Results 1 to 27 of 27
Thread: cabane vee LED light
    Mar 2005
    Thompson Falls, Mt.
    79
    I see some cubs have a LED light mounted in the cabane vee. Is there a particular light that works best for that? Like maybe the Aeroled microsun or aerosun maybe? Or? I want the brightest I can find but that is still small and doesn't draw much amperage.
    2,273
    Go to a four wheel drive shop and see what's available. They'll have the brightest 12 volt lights.
    Just remember that LEDs draw less current than incandescent lamps. But when comparing LEDs to each other, less current equals less candle power. The illumination rating of each light (in candle power or lumens) will be listed in the specs for each light.
    4,306
    Single light or two? Forward recognition or light up a dark runway? Different priorities lead to different lights. Watts in equals lumens out. Spot or flood will light things differently. To some degree size matters. If you’re certificated your mechanic’s opinion about approval matters, too.
    https://www.visionxusa.com/producttype/led-lights/
    Mar 2005
    Thompson Falls, Mt.
    79
    I want strictly RECOGNITION. Maybe two so I could wig wag but as bright as I can get on a couple amps max when the light is on and if there are two then the wig wag will limit one on at a time. I only have an 8 amp alternator. I am rebuilding my wings and was going to go with landing lights in each wing, that wig waged, but that is way too heavy and more money too.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    1,974
    I installed my led light bar for landing, but it did seem to blind a few others on approach, so I guess it worked for recognition.
    2,273
    DO NOT wig wag lights mounted close together. The human eye will only see a steady light at distance. If they are mounted close together flash them on and off together and they will be effective.
    If you only want recognition, get the 'spot' types and not the 'flood' types. Will be seen at a greater distance.
    Likes Hardtailjohn, RaisedByWolves liked this post
    4,306
    I'm not sure about the floods being less effective than spots. If I'm at the power line corner heading toward Pt McKenzie and an outbound plane is at the boat hull heading toward the power line corner I want floods, and that's why I selected 40* beams. Spots wouldn't be visible from that angle. That's just an example but it applies to everywhere I fly. Long distance recognition isn't a big deal. My lights can be seen from straight ahead as well as a spot in any distance that matters. The closer-in 20-30* off center angle is the one that scares me. I watch the 206 and 185 nose lights with interest. I assume one is a landing (spot) and the other a taxi (flood) and I believe the taxi light is better at off center recognition. I can see the landing light from 10 miles away but lose it as it gets close.
    Here's an illustration. You can see both light pods in this picture and if I turned them on you'd see them flashing. I don't think you'd see a spot but maybe I'm wrong.
    Schwarz's Avatar
    Oct 2016
    Texas
    19
    I didn't mount mine on the cabane vee, I mounted these....
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    ...on the front of my steps. I have steps on both sides and wanted them far enough apart to wig wag.
    Wes Schwarz
    Likes stewartb, Farmboy, cruiser liked this post
    cruiser's Avatar
    May 2002
    South Glens Falls, NY
    1,436
    Quote Originally Posted by The Kid View Post
    I admit to being biased towards the Vision X products as I have two mounted on my cabane V. The Vision X Optimus light comes in 10, 20 or 50 degree beam spread. The 10 degree beam provides over 800’ of usable light according to Vision X. I put 20’s on my airplane. They are aluminum, not plastic, with an unbreakable polycarbonate lens. They have colored lense covers if you feel the need to do red and green during the holidays. A minor tweak to the mounting hardware and they bolt right on to the cabaneV bolts. 0.8 amp draw per light, piece of cake for a Max Pulse. They are heavy, 2 3/4 lb per light as I recall. I think there is a transformer coil in there, maybe that’s what makes them so bright. Sales pitch over. Good luck, Jim
    Likes 40m, stewartb liked this post
    9,633
    LEDs have evolved alot in the last two years. Back then a 5" one would have been only 24W and been over $100. I only use one of these.
    1,424
    This is interesting and a positive change. Back in 1987 I mounted a Warn driving light on my cabane with a bent up bracket under the strut bolt heads. You'd of thought I'd designed a Dr. Death ray the way the FAA wondered about it. I explained I wanted to see snow drifts trapping fur in winter to not break gear and didn't care about runways. They left me alone and it worked good.
    cruiser's Avatar
    May 2002
    1,436
    Fine looking light. And a great price. Got any pics of it mounted?
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    1,974
    If those pods Glenn posted are 288W each, that's very good.
    Not that it applies to cabane lights, but if you follow lightbarsupply, they have sales a few times a year and this package can be purchased for $169 as I had done. Might have watch facebook and be patient for the sales though.
    https://lightbarsupply.com/products/...-free-shipping
    The 20" bar went on the cub.
    The 4 pod lights when on my yard tractor.
    The huge 52" light bar I haven't found a use for yet.
    Of all of mine I actually feel the 20" bar is the brightest, for whatever reason, but its listed as half (126W) of what Glenn's link shows.
    pb
    9,633
    Quote Originally Posted by cruiser View Post
    I found this picture hanging around , just a alum angle bolted to the V
    Tim's Avatar
    Feb 2002
    Petersburgh, NY
    3,460
    See what i
    Mean, SJ, you jerk
    Sent from my Pixel 2 using SuperCub.Org mobile app
    Likes STaylor2, Chicken Hawk liked this post
    Scouter's Avatar
    Nov 2003
    Exeter Maine
    1,845
    Quote Originally Posted by Schwarz View Post
    Wes
    what did you use to flash the lights? A few different methods for sure, with varying degrees of cost
    im beginning to be more impressed with all the pulse and wig wag recognition, a lot of this years STOL class contest at Oshkosh showing pulse lighting.
    Jim
    Chicken Hawk's Avatar
    Feb 2015
    Southern NH & Eastern Maine
    211
    Quote Originally Posted by Scouter View Post
    Wes
    Jim
    This seems to be what lots of people are using.
    http://www.maxpulsemaxdim.com/maxpulseproduct.htm
    8,923
    Jim
    This wig-wag is what I'm using with LED lights.
    https://www.kestrobes.com/ltr-landin...ogniton-light/
    4,306
    For simple flashing guys have used automotive blinker relays for as long as I can remember. I've used an STC'd MaxPulse in my Cessna for many years, and a bootleg flasher for many years before that (until a mechanic found it and removed it ). I like the MaxPulse so well I bought another one for my experimental.
    8,923
    For simple flashing guys have used automotive blinker relays...
    I tried one of these. It didn't work with LED lights since the current draw was too low.
    4,306
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    1,974
    Just because I my post earlier referred to waiting for a sale, the light bars I used are now on sale for $159. So, if your tractor needs lights.... these work.
    https://lightbarsupply.com/products/...gVQChZIFJyNAU0
    edit - most probably don't need the 52", so this is a better deal at $89.
    https://lightbarsupply.com/collectio...ottom-bundle-1
    I have no connection with this company, they are probably chinese made, and YMMV.
    2,273
    You used an old style flasher for incandescent lights. Find a flasher from a newer car that uses LED blinkers. Will work just fine.
    aktango58's Avatar
    18AA
    9,000
    Peter,
    That 52" bar would fit perfect on my loader for plowing!
    The only issue with LED is that they do not generate the heat to clear snow or ice off of them.
    These are safety items. If you have to, take them off before you let your mechanic get near the plane. It only takes a few minutes to unbolt and unplug.
    Flashing lights make you much more visible, worth the weight and expense every time.
    Likes Farmboy liked this post
    krines's Avatar
    Feb 2012
    Billings
    51
    IMG_0739.JPG Aeroled Sunspot36LX Landing Light installed by Aerotronics Billings. FSDO stated no 337 necessary. When landing it is aimed down toward the runway as the tail come down it points out like a taxi light. Once you put the big tires on who cares about drag.
    Mar 2005
    Thompson Falls, Mt.
    79
    Did Aerotronics furnish all the "bracketry" to mount it like that? Will the Mx Pulse work with it to flash it on and off or to have it on steady? That's really a nice looking installation.
    krines's Avatar
    Feb 2012
    Billings
    51
    All the brackets where supplied by Aerotronics however I think this is very much a do it yourself deal. The light housing I believe you can get from aeroled or some other supplier like spruce. It then is simply a piece of angled alluminum clamped to the V. Mine is on steady but I guess you could pulse if you want.
  1. Landing light on Cabane V
    By Luke_theDrifter in forum Super Cub Sick Bay
    Last Post: 07-10-2006, 06:49 AM
  2. cabane vee on the 12
    By fatcub in forum Tips and Tricks
    Last Post: 12-15-2002, 05:31 PM
