Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
Thread: coyote on wing strut
    krines's Avatar
    Feb 2012
    Billings
    66
    How do you secure one so that it does not go crashing through the roof of your neighbors house. I have a long history of things flying out the back of my pickup so I am a little concerned. Tips tricks and pics appreciated.
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    849
    Might be easier if you kill it first...
    krines's Avatar
    Feb 2012
    Billings
    66
    Had a not so dead one jump out of the pickup once.
    19,821
    Cram his head between the two struts or tie to the jury struts. Seen videos and pictures but certain people here don't want other certain people getting a hold on such media.
    Likes SteveE, scout88305, 62E, OLDCROWE, FdxLou and 3 others liked this post
    May 2012
    SE Montana
    237
    Put him in a Hefty garbage bag and put him in the baggage compartment. Make sure you tie it shut tight enough so the fleas can't get out....
    Likes mike mcs repair, super stol, eviens liked this post
    krines's Avatar
    Feb 2012
    Billings
    66
    Had 2 forty pounders in hefty bags the other day which got me thinking CG with all my survival crap. If I got one more what next. Fortunately I was low on fuel so question answered. Steve do you tie neck to front jury or behind front legs to jury.
    Jan 2013
    10
    I tie on the struts when we're gonna drop them by the ground crew vehicle. The most foolproof is to tie (or zip tie) the front and back feet around the base of the struts. You can drag by the ground vehicle and let them drop.
    If it's ten below and you don't want to open door and window and lean out, than use 550 cord and tie them around the strut with a bow knot and leave one side of the tail long, loop it over the door and close the window on it. When you drag the drop spot, pull all the strings and let em drop.
    Don't try to drop them in the bed of the pickup. A 30 pound coyote can make a single cab's roof touch the seat backs.
    Apr 2015
    Platinum
    267
    There’s got’a be pictures of that!
    Sent from my iPad using Tapatalk Pro
    9,300
    Mark,
    I want to hear that story, from the owner of the pickup!
    Put dead stuff in the pod!! best way to keep plane clean.
    Toss the front legs over the front strut, loop around body behind shoulder, then tie to front strut. I like to put stuff at Jury strut to keep them from sliding up and down. Add bungie action to keep things from moving while in flight.
    Removing the stick and putting a stick box over it allows for loads to be carried forward inside. Passengers can sit on loads also- be surprised how easy it is to ride on two deer when you need to!
    Thanks Coulee Clipper thanked for this post
    krines's Avatar
    Feb 2012
    Billings
    66
    Gunner I assume the body of the dog hangs below the strut when tied around the base, is that correct? I like that better than uneven weight at the jury strut. Have you ever had zip ties break. I like the quickness of zip ties and I bet they hold tighter than 550 cord. I imagine those zip ties get brittle in the cold. Don't plan on dropping any but the idea sure sounds like fun.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,239
    This should answer questions.
    3,268
    Fleas and smashed truck cabs. I just gotta buy the beer for this!
    Likes jrussl, mike mcs repair, Wag2+2 liked this post
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,619
    Rather then Harbor Freight zip ties, a little searching can turn up some high quality ones, even in all stainless.....used in securing cabling on solar system installs.
    I'd use these, as many as needed, they can be daisy chained to get any needed length, and best of all they can easily be worked with gloves on. https://titanstraps.com/ https://www.cabletiesandmore.com/sta...cable-ties.php
    FWIW:This is how we did it back in the early '80's. Ultralights, pusher ultralights especially, make the ultimate coyote getter, slow, and capable of a lot tighter turn radius then any fixed wing light plane. The gunner/pilot pictured was a customer of mine, back when I was selling the Pterodactyl line of ultralights. He figured out real quick, being a sheep rancher like he was, this configeration worked real well. I went out with him a few times and acted as his hauler, I carried up to three at a time, lashed to the hang cage sides using my tie downs rope.
    Likes super stol liked this post
    S2D's Avatar
    Montana
    4,195
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,239
    Quote Originally Posted by Olibuilt View Post
    But it’s easier to get them to grab onto the zip tie and kill them when you get home. Or if you decide to catch and release so you can get him another day.
    Likes Ruffair, 40m liked this post
    Apr 2007
    Savannah Ga
    738
    OK I`m from Georgia and we just leave them for the buzzards to eat why yall wanna bring them back with ya. I wouldnt put my hands on one of those nasty rabies carrying flea bags
    S2D's Avatar
    Montana
    4,195
    In case we ever get to Russia, we can give her one of these !!!
    https://www.pinterest.com/Janor97/coyote-fur/
    Likes Ruffair, Gordon Misch liked this post
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    502
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    Likes Hardtailjohn, Paul Heinrich liked this post
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    354
    That's what I was wondering. I'm not a hunter, although I have a licence (requirement in my country) and a riffle. Anything I've shot in the past I've left for those more hungry.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,970
    Quote Originally Posted by Gunner View Post
    About 35 years ago, A friend and his Grandfather went bear hunting. My friend had a Nissan pickup. They got a bear treed near the access road, and Grandpa decides to back the truck under the tree and then they'll drop the bear into the truck with a rifle. Well, the bear lunged a bit upon being shot, and landed on the cab. The drop was on the order of 12 - 15' and crunched the cab pretty good. Totalled the truck.
    RVBottomly's Avatar
    Sep 2017
    830
    Quote Originally Posted by Skip View Post
    Well, in the 70s we'd get up to $40 a pelt when the fur was good.
    I never worried about fleas much because of off-splashing of the Dursban we'd use on the cows.
    Sent from my SM-J320V using SuperCub.Org mobile app
    Likes 1934A, Hardtailjohn liked this post
    May 2012
    SE Montana
    237
    The winters are long and cold up here, sometimes the women gotta make do with what they've got on hand....
    Likes Olibuilt, Skip, Southern Aero, TurboBeaver liked this post
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,239
    Ya they used to bring big bucks, still worth some today, but not near as much.......... I know these 2 hombres that had a pickup load of furs heading to NYC to cash in... On the way there the prices dropped and they barely made gas money....
    3,268
    Fur prices dropped or gas prices went up?
    krines's Avatar
    Feb 2012
    Billings
    66
    Ok guys I am starting to get some kind of picture and the one that sticks to mind is the coyote bikini. Case texted me 4 coyotes and one fox bungeed to his plane. It was informative but I thought he was bragging. Steve that pistol shot is beyond the pale. I have givin it a thought but I fly low just not that low. Heard story of a local workin the yotes with an ultra light. Bet that works well but hell I am freezing doing this can't imagine. If you want to make money at this have blankets made with the pelts. Price tag in Jackson Hole 12 grand for one with a dozen pelts. I make throw blankets for the back of the couch with 8-10 pelts which sell for 2 grand. Got a waiting list. People like fur but are afraid to wear them in public.
    Thanks Eddy Lewis thanked for this post
    Likes jrussl, RVBottomly, 46 Cub liked this post
    S2D's Avatar
    Montana
    4,195
    Quote Originally Posted by krines View Post
    Case texted me 4 coyotes and one fox bungeed to his plane. It was informative but I thought he was bragging. .
    Seriously ?? You think 4 coyotes is bragging??
    Apr 2007
    Savannah Ga
    738
    The poor thing she needs all the help she can get. If she needs a warm place to winter over I can volunteer a spare bedroom
    White City, Oregon
    920
    My grandfather back in the early 50’s after a single hunt... yes, that is a J3... zoom in to see the Yotes both on the ground and on the aircraft...
    Brian
    Oct 2016
    MT/SD
    502
    Oct 2016
    MT/SD
    502
    Pida gonna love this thread!
    2,347
    Big smart rats. Very successful and have made it to the far north in Alaska 100 years ago: http://www.adfg.alaska.gov/index.cfm?adfg=coyote.main
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,630
    Peta
    https://www.peta.org/
    Quote Originally Posted by cub special ed View Post
    pida gonna love this thread!
    19,821
    Hey Eaton, don't you have some video? Great upload for YouTube.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,239
    I have no idea what your talking about
    krines's Avatar
    Feb 2012
    Billings
    66
    I knew I could get you guys going. Son got married last summer and the head of PEDA was at the wedding on the brides side. Don't think she sensed she was standing next to a natural born killer. Wife kept giving me the look. Love to go to Yellowstone and look at wolves. Wolf lovers, you can tell them as they stand next to the road with radio collar locators and huge spotting scopes. Always stop and look through their scopes and once again I don't think they sense who they are talking to. Wife giving me the look again. I know I am socially unacceptable but I know how to behave, parents beat it into me. Neighbors daughter was a coyote biologist for awhile in Yellowstone. She knew my game. Probably liked seeing all the coyote body parts sticking out of my garbage can as did all the people who walk my neighborhood. Biologist told me that when coyotes get hunted their litter size increases which I comment " So your saying I am good for the coyote population". Now she was giving me the look.
    spinner2's Avatar
    Montana
    1,769
    Steve, you're just very good at putting things to sleep. Like coyotes and people. Come on over and put some wolves to sleep.
    3,268
    Quote Originally Posted by spinner2 View Post
    Yikes! Don't talk back to Mr Pierce!
    spinner2's Avatar
    Montana
    1,769
    Different Steve. The OP is a Steve too and is ..... well he can explain if he wants to.
    krines's Avatar
    Feb 2012
    Billings
    66
    I put people to sleep and wake them up for a living. Kind of like the pilot log book. I hope all the takeoff and landing numbers are the same.
    Likes spinner2, Steve Pierce liked this post
    krines's Avatar
    Feb 2012
    Billings
    66
    Which reminds me, my wife always stresses that it is important to have balance in ones life. After saving lives all day I find it important to take a few.
  1. Wing Strut Length
    By Jim Miller in forum Experimental Cubs
    Last Post: 10-05-2012, 09:30 AM
  2. wing strut
    By lunchmoney in forum Cafe Supercub
    Last Post: 10-25-2006, 08:15 PM
