ANC Earthquake
These pictures are from an accident that occurred yesterday. This WAS the Mckenna Brothers nicest plow truck. My daughter drove it for two or three years during the winter. Her former co-worker is lucky to be alive....the guard rail saved his butt. This was a fresh road repair. DOT had just removed the barrier cones...the old surface was slightly raised....the belly blade caught and threw the truck off the road. My daughter tells me they haul arse though this area when plowing.
where was that taken?
Correction....
Not Big Lake. Palmer....Belly blades can be fun...especially when slow and trying to cut the ice with a good amount of down pressure....then hit a high spot or are on a barely detectable rise in the road when on ice....the truck bed is almost empty...it will use the belly blade like it’s an ice skate...into the the ditch we go!!
