Page 1 of 2 12 LastLast
Results 1 to 40 of 58
Thread: Brake Boosters Required for Bushwheels?
    FullThrottle's Avatar
    Jul 2013
    Houston, TX
    14
    I saw some threads about brake boosters, but nothing that discusses whether or not brake boosters are required for all types of bushwheels. Although pretty much anyone with over size 26 tires likely uses them (the original Scott brakes aren't amazing), is there anything required in the STC for 31 inch bushwheels (or bigger) that would require either the boosters or double puck brakes?
    3,423
    Brake effectiveness with 8.50s will be reduced by about a third with 31s. (diameter ratio, small/large)
    akskibum's Avatar
    Dec 2011
    Anchorage Fairbanks
    49
    The Bushwheel STC requires "heavy duty brakes" for a PA18.
    9,555
    Quote Originally Posted by akskibum View Post
    "heavy duty brakes" or "heavy duty landing gear"? They are not the same.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,845
    From a practical standpoint, I think your brakes are going to be lacking with the original Scott masters and single puck calipers. Although I typically don't use much brake other than run-up and close quarters steering, it's nice to have good braking power when you really need it.
    18,958
    According to the Bushwheel STC Aircraft Model List note 1 you need heavy duty brakes. http://www.airframesalaska.com/v/vsp...reak%20AML.pdf
    Required or not you want them if you want to stop.
    9,555
    Thanks Steve. This brings up another question. What is the FAA's definition of "heavy duty brakes"?
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    353
    Heavy duty Cub brakes Two required.
    Thanks Nodak33, TCE thanked for this post
    nd
    3,343
    tried them, didnt have enough up trim, damn near crashed. says 2 required, was that for each side?
    Likes Farmboy, flybynite, ron, moneyburner liked this post
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    748
    I would think in the case of a cub it would indicate double puck disk brakes.
    The word “heavy duty “ is too subjective and is used by most manufacturers to indicate some type of “upgrade “
    Ed
    1,756
    Soooooooo, Most will say a set of double puck brakes for a cub is a Heavy Duty brake. BUT, I do not see a Heavy Duty description listed in the type certificate. I also do not see Heavy Duty description listed on the Cleveland or Bushwheel double puck brakes. Could not find a FAA description of "Heavy Duty Brake" for a CAR 3 aircraft. The bottom line is whatever your IA will sign off is what you need. I see nothing that says brake boosters are required (I am sure more than one cub has been on its back without them). I would go back to CAR 3 and see what the requirement for brake performance is and go from that. For my mission I think brake boosters and double puck caliper on 31 inch bushwheels is a must have. I would be happy to fly a cub without boosters, I would just pay a bit more attention on how long my landing area is.
    03.365 Brakes shall be installed which are adequate to prevent the airplane from rolling on a paved runway while applying take-off power to the critical engine, and of sufficient capacity to provide adequate speed control during taxing without the use of excessive pedal or hand forces.
    Still dark and cold out here we could stir this pot for a while
    Thanks Bowie thanked for this post
    Likes cruiser, BC12D-4-85, WanaBNACub liked this post
    18,958
    On a Pacer I would consider double puck Clevelands as HD and in a Super Cub I guess I could consider the same over the original expander tubes which are a 4" wheel so I guess you do need heavy duty brakes so you have the correct wheel size. You won't like your stock diaphragm brakes with Bushwheels I can pretty much guarantee.
    3,423
    I have stock Scott diaphrams and Bodell wheels/brakes on my PA-12. The combination is "good" with 8.50's, "adequate" with 26" Bushwheels, and a bit marginal with 31's.
    Likes TirolCub liked this post
    9,555
    It should be noted that when the large diameter tires first came into use on the Cubs that 4" expander tube brakes were in use. These did not have enough braking power to keep the wheels from rotating. As a result someone changed the expanders to double puck 6" disc brakes. These didn't hold either but were a lot better than the expander tubes. As a result high pressure boosters were developed to activate the double pucks. Now they worked. The double puck with booster is strong enough to cause you to buy a new prop. Definitely a heavy duty brake.
    Did anyone ever try single puck wheel brakes with high pressure master boosters? If so how well do they work? Seems that since the gross weight of a Cub is quite low, the single puck brake ought to be sufficient when coupled with a booster master cylinder.
    Likes mike mcs repair, PerryB liked this post
    10,611
    Back when, our Cubs with expander brakes and 25 inch Goodyear Airwheels had marginal braking.....as in they wouldn’t hold the plane during an 1800 rpm run up.
    Personally, I like effective brakes most of the time.
    Sep 2004
    England, UK
    20
    It’s not just your stopping distance that’s the issue without boosters. I tried 31 inch Bushwheels with my double puck brakes and standard Scott masters. Crosswind landings on pavement were scary, I quickly went out and bought the boosters.
    Nov 2003
    Thun Field, Washington
    780
    I'll be danged. I have single puck brakes and stock diaphragms on my Exp Cub and my brakes work fine with 31s.
    They got a lot better when I went with good high pressure brake lines instead of the old POS lines.
    Likes mike mcs repair, BC12D-4-85 liked this post
    18,958
    Quote Originally Posted by Carey Gray View Post
    Did you learn from Jerry Burr how to get pressure in the system and lock the parking brake valve, then add more fluid?
    Nov 2003
    780
    I do know how to do the parking brake thing, but I don't have parking brakes.
    If you don't have it, you never have to fix it.
    18,958
    So you just top off the stock master cylinders w/diaphragms, no pressurizing the system and you have good brakes on 31s?
    cruiser's Avatar
    South Glens Falls, NY
    1,441
    I have no problems with 31’s and stock master cylinders. I suggest fresh diaghrams and seasonal fluid level correction.
    3,423
    Speaking only for myself - I fill through the bleeder valve at the wheel with a piece of plastic tubing on an oil can. A little bit redneck I guess, but it works much better than just filling at the master plug. That gives me so-so brakes with 31's and decent brakes with 26's. On 26's I can hold pretty easily for 1800 RPM mag check.
    I suspect the Bodell piston might be bigger cross section than double clevelands, but I've never checked.
    Nov 2003
    780
    I don't know any other tricks. My brakes aren't as sensitive as with the boosters. I wouldn't want sensitive brakes on something with a really light tail. Everyone has a different story.
    Like cruiser said, having good diaphragms is pretty important and the fluid level is obviously important.
    Filling from the bottom works great for bleeding, but after the brakes are bled I just fill them from the top. It's easier and not as messy.
    Apr 2009
    AK
    101
    You can just loosen the 1/4” bolts holding the backplates a couple turns, pump the brake, fill the master, tighten the bolts back up, and have the same effect as adding fluid after locking the parking brake- what I do when there’s no parking brakes and I need to preload them a bit... This has worked well on a customer’s J-5 with stock diaphragms and double pucks with 31’s- enough to hold at full power with the o-290d without mashing the pedals too hard...
    Likes AkPA/18, S2D liked this post
    Meanwhile,...
    5,080
    Rumor has it if you change out the thin copper washers under the cap for some say 1/8” thick and top off the fluid that little bit extra fluid makes for a worthy improvement in braking.
    Thanks windy thanked for this post
    18,958
    That thin copper washer is someones substituted part by because they didn't have the correct parts. The correct washer is a thick, black, fiber type washer.
    Glad my Super Cub had Dakota Cub brakes when I bought it. They stop very well and are trouble free. I only check the fluid level annually, no more fluctuating brake pressures depending on OAT.
    Likes RaisedByWolves, DENNY, windy liked this post
    Meanwhile,...
    5,080
    Interesting, never trust a rumor to stop ya.
    18,958
    YepClick image for larger version.
    Sent from my Pixel 2 XL using SuperCub.Org mobile app
    Nov 2003
    780
    I use an O-Ring
    4,812
    Quote Originally Posted by FullThrottle View Post
    Yes. Common sense.
    I want my brakes to hold the plane in a full power run-up. I want brakes to reliably stop the plane at gross weight. I want to maximize the performance potential that Bushwheels offer in places that Bushwheels allow me to go.
    Thanks Poor Joe thanked for this post
    Likes Steve Pierce, FdxLou liked this post
    tptailwheel's Avatar
    Apr 2004
    vermillion sd
    146
    Your nails are too clean Steve.😁
    18,958
    Quote Originally Posted by tptailwheel View Post
    LOL, start of the day and my left hand. Back when I was attempting to go to college but spending too much time working on cars my Dad suggested A&P school. He said it would be a cleaner living than working on cars. He was right. Good hand cleaner helps as well.
    S2D's Avatar
    Montana
    4,068
    Quote Originally Posted by ak49flyer View Post
    That's funny, after fighting cubs with no parking brakes for years, I just figured that out a couple months ago.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    748
    So “hypothetically “ what high pressure system would you recommend for a cub that is in service and that has the under seat battery conversion?
    Parking brake valves and high pressure hoses already installed.
    Ease of installation, and having “few” operational concerns desired. (Hypothetically speaking of course)
    Ed
    S2D's Avatar
    Montana
    4,068
    Never had any problem with the Steve's A/C brakes (installing or servicing). Easy to service if you have the original style seat & springs. Little harder with the solid seat.
    Thanks cubpilot2 thanked for this post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,457
    I have a Masters Degree and a PHd in Fighter Pilot and get my hands dirty most every day!
    18,958
    But you got a degree, I wasn't that disciplined.
    18,958
    On a flying airplane with good Scott frames I would say Steve's because it is pretty easy to install by just unscrewing the parts, no fabric cutting etc. I use NAS1352-08-8P socket head cap screws to install, way easier that regular screws.
    NDRII's Avatar
    Aug 2003
    Back in No. VA again
    97
    After flying with 35s for 4 and a half years, I finally installed Steve’s on my airplane two weeks ago and man is it nice!!! And yes took Steve Pierce’s advice from a previous thread and used the above cap screws, it makes a world of difference.
    RaisedByWolves's Avatar
    Feb 2005
    3,855
    I love the Dakota cub masters. More involved to swap out, but they are great
    Likes cubpilot2 liked this post
  1. brake boosters
    By av8rtom in forum Cafe Supercub
    Last Post: 10-22-2013, 08:05 PM
  2. Brake Boosters
    By DUSTERMAN in forum Modifications
    Last Post: 11-11-2010, 09:18 AM
  3. Brake boosters
    By pzinck in forum Member to Member
    Last Post: 03-29-2010, 09:39 AM
