Results 1 to 40 of 42
Thread: Stabilizer/Elevator rigging
    giangab's Avatar
    Jan 2017
    72
    Hello friends.
    The restoration of my PA18-95 is short from being completed.
    I need help again.
    I could not find the rigging instructions relevant to the cable/spring connecting the elevator upper horn to the stabilizer joke.
    The spring pulls the elevator up, more when the trim is full nose down, and less when the trim is full nose up.
    I understand this device is for two purposes:
    1. Center the joke in level flight with trim somewhat neutral
    2. Allow controlling the elevator in case of elevator control cable failure
    Thanks for helping.
    Ciao
    Gian
    Likes barrow pilot liked this post
    6,877
    I know absolutely nothing about that, except if it was mine I would figure out a way to get that spring to mess with my elevators less. I was told its only purpose was to certify the aircraft in a hands-off terminal velocity dive. I occasionally fly a Cub with a really loose spring, and it is a delight! I don't have to trim in the pattern.
    9,910
    I fly one without a spring and trim 11 turns ( double pully , no flaps ) between cruise and landing. I'm hoping a spring will help me to trim less, like my Pa11 was.
    Most guys who cut there teeth on a J3 don't like the spring
    10,597
    that cable and spring were only relevant to the plane as it weighed when it left the factory.... you can play with cable length and spring size to get the personality of your plane to be nice... heavy cubs just remove it....
    giangab's Avatar
    Jan 2017
    72
    Hi all, thanks for taking your time and replying to my question.
    So for it is understood, but I nelieve there should be a “basic” or standard calibration of the spring,or possibly a range.
    Surely the cable-spring device should never be loose and be in tension along the full trim excursuon.
    Inviato dal mio iPhone utilizzando SuperCub.Org
    Thanks cubnut thanked for this post
    19,000
    The cable length and spring tension need no adjusting. Install it and go. There is nothing to adjust. It is there to meet the pitch stability tests for certification. Yes it gets loose and tight depending on the trim setting.
    giangab's Avatar
    Jan 2017
    72
    Thanks.
    I have installed the one that was on the plane before restoration, but it appears (to me) to be very tight, I mean with trim neutral on the ground the stabilizer stays up some 10 degrees and the stick is quite hard to push forward. Possibly someone has changed the original spring with a tough one.
    Any suggestion to check this to reflect the design - factory condition?
    Thanks.
    19,000
    Can you post a picture?
    Likes cubnut liked this post
    giangab's Avatar
    Jan 2017
    72
ID:	39685Click image for larger version.
    19,000
    Do you have a picture of the cable and spring?
    giangab's Avatar
    Jan 2017
    72
ID:	39687Click image for larger version.
ID:	39688Click image for larger version.
ID:	39689Click image for larger version.
ID:	39690Click image for larger version.
    giangab's Avatar
    Jan 2017
    72
    This is the device
    giangab's Avatar
    Jan 2017
    72
    giangab's Avatar
    Jan 2017
    72
    Ful down trim
    giangab's Avatar
    Jan 2017
    72
    9,910
    Pretty sure there are 2 different springs. One for Pa11 and Pa18-95 and one for Lyc powered 18s?
    giangab's Avatar
    Jan 2017
    72
    Full up trim
    giangab's Avatar
    Jan 2017
    72
    Then ther should be a specification for each of them: anyone knows?
    Grazie
    9,910
    Quote Originally Posted by giangab View Post
    Grazie
    Both listed in Univair
    Jun 2006
    Anchorage, Alaska
    16
    The spring is part number 10940-02 and the cable number is 40123-78. The cable is 21 3/4 inches in length from end to end.
    19,000
    That is a home made cable. My parts catalog calls out calls out 40123-66 for the "95".
    Attached Files Attached Files
    10,597
    that's not readable, maybe SJ can upload it without it degrading it??
    nd
    3,362
    40123-78 is for the lycomings. spring used is the same for all.
    nd
    3,362
    Feb 2004
    northeast Texas
    54
    Your jack screw yoke is mounted upside down from the one in your picture. Might make a difference in spring tension at up or down trim if spring cable is not in center of yoke travel.
    Feb 2004
    northeast Texas
    54
    Sorry looking at it wrong, it is the same as the picture
    giangab's Avatar
    Jan 2017
    72
    Thanks to all. I have checked the drawing suggested by Steve 40123/66 and Cubdriver2 40123/78, but I can't figure the discussed "elevator spring for PA18/95".
    Thanks for furthwer help (I am ready for test flying and wish "no problems".
    Thanks again, Gian
    Thanks flynlow thanked for this post
    Sep 2006
    Maynard,MA
    1,228
    Spring takes the pressure off the stick as you add nose up trim.Made my cub much nicer to fly when slow.
    giangab's Avatar
    Jan 2017
    72
    The function of the spring (also called bungee) is clear.
    I also understand that pilots have differen “tastes” regarding the strength of the spring: in this respect I would be pleased to know what would be the strength or force to pull the originally designed spring.
    I cannot find such info in the mentioned drawing.
    Thanks again.
    19,000
    Why not just purchase the spring from Univair and that way you know you will have the correct tension and length?
    giangab's Avatar
    Jan 2017
    72
    Steve, you are right!
    univair has two elevator bungee/springs: which one is the rifht one?
    U10940-002 UNIVAIR BUNGEE SPRING - FITS PIPE
    or
    U81411-002 UNIVAIR BUNGEE CONTROL CABLE SPRING - FITS PIPER
    Similar but different.
    19,000
    I don't have the parts manual in front of me but item 30.
    9,910
    Picture of spring on my old Pa11
    nd
    3,362
    or
    10940-002 is the top spring. 81411-002 is the trim cable idler pulley spring.
    giangab's Avatar
    Jan 2017
    72
    Thanks for the clarification
    giangab's Avatar
    Jan 2017
    72
    I have checked my spring and found that with trim netral would keep the elevator up about 10 deg and the stick was very heavy to move forward. With trim full up the spring was loose.
    I measured the spring to be 2.1 mm wire and 1/2” coil and abot six inch long. Surely too heavy. The univair spring is about 1.3 mm wire and 1/2” coil and about the same length.
    I have changed to a light spring 1.2 mm wire 1/2” coil and avout 5 “ long to keep the cable straight when full trim up: the stick is light and the elevator drops slightly when trim is neutral: this appears to be the condition recommended by most of you. I will follow comments when I will test fly. Click image for larger version.
    giangab's Avatar
    Jan 2017
    72
    The “elevator sprng” thread discussion was very useful. Thanks to all.
    Jul 2019
    O’Fallon, MO
    23
    I just went through this issue with my super cub, had to muscle stick for pitch and it took a lot of trimming after flap inputs. Turns out the bungee cable was twisted and kinked, causing it to be too short with constant tension on cable; this same condition is caused by too short of a cable.
    3,429
    I'm going through this exercise for the EAB-12 I'm working on.
    The spring callout in my PA-12 parts book is 81411-00. The Univair catalog says their U81411-002 supersedes the -00 part number. Says it is for J-5, PA-12, PA-18, PA-20 and PA-22 https://www.univair.com/piper/piper-...-cable-spring/
    It's unclear what length cable to use for connecting the trim yoke to the spring. The PA-12 length is 20 5/16", and the PA-18 length is shown as 21 1/4". I assume the longer length is due to balanced elevators. In our build we are using extended chord elevators, which would suggest the shorter (20 5/16") length.
    PA-12 https://www.univair.com/piper/piper-...-bungee-cable/
    PA-18 https://www.univair.com/piper/parts/...-bungee-cable/
    I'd sure appreciate any applicable thoughts? Thanks.
    May 2017
    535
    Umm, I think that’s why they call it EXPERIMENTAL. I suspect that during your Phase 1 testing you may end up making several in different lengths and pick the one that works best through your entire flight envelope. There is a reason for that Phase 1 testing.
    Likes Gordon Misch liked this post
  1. FS Stabilizer 40643, Elevator 40572, Upper & Lower Wire Assemblys
    By davidv.lewis in forum Parts and Pieces
    Last Post: 02-15-2019, 10:37 PM
  2. Replies: 1
    Last Post: 06-20-2017, 12:30 AM
  3. For Sale- Airframes Inc Elevator, Stabilizer & Rudder Ri
    By RYAN_WINGS in forum Cafe Supercub
    Last Post: 09-28-2005, 10:25 AM
