Thanks Thanks:  0
Results 1 to 10 of 10
Thread: A185f door off flight
    Oct 2018
    9
    So let me start off by saying that with the winter weather upon us i do not have the urge to go without doors anytime soon. That being said im curious if there is STC paperwork on flying without the doors, and its availability. I heard that in its very early, previous life our plane served as a jump plane. I cannot find any info in our logs to support this however. So, if anyone has info regarding how to accomplish this, im looking forward to hearing back. Thanks!
    Mar 2018
    69
    Letter from the FSDO and a placard gets added.
    2,627
    The 180/182 jump planes I've seen have fold-up RH door arrangements,
    but I guess some folks just remove it.
    I did find this re door removal approval:
    https://uspa.org/Governance/DZO-and-...-Modifications
    says 170/172/180/182 but doesn't actually mention the 185.
    4,560
    Nov 2004
    Fairbanks
    869
    Snomish Skydive Door, one jump door.
    Mar 2018
    69
    There is a USPA STC that allows you to carry four pax (jumpers) and modify the airplane for four sets of floor mounted seatbelts. But, just to fly with the door removed, I remember going down to the FSDO and they provided a letter changing the operating limitations of the airplane for flight with door removed (for skydiving, aerial photography, etc.).
    10,345
    we used to just pop a door off on a beach, then go air drop supplies to hikers.... no paperwork that i know of
    Hardtailjohn's Avatar
    Marion, MT
    699
    We always had an inflight door on our 185 we jumped out of (NOT a perfectly good airplane!), and one time we wound up with no door.... I think it's still up on that hill above the airport somewhere....we never did find it. Back then, all that we had was a field approval for the door hinge to be moved up top. Sounds like the STC shown above will do what you need.
    2,627
    Quote Originally Posted by Hardtailjohn View Post
    ….Back then, all that we had was a field approval for the door hinge to be moved up top. ...
    More than just top hinges.
    The fwd bottom corner of the door has to get bucked off, to clear the strut,
    then the door opening gets a corresponding filler piece.
    And I'm pretty sure a different latch would be required.
    Plus some sort of hold-it-up latch out on the wing too-
    some may be remotely operated?
    Marion, MT
    699
    Yep, basically a corner cut from the door and stuck down in the door frame. Then the one we had was a rotary latch that just ran a couple pins through the door jam. No need for a "hold up latch" because in flight the door stays on the bottom of the wing. Some of the "fancy" ones had a latch (our 180 did, but it was from Boise originally) but the 185 never did...we just held it up and helped eachother in. Oh the days of ignorant bliss.
  1. 1979 A185F interior panels
    By Experimental1911 in forum Cessna: C180/C182/C185
    Last Post: 11-22-2018, 11:42 AM
  2. Cessna A185F Headliner Retainer
    By Grant in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-09-2017, 05:25 PM
  3. Cessna A185F Headliner Retainer
    By Grant in forum Cessna: C180/C182/C185
  4. Cessna A185F stretcher door and photo port photos
    By bat443 in forum Cessna: C180/C182/C185
    Last Post: 01-02-2016, 03:22 PM
  5. Cessna A185F stretcher door and photo port photos
    By bat443 in forum Everything Else (formerly:My Other Plane Is A....)
