Results 1 to 13 of 13
Thread: Radio Transmission Issue
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    157
    I have a KY 97 14 volt com with a whip antenna. I can pick up transmissions loud and clear from 50 miles away. However, when I transmit it doesn’t seem to push out a strong signal. Within 5 miles it is good but 10 miles and beyond it appears to fade fast with interference that makes it difficult for ATC to pick up and understand. Any ideas on what the issue might be? Thanks in advance.
    Thanks Idleclamp thanked for this post
    2,676
    Are you sure the antenna is for VHF frequencies? Do you have a model number of the antenna or a pic? It sounds like the wrong antenna or improper installation. If the antenna is rated for VHF com freq's, pull it off and make sure you have good metal to metal contact with the panel it's mounted on (no paint) and if it's on a fabric plane make sure you have some type of ground plane under the antenna mounting location.
    Thanks Wag2+2, Bluebear thanked for this post
    Likes mike mcs repair, BC12D-4-85, C-FIJK liked this post
    Jan 2018
    17
    Not sure but battery or alternator power? Might want to see if it is charged up.
    Thanks Wag2+2 thanked for this post
    10,663
    Quote Originally Posted by PA-12 on Baumanns View Post
    on that thought...
    maybe its not able to draw the current to transmit without lag voltage drop/noise due to bad connection in rack..
    maybe pull it out of rack and re rack it....
    also try cleaning ground and power wire connection and breaker connections...
    1,851
    Is there a radio shop or installer that you can have inspect the installation? It takes experience to deal with this. Hearing is one thing and most do ok even during iffy installations unless the local radio frequency noise is high, but signal output is the elephant in the room that may need attention. Local noise (both audio like loud sounds and electrical static), microphone and its voice modulation setup, wiring both power for the radio and to the antenna, and antenna working conditions like mounting can affect output. These aircraft radios are limited on power and fabric aircraft might need a tuneup.
    2,676
    Can you give us some history of this issue? New installation or new rebuild? Ongoing problem or new problem with old installation?
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    157
    It is a rag and tube fuselage. Will sent a pic of the antenna in a couple of days when I get back to town. I noticed over the past few years since I bought the aircraft when I try to contact someone 20 miles or more away ( air to air) I don’t get a response. Seems to be ok in closer. Only recently I was advised the quality was not great but it’s probably been an issue for a while. Battery and alt seem ok as there is no problem starting the O-360 and the ammeter acts normal. I will follow-up on the suggestions and will advise.
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    157
    Attached is a pic of the antenna. Reseated the unit in the tray and went for a test flight. Response was 5 by 2 at 15 miles. Will be checking all the connection points next.
    10,663
    Quote Originally Posted by Wag2+2 View Post
    pull antenna and clean where it mounts to fairing & the ring from coax outer sheath/braid... make sure that's still connected, or i should say grounded well from the coax... sometimes it's separate screw into fairing from coax sheath
    not much of a ground plain back there for it to use either... did it work well at one time?
    2,676
    It's a good antenna (oldy but goody). But Mike's right, most likely crappy connection to ground plane. Most of those are mounted much farther forward on that faring strip, too.
    If the coax is the old black RG 58 and you're having this trouble, you might want to consider replacing the coax cable with new RG 400 and crimp on BNC connector. To attach the coax to that antenna, crimp a ring terminal onto the center conductor and fasten to the antenna stub. Attach a pigtail lead to the braided coax shield and solder the other end to the tabbed, star washer that SHOULD be between the lower insulator half and the fairing strip. If the star washer is not available, crimp a ring terminal to the pigtail and fasten it to a clean, paint free spot on the fairing, close to the antenna base.
    6,907
    Just from the photo it looks like the antenna is perched in the middle of the fuselage. Not sure - that would be a difficult mount, and if for some reason the stringer was not making good contact with fuselage steel (powder coat?) then you would have a unidimensional ground plane.
    On the other hand, I have seen antennae with no ground plane work fine - we have a rubber ducky on the windshield of a Chief, driven by a handheld, that works in the San Diego and Santa Monica environments. I did not think it would work at all.
    Likes BradleyG liked this post
    10,682
    Bob,
    It looks like it’s mounted to the right wing root fairing. Angle of the photo is a bit deceptive, methinks.
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    157
    Thanks for the feedback. Will try to work on the rest of it this weekend.
  1. Radio issue Aircraft On Ground!
    By aktango58 in forum Super Cub Sick Bay
    Last Post: 09-15-2012, 11:36 PM
  2. Radio noise, radio needed
    By teeweed in forum Cafe Supercub
    Last Post: 09-06-2005, 09:03 PM
  3. STC issue/ = $
    By T.J. in forum Modifications
    Last Post: 05-12-2003, 12:29 PM
