wireweinie
FOUNDER
I guess I am not understanding on how to install that
This is out of section four of the instructions. Just don't connect the caution/warning lights.
I got that but was not wanting to use a dimmer pot is there a other way to install it
You have to use the EI dimmer it doesn’t work the same as standard dimmers. If I’m remembering correctly. It’s been Awhile. I don’t think there is any internal way to dim the unit.
Been there done that to the point of being ready to rip it out and send it back... their belief (the tech actually said this to me) is you need full bright at night because it's dark so I asked if he had ever flown at night... Even with their dimmer it has a very narrow range.The CGR has dimming programming instructions in section seven of the operations manual.
Calm down. They give you an option now of how you want it programmed. I ordered mine and the last one I installed with a photo eye so it automatically adjusts the backlighting and you can custom program the intensity in both parameters.Been there done that to the point of being ready to rip it out and send it back... their belief (the tech actually said this to me) is you need full bright at night because it's dark so I asked if he had ever flown at night... Even with their dimmer it has a very narrow range.
Kurt, how long ago was that? I haven't run into that issue but good to know.Guys,
I have a suggestion I have that help you avoid trouble and frustration in the future with your EI unit. Take a few minutes and with a magnifying glass or what ever tool necessary check the connectors, pins and harness’s on new EI products (and anyone else’s for that matter). I spent thousands tracking down faulty crimps and poorly seated pins that were in the plug. Removal of the components from the airplane of what you can and further trouble shooting under the panel not being able to readily reach stuff is very difficult. Better to check this stuff on the bench. I love their products but their QC on my unit and some units of others I know have been a bit lacking. This is simple stuff and with a bit more attention detail it could have easily been prevented.
Just a heads up.
Kurt
Well good but I'm still PO'd at the way I was treated and what we had to go thru but glad they have seen the light, I mean the dark...Calm down. They give you an option now of how you want it programmed. I ordered mine and the last one I installed with a photo eye so it automatically adjusts the backlighting and you can custom program the intensity in both parameters.
I normally don't fly at night but did have to run out and help a buddy with a moose. We came home in the dark and being able to dim the EI gauges really helped. I have individual gauges in the cub if I had the all in one I would add the warning light I tend to look outside a lot and having something to catch my eye like that is helpful.
A couple of months ago when we were doing the repairs on a unit that was installed new in 2012. The poorly crimped and poor QC on the pins and harness was astounding! My mechanic said mine wasn't the first he has seen, he has seen this on a lot of their stuff over the years. I do like the unit, I wish they had built my harness properly. Make sure you spend a few minutes going over the harness while its easy to do on the bench.
Kurt
There are going to be issues from time to time, but I'm not buying the 'over the years' line. I've installed more than most over the last couple of decades and I have my issues with their harnesses. Namely the crappy insulation on the individual wires. Melts at low temps and smokes when stripped with a hot blade. But I have NEVER had an incorrectly wired harness from them and never had a failed crimp on a wire. I'd like to hear what the exact problem was with your harness and how the mechanic determined that there was poor QC on the pins/harness. Keep in mind that the CGR-30P wiring diagram is the kind that shows all possible connections and not just the ones used for that particular aircraft. It's easy to get confused.
Did he show you the problems with the harness? Do you have pics of the specific issues? When I work with the number of their harnesses with minimal issues and then hear 'they suck', I need to see some evidence in order to change my mind.
That's why I like a direct reading oil pressure gauge. All of the others, you can do without.What are the odds of having the whole screen go black and losing all your engine indications? Seems like all our eggs are in one basket.
George
Nice, is it certified down to CAT lll or just CATll? :smile:I love all of the electronics but I also like the idea of a direct wet oil pressure. View attachment 53046
