Hi all.
I am doing some "Deep engine maintenance" on a friends experimental PA 18A 150. He is unfortunate enough to have a corroded cam that needs replacement. Engine around 500 hr s.o.h.
We will send the Engine, less cylinders, to a approved Workshop to replace the cam and cam followers.
We were thinking that now is a perfect opportunity to upgrade to 160 HP.. If it only was this easy..
We needed to replace two bad cylinders that was burned beyond repair at the exhaust port. Luckily I had two OK cylinders he could buy very cheap. The cylinders are all LW-12417 and two of them are painted blue on the cooling fins, indicating they should be nitrided, and the other two are plain grey.
Since upgrading to 160 hp, nitrided cylinders seem to be mandatory. My issue is that I cannot figure out if the LW 12417 cylinders are nitrided or not. I found some info in an old lycoming Part manual that they are plain steel cylinders, but still two of them are painted blue..
Today only the nitrided cylinder is used for 150 and 160 hp O 320 with P/N LW12416. I had a look in Lycomings part superceedure document, stating that LW12417 and LW12416 are interchangeable. For me, this means that you could install a LW 12417 cyl on a 160 HP Engine. But then I contacted a Lycoming field techrep about this to verify, and he stated that the approved cylinders are those in the Lycoming SI 1037, I.e LW 12416.
So I am still very confused, not only what is true, but also if we decide to install theese cylinders without upgrading, what Piston rings will I use? The compression rings for nitrided and plain steel cylinders are not the same..
As usual, I Believe that the best answers, and/or solutions comes from this great forum and all you knowledgeable folks![]()
