Super Cub to 23000 feet - Engine/mod combo?
I agree with MTV, you are leaving a lot of horsepower on the table. You should be able to go to full throttle or nearly so down low without exceeding 2700 rpm. At altitude your maximum manifold pressure will be reduced. So at 15,000 you would be lucky to get 60% power at full throttle 17" mp and 2700 rpm. Take a look at Lycoming's power chart.
Please explain. I'm not sure I understand.
At altitude where I fly 90% of the time I can go WOT with the Catto in level flight and it turns 2650-2700.
Overall Ive been pleased with how the Catto does at altitude. It doesn't seem to run out of bite like the Borer reportedly does.
You stated "Down low it will overspeed very easily at more than 2/3rd throttle." That is indicating that you are using less than maximum available power. You are operating in a unique environment. At your most critical take off altitude are you getting at or near 2700 rpm with full throttle? If so then change nothing as that is where you need the power, on take off at a critical altitude.
It's statics at 2300-2330 at SLCB (8360) or my higher strips (12,500). 2500-2550 rpm in a 60 mph climb. Yes I'm leaving horsepower on the table. Options...
A. Buy a 86/36, lose cruise speed, carry more fuel.
B.Higher CR/port/polish to spin my current prop faster on T/O and climb. I want to do this but don't want to open up a good running engine.
Other ideas appreciated. :D
Pulled a dental team (2 pax) their camping gear and full fuel out of LA Paz (13,300 ft) last week around 12 noon. Almost 1900 lbs on takeoff. DA was probably close to 16K on the runway. Climbed another 2K higher en route.20190711_113212.jpeg
Impressive!
I think more displacement the only to improve on what you have, that opens up a whole nuther can of worms.
How long was your ground roll on the 13k TO?
Probably 600 or 700ft? Up there I let it roll till I'm seeing at least 40 mph IAS.
This strip in the high desert is 13,630 ft. They used to fly C-46s in here full of meat from the lowlands to supply the mines.
Awesome. I flew a 1962 C130E into and out of LaPaz. We were super light on takeoff and used about 9000’ and oversped the nose wheel by 20 kts.
Do you use oxygen in that cub?
Jake
The airforce here flys a C130. I would have thought it would do better. Isnt it a pretty good STOL machine at sea level? I'm curious what the mission was that brought you all the way down here?
I've got one of these under the panel and use it fairly often. I use a pulse oximeter to keep a close watch on myself. Just concentrating on deep relaxed breathing keeps me in the mid 90s without O2 but under even mild stress I put on the O2 as insurance. 20181228_122819.jpeg20190628_141943.jpeg
Please tell me what is your information source on your iPad? ipad model? Thank you
