Results 1 to 40 of 44
Thread: Layout Instrument panel for NQ
    Aug 2018
    54
    Hello, Iím new to the SC. I will get my own Cub late spring/early summer.
    Right now Iím trying to put together the best instrument panel setup from scratch. I am going for night certification. G5? What airspeed indicator altimeter and what altimeter/VSI and what gyro? Do you recommend an Engine monitor (the aircraft has a ďstandardĒ EGT/CHT monitor right now. Which Radio and transponder (Trigs?- small and I hear only good). iPad mount in the panel or on the ďsideĒ. Is anyone using a 9.7Ē iPad?
    What are your suggestions?
    wireweinie's Avatar
    Palmer, AK
    2,981
    Strap on a helmet and your flak jacket, cause you're about to get a whole lot of incoming!
    First and foremost, everything should be as small and lightweight as you can afford. Whatever the brand or model. My recommendation would be an Electronics International CGR-30P for engine gauges. Winters, 2 1/4" airspeed and altimeter. If you use a VSI, just grab any cheap one, preferably in the 0 to 3000ft range. Trig or Becker radios and transponders. Big difference is that Beckers are a one piece unit and the Trigs are separate control head and transmitter box. If you require ADS-B, I feel that the Trig is easier to connect into the system. And I always recommend installing a stand alone intercom. You get better volume and easier squelch control than with the built in intercom in the com radio.
    You mentioned gyros. Is a gyro required for your certification? Is your night certification IFR or VFR? Are there specific instrumentation requirements for this?
    Likes RaisedByWolves, FdxLou, flylowslow liked this post
    3,984
    Speaking of trigs, my display went on the tc90 comm. after a bit of going back and forth with the factory not getting anywhere, I remembered mid continent is who they use for us repair. Called them up, they said yeah itís the display, 100 bucks we will send you a replacement and send the old one back. It was out of warranty, but they were fantastic to work with. And itís super easy to pull the head unit out. New one works great. That was the only trouble I had with them so far in 400 hrs
    Likes Skykingfm liked this post
    wireweinie's Avatar
    Palmer, AK
    2,981
    Great info. I'll keep Mid-Continent in mind for any future issues.
    10,906
    you are about to discover the steel fuselage tubes hiding behind panel... THEY WILL DICTATE YOUR LAYOUT, and no mater how hard you try you WILL run into issues with them..
    wireweinie's Avatar
    Palmer, AK
    2,981
    Heh heh. Oh yeah.
    Apr 2018
    45
    Like that? Click image for larger version.
    Meanwhile,...
    5,204
    Portable so not “certified” but for night flight I really like my Garmin 796 with the GDL 3D linked to it. In the hsi mode you can split the panel with the moving map or go full HSI and it is really slick plus you get ADS B. I have the 796 as the center of my panel and display vertical speed digitally on it so that saves a hole.
    Mar 2015
    Anchorage, Alaska Carefree, AZ
    252
    Quote Originally Posted by OLDCROWE View Post
    Portable so not ďcertifiedĒ but for night flight I really like my Garmin 796 with the GDL 3D linked to it. In the hsi mode you can split the panel with the moving map or go full HSI and it is really slick plus you get ADS B. I have the 796 as the center of my panel and display vertical speed digitally on it so that saves a hole.
    Here is my new carbon fiber panel on Husky, pretty much same for cub.
Name:	Husky panel.jpg
    Dec 2016
    Canyon, tx
    514
    Don’t skimp on a dimmer if you’re actually going to fly in the dark. I spent two hrs tonight with a microfiber towel over my brightest displays
    3,045
    I had the same sort of issue recently taking off at what was effectively dusk--
    not really, but pretty dark out due to low clouds & rain,
    and tablet display was bright enough to make the rest of the panel hard to see.
    I was at a towered airport & in a hurry so I just turned on my (battery powered) "Pilot Light Pro" overhead instrument lights.
    When I got back to my home airport about 20 minutes later, it was much brighter out and I forgot to turn the instr lights off--
    I don't night fly much & so they aren't part of my normal shutdown routine.
    Luckily a buddy stopped by to BS and happened to notice from in front of the airplane that they were still on--
    otherwise, it wouldn't been til I needed them again that I woulda discovered the dead battery.
    FWIW these instrument lights are plastic, battery powered,
    and (like most things in aviation) kinda spendy for what you're actually getting....
    but they were the most cost-effective solution I could find for instrument lighting that I'd only use very occasionally.
    I have the unit mounted to the bottom of the forward spar carrythrough.
    https://www.aircraftspruce.com/pages...otlightpro.php
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    119
    Right now I’m trying to put together the best instrument panel setup from scratch.
    I am in exactly the same position with a certified PA18 rebuild in the UK. I have a new blank panel, a Trig TY91 comm and Trig TT21 Mode S and the old original instruments. Keen on a source of attitude reference, have sourced an electric AH but a Garmin G5 looks very good as there is an STC for it and you can toggle up an HSI display if required.
    When I flew the plane I used an iPad mini supported in a RAM mount with a suction cup attached to the lower right windscreen position.
    19,366
    Quote Originally Posted by jokerswe2008 View Post
    Hello, I’m new to the SC. I will get my own Cub late spring/early summer.
    Right now I’m trying to put together the best instrument panel setup from scratch. I am going for night certification. G5? What airspeed indicator altimeter and what altimeter/VSI and what gyro? Do you recommend an Engine monitor (the aircraft has a “standard” EGT/CHT monitor right now. Which Radio and transponder (Trigs?- small and I hear only good). iPad mount in the panel or on the “side”. Is anyone using a 9.7” iPad?
    Have you seen the recent thread with panel pictures? http://www.supercub.org/forum/showth...54930-Cgr-30-p After flying with the iPad ina Super Cub I much prefer the Garmin 796. The glare is a problem with the iPad in a Super Cub at different times of day. I am a minimalist but I like my VSI, lets me know if I am climbing in the mountains. I really like the Trig radio and transponder. Built in intercom works well. Like Tom posted, Mid Continent does their service work. Bruce there is great to work with. Their warranty is 2 years and if you have a problem that warranty starts over. The Electronics International CGR30P is a great engine instrument for the Super Cub by integrating everything you need for the engine in one 3 1/8" instrument that is easy to see all the information. I have never had to buy new flight instruments, usually just get the old ones rebuilt due to cost of new certified. If you need help I am a Trig and Electronics International dealer, have layed out and installed quite a few Super Cub panels and can provide good pricing and technical advice if needed. It is fun to see these things come together.
    Likes FdxLou liked this post
    5,129
    Anti-glare screen protectors are almost as common as iPads.
    A minimal panel with an iPad Mini running GP and a GDL50 would be a strong contender if I was in the certified world. Amazing capability. Very simple to use.
    My perfect certified panel would have a JPI 930, an airspeed and altimeter, and an iPad running a GDL50. Panels are personal choice. Nobody's choices are righter than another's.
    Likes mike mcs repair, JeremyLee89 liked this post
    19,366
    Open to good suggestions on glare shields. Can't remember all the ones we have tried. One was glass and not cheap. The newest iPad has better glare resistance but still hard to see at certain times of day in certain directions. I love all the information, crazy the think what we use to fly with and what we have at our fingertips now.
    Aug 2018
    54
    Univair
    The new modified Univair fuselage has taken the instruments into consideration, so I believe itís easier with this new fuselage (and also no rust or stressed metal etc - after all it is a very old aircraft).
    wireweinie's Avatar
    Palmer, AK
    2,981
    The new modified Univair fuselage has taken the instruments into consideration, so I believe it’s easier with this new fuselage (and also no rust or stressed metal etc - after all it is a very old aircraft).
    No design changes that I'm aware of. Anyone else heard of this, other than special order?
    It's not the center brace that will obstruct you, it's the two tubes forward of the lower mounting tabs. They come together to form an 'x' between the panel and the firewall. With the panel tipped forward at a slight angle, EVERYONE that has fabbed a panel has had an instrument/radio/primer/etc bump those tubes. You''ll understand this the first time you mock up your panel.
    Aug 2018
    54
    In lower corners it will be a problem to place instruments.
    I donít know how to post pictures here, but send me a PM and Iíll send you a picture.
    Jul 2012
    Montana
    437
    Once you have a panel layout figured out, cut it out in 1/4" plexiglass the exact shape of the actual panel, very helpfull seeing your obstructions
    Thanks JeremyLee89 thanked for this post
    Likes JeremyLee89 liked this post
    behindpropellers's Avatar
    Feb 2003
    NE Ohio
    6,781
    Hit me up if you need a test panel cut, I do them for all of the local guys. I usually suggest two. The first one has the outline and the mounting holes cut with the instrument/avionics locations engraved. The second one is complete.
    Usually I make them out of .093 stock since this is pretty close to typical panel thickness.
    As far as hitting the stuff behind the panel, the cub is pretty easy since there is good design data on it.
Name:	Two Panels.jpg
ID:	40016Click image for larger version.
    Likes Steve Pierce, utb 44E, C-FIJK, flywhatever liked this post
    Sep 2004
    Illinois & Wisconsin
    666
    I seem to recall the guy in Vernon, B.C. solved the interference problem with the tubes behind the panel by simply cutting them out, claiming they weren't needed. I don't know if the owner ever discovered if he was wrong.
    19,366
    I don’t know how to post pictures here.
    Click on the picture frame with a tree on it just to the right and below where is says "Quick Reply".
    3,984
    I've never had a problem with the 796, and i like having a dedicated GPS my self.
    Tom
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    688
    Tom, what are you using for weather/adsb on the 796? What's the yearly subscription for vfr charts?
    Never had a Garmin unit
    Tom
    Meanwhile,...
    5,204
    Quote Originally Posted by john schwamm View Post
    a getting dark shot with the 796 in split screen mode with the GDL 3D talking to it via Bluetooth. 796 is surface mounted with the stock mounting bracket.
    Thanks Bearhawk Builder thanked for this post
    3,984
    Gdl-39 via Bluetooth. I have ForeFlight on my phone as-well.
    Air gizmo panel mount
    Oct 2013
    28
    Iíve been trying to figure out how to post pictures also, I have nothing on my screen that shows Quick Reply. Do I have to change my settings? Thanks for any help.
    19,366
    How are you posting? Here is the quick reply.
    And the picture frame with the tree "picture upload" icon.
    Oct 2013
    28
    I have nothing like that, Iím on the forum.
    19,366
    What browser are you using?
    Sent from my Pixel 2 XL using SuperCub.Org mobile app
    Oct 2013
    28
    Safari
    Oct 2013
    28
    Quote Originally Posted by chuckwagon View Post
    Safari
    Attachment 40023
    Likes Steve Pierce, DJ liked this post
    Oct 2013
    28
    Thanks for the help Steve, I was able to figure it out on the mobile app. Still didnít have either of two pages you posted though. Iíll have to do more looking.
    19,366
    The mobile app is different. I just have an arrow to upload but I am on an Android.
    5,129
    Assuming you're logged in, at the bottom of any thread you'll see a quick reply window, or if you select reply from a particular post you get the same window. In the quick reply window look to the top right header and select the third symbol from the far right. That'll bring up the add photo function. Select from computer or URL. From computer when you click on select files you'll get a file page to choose where the picture you want resides. Locate it, select it, and click upload files.
    1,969
    If you are going from scratch I would try to get as much digital equipment as possible. I think they are more dependable, less weight and take up less space compared the old gyro's. When you build the panel make it easy to upgrade. Switches on drop out panel for easy access. I would not mount I-pad or Garmin 796 type GPS in the panel, do a surface mount and extend it above the panel as far as possible. This will save space and easy swap out if you upgrade. I have a center drop out access plate in the middle of my panel( 795 mount attached). If I need to reach the back of anything in the panel I can stick by arm in and reach it. Use instrument nuts on all gauges. The last raffle cub was built with nylocks behind all the gauges, making it a major pain to work on. I have seen aircraft builds delayed by 8-12 weeks waiting on custom laser cut panels and power coating. Mine was built in 12 hours and rattle can paint. No right or wrong just some stuff to think about.
    Likes OLDCROWE, NorthcountryPilot liked this post
    Oct 2011
    102
    cub instrument panel
    Hey everyone, in my restoration of my cub, inexperienced as I am and perfectionist to a fault, I've realized nothing isn't tameable. So far... I'm not good with electrics. I was going to hire a guy to do my instrument panel with given avionics, instruments, etc from the underseat battery all the way up to the wiring harness for the CGR-30P up in the engine compartment.
    But now, things have slowed my progress so I'm thinking I'll have the time with the panel to do myself...What am I up against besides the tubes that you gotta build around? I'm thinking layout on cardboard template first, then clear plastic template, then the real deal...I don't know anything about laser cutting or plasma cutting or water jet?...thoughts anyone?
    CenterHillAg's Avatar
    Texas Coast
    117
    I built a couple panels in ag planes, building one in a Super Cub would be about the same Iím sure. Take your time, measure and check for fitment multiple times, and itíll turn out to be a fairly simple job. I used foam board for the template, a bandsaw for the panel shape and holesaws for the instruments, final fitment was done by hand using a belt sander and grinder mainly. Itís a lot of fun getting everything exactly where you want it, Iíd say go for it.
    19,366
    I am doing one now. I use a instrument panel punch and a Unibit. Nothing hard about cutting a simple Super Cub panel.
    Likes DENNY, AkPA/18, mike mcs repair, N929DW, tbone liked this post
    3,984
    Couldnít talk Bryan into a cgr?
    Likes tbone liked this post
  1. 185 Instument Panel Layout
    By Tanker277 in forum Cessna: C180/C182/C185
    Last Post: 05-10-2020, 08:57 PM
  2. New Panel layout comments wanted
    By MT12 in forum Member Projects in Progress
    Last Post: 05-10-2016, 06:32 AM
  3. panel layout question
    By turbofan in forum Cafe Supercub
    Last Post: 03-21-2012, 10:42 AM
  4. 12 instrument panel
    By JimC in forum Modifications
    Last Post: 11-01-2002, 01:36 PM
