Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
Thread: Brake Boosters Required for Bushwheels?
  1. #41
    2,784
    Quote Originally Posted by Carey Gray View Post
    ...Filling from the bottom works great for bleeding, but after the brakes are bled I just fill them from the top. It's easier and not as messy.
    I top off the brake on my C180 from the bottom up --
    for me, it's quicker & easier than crawling under the panel and fumbling around.
  2. #42
    nd
    3,343
    i top my north rivers or take some out which is very seldom needed with these.https://www.ebay.com/itm/X5-Small-1m...BD:rk:23:-Pf:0
  3. #43
    Nov 2003
    Thun Field, Washington
    780
    What I don't like about filling from the bottom is that you have to be pretty careful not to squirt some air into the system and make things worse.
    Don't you still have to get under the panel to take the plugs out of the master cylinders?
  4. #44
    behindpropellers's Avatar
    Feb 2003
    NE Ohio
    6,725
    I always vacuum mine from the top. No air bubbles.
  5. #45
    4,812
    Cessna masters are vented. If you don't toss a rag over the masters they'll pee straight up in the air like a baby boy when you pump from the bleeders.
  6. #46
    Nov 2003
    780
    Too funny. Now I have this visual...
  7. #47
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,457
    One of these in place of the vent plug with a tube into a jar eliminates the peeing.
  8. #48
    4,812
    A rag is easier. A rag with a little brake fluid is great for wiping down the belly, too.
  9. #49
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,457
    Can't argue with that logic!
    A rag is easier.
  10. #50
    cruiser's Avatar
    May 2002
    South Glens Falls, NY
    1,441
    The vent plug is a straight thread not a pipe thread
  11. #51
    4,812
    My rags are cotton thread.
    Likes CamTom12 liked this post
  12. #52
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,457
    Stright thread barb fittings are available.
    Quote Originally Posted by cruiser View Post
    Likes cruiser liked this post
  13. #53
    18,958
    These dam Cessna guys posting on a Super Cub site are making my head spin. Scott brakes use a straight thread, I made the fitting to bleed them. Cessna uses A tapered pipe thread.
    Thanks Eddie Foy thanked for this post
  14. #54
    2,784
    My C180 master cylinders have plastic pipe plugs, with itty-bitty vent holes.
    They don't really tighten up like a pipe thread should though, more like they bottom out.
    What I don't like about filling from the bottom is that you have to be pretty careful not to squirt some air into the system and make things worse. Don't you still have to get under the panel to take the plugs out of the master cylinders?
    I have an oil pump can full of 5606 fitted with some clear plastic tubing,
    pretty easy to squeeze the bubbles out before attaching to the bleeder on the caliper.
    I do remove the vent plugs, but other than usually dropping one into the bilge that isn't too bad--
    it's trying to get the bleeder hose down into the master cylinder and pump some fluid in,
    all while laying on my belly under the panel and fighting off a charley horse in my cramped-up arms that's the problem.
  15. #55
    Oct 2009
    Wanaka,NZ
    335
    I have stock Scott diaphrams and Bodell wheels/brakes on my PA-12. The combination is "good" with 8.50's, "adequate" with 26" Bushwheels, and a bit marginal with 31's.
    Hi Gordon,I see you have the original Scott brakes fitted.Can you offer any advice re changing diaphragms,and longevity of such.Thanks if you can help.
  16. #56
    3,423
    Quote Originally Posted by ron View Post
    I don't have any advice that might be considered sophisticated, but - - I've owned this plane for more than 45 years, and have changed diaphragms twice. Once because one ruptured on a short gravel bar. That was entertaining! Seems to me that they're good until they're not? Some of the mechanics here will have better, more detailed information for you.
    Thanks ron thanked for this post
  17. #57
    9,889
    27 years of Cub flying and I have never blown one. If you keep them pumped up they hardly stretch at all, it's when you let the fluid get low that the diaphragm has to travel farther and gets weaker each time it has to stretch that far
  18. #58
    TirolCub's Avatar
    Sep 2006
    Austria
    199
    I am using these bleeder valves on my Cub with Clevelands. Topping the Scott cylinders with fluid and thereafter bleeding the system is just easy with them ...
    http://www.stahlbus.com/products/en/...stem/index.php
    Thanks ron, fancypants thanked for this post
  1. brake boosters
    By av8rtom in forum Cafe Supercub
    Last Post: 10-22-2013, 08:05 PM
  2. Brake Boosters
    By DUSTERMAN in forum Modifications
    Last Post: 11-11-2010, 09:18 AM
  3. Brake boosters
    By pzinck in forum Member to Member
    Last Post: 03-29-2010, 09:39 AM
