits. Mine is the older version with the 260 hp engine. On take off, it goes into ground effect scary quick for as heavy as it is, and then rises nose flat like you are in an elevator. When landing, you have to hold it up until it is slow enough or it will just keep flying. Once you cant keep it up anymore and the mains touch the runway, it is rare to roll 200 feet. I don't know what else to say. It is an easy plane to fly and land, I have flown regular 182's and there is no comparison at slow speeds.
  1. Katmai 10-12 August
    By JohnnyR in forum Supercub Gatherings
    Last Post: 05-25-2018, 12:07 PM
  2. Video: Katmai Summer Fun
    By Henny in forum Video Vault
    Last Post: 01-26-2016, 09:34 AM
  3. Katmai
    By chuckpodo in forum Cafe Supercub
    Last Post: 07-01-2011, 04:18 AM
  4. Katmai Trip
    By Redbaron180 in forum Sportsman's Den
    Last Post: 07-10-2007, 11:50 AM
