arcticairalaska
Fairbanks, Alaska
yep
My Dad really likes he A220 in his Clipper, has had it for several years. What are the issues?
So I guess you guys are saying replace my Icom A200 with a ky97 in instead of a Icom A220?
But the ability to monitor a frequency and talk on another is sooo tempting!
sl-40web, what would your choice be on something like a citabrias that is used to putt around. Val in it now is only working when the engine is off and he wants a new com, transponder and ads-b.
Web, what would your choice be on something like a Citabrias that is used to putt around. Val in it now is only working when the engine is off and he wants a new com, transponder and ADS-B.
I hve smallest mode S transponder in cub. Any transponder will work.
A KY 97A will generally work better than the Icoms for range and clarity. The -A200's were built as one for one replacements for the KY 97A's and sold for half the price. They work ok but just not the same level of quality. And it was a good hook that any operator could just slide it into a KY 97A tray with no other mods. So if you have an -A200 that needs replacement and cost is an issue, find a used KY 97A......
I'm not 100% certain that a King KY97 will just slide into an Icom A200 tray (or vice versa) & work ... aka "plug & play".
.... the KY 97A (not the same as a KY 97). ..........
Whats the difference?
This horse has been so long even the maggots are gonWeird response from Garmin....maybe it's a faulty design soon to be replaced. Usually peaking receiver sensitivity has to be accompanied by dealing with increased signal to noise ratio problems. A variable RF gain plus variable digital filtering can help.
Not uncommon for east asian companies to deny issues exist then offer upgraded products and save face. Question: Does disabling the intercom function have any effect on receiver performance?
Web,
I currently have an Icom A210 in my plane. Like you said, I don't much care for the "background noise" that it allows. I do like the "monitor" feature, since I only have the one com radio (and no space for another in the "stack"). Are there any other "plug-n-play" alternatives besides the KY97A?
May be a nice option to monitor two frequencies while com on one with a single unit. Like an audio panel with two rigs. Facility in one ear and CTAF or emergency in the other biased via volume. Neat.
