What charging system do you have? And how are you monitoring voltage? I.e. voltmeter in panel or handheld?
It's an alternator. I'm not sure which brand. Voltmeter in the panel.
Find a brand/model on the alternator & reg. and it will help with troubleshooting. Alternator doesn't narrow it down much.
Assuming a digital voltmeter?
You’d probably be a lot happier with digital.
JP11;734240With the realization I have Bendix mags.. My priorities I think have shifted from going to Pmags to getting a EDM350 engine display. JP[/QUOTE said:When you check the mag timing, if it is off have the mags pulled and get the Egap checked and corrected. It's a quick job.
Oh my, yes. Your problems are nagging me to think that your aircraft spent a lot of time in the "if it ain't broke, don't fix it mode". I think you may have significant preventive maintenance items to catch up on. I like to avoid magneto failures that result from no maintenance.Ask them to do a 500 hr inspection on the mags.
