Results 1 to 11 of 11
Thread: PA-18 parts inventory for sale.
    Dec 2009
    Teuge, EHTE, The Netherlands
    47
    Hi all,
    Somehow I accidently deleted my last post again......................................
    Anyhow, this is what is left of the PA-18 inventory. I want to sell it soon in one piece, so make an offer (PM me) for it approx. 2 crates. Shipping from the Netherlands. Almost all is NOS. Goes to the highest bidder
    64020 Piper Fitting 10
    10112-07 Drag Strut N Brace Tube 3 U10112-007
    10161-05 Fitting 15 U10161-005
    10401-00 Piper Front Spar Butt Hinge Fitting 105 U0401-000
    10630-009 RH Leading Edge Skin 27 U10630-009
    10630-011 LH leading Edge Skin 1 Super Cub
    10631-00 LH Leading Edge Cover 1 U10630-000 Position 2
    10634-05 Rib 0 U1215-01
    10634-07 RH Butt Rib 0 U1215-02 Super Cub
    10634-07 RH Butt Rib 0 U1215-02 90 HP Cub
    10635-03 Tank Bay Rib 0 U1224-00 10635-00
    10653-02 Rib 0 U1213-00
    10703-00 Aileron Hinge Bracket 61 U10703-000 New
    10703-00 Aileron Hinge Bracket 57 U10703-000 Used
    10703-03 Flap And Aileron Hinge Bracket 58 U10703-003
    10703-04 Flap Outboard Hinge Bracket 47 U10703-004
    10734-00 LH Brake Pedal Front 6 U10734-000
    10734-01 RH Brake Pedal Front 5 U10734-001
    10808-03 Top Cowl 2 U10808-003
    10865-005 Rudder Control Cable 1 U10865-005
    10921-00 Bearing Block 25 U10921-000 Bewaren
    11670-02 LH False Spar 9 U11670-002 Position 2
    11682-00 Inboard Flap Hinge 3 U11682-000
    12184-02 Landing Gear & Lift Strut Fitting 2 U12184-002
    12184-03 Landing Gear & Lift Strut Fitting 1 U12184-003
    12241-00 Cable Guard Bracket 7 U12241-000
    12252-08 #2 Wing Channel Brace 10 U12252-008
    12257-01 Piper Lower Door Frame 1 R12257-001
    12258-01 Trim Strip 7 U12258-001
    12274-00 LH Bottom Front Wing Root Fairing 2 U12274-000
    12276-00 Wing Root Fairing Assy 9 U12276-000
    12309-00 Throttle Control Panel 1 U12309-000RD
    12315-00 Cabin Heat Box 0 12315-000
    12407-00 Clamp 2 U12407-000
    12581-00 Piper Jury Strut Fitting 86 U12581-000
    12662-04 Nose Rib 0 U1200-02 U1200-05 &U1200-08
    12707-00 Cowl Fastener Cub 10 108-6021401-36
    12767-00 LH Front Wing Attach Fitting 2 U12767-000
    12767-01 RH Front Wing Attach Fitting 2 U12767-001
    12845-00 Upper Shock Strut Fitting 1 U12845-000
    12847-00 Door Latch Bracket 1 U12847-000
    12875-000 Lower Shock Strut Fitting 3 U12875-000
    12902-01 RH Full Rib 0 U1206-01
    12982-00 Adjust Screw Pulley 6 U12982-000
    13052-07 Rib 0 U1212-00
    13052-10 LH 3/4 Rib 0 U1211-00
    13072-05 Outboard Leading Edge Skin 45 U13072-005 Position 3
    13733-03 Rear Control Stick Lower Stub 4 U13733-003 Only lower stub
    14161-00 Piper Rear Spar Butt Hinge Fitting 59 U14161-000
    14177-00 Bushing 11 U14177-000
    14222-00 Drag Strut 5 U14222-000
    14222-02 Drag Strut 11 U14222-002
    14271-00 Piper Filler Block 14 U14271-000
    14385-00 LH False Spar 2 U14385-000 Position 1
    14385-01 RH False Spar 12 U14385-001
    14461-00 Piper Filler Block 6 U14461-000
    14541-00 False Spar Brace 30 U14541-000
    16462-000 Upper N Brace Tube 1 U16462-000
    16551-00 Tip Bow Fitting 12 U16551-00
    16611-00 Tip Bow Fitting 26 U16611-000
    18875-07 Control Knob 3 U10911-000
    21161-00 Stabiliser Support Assy 1 U21161-000
    21272-02 Landing Gear Front Fitting 8 U21272-002
    21642-03 Fitting Assembly 1 U21642-003
    24121-002 Brake Pedal Fitting 14 U24121-002
    31702-00 Steel Cub Hub Cap 3 U31702-000
    40081-00 Fair Lead Snap Ring 13 U40081-000
    40092-09 Piper Flap Bellcranck - Right 20 U40092-09
    40092-10 Piper Flap Bellcranck - Left 24 U40092-10
    40223-000 Torque Tube 2
    40572-00 Piper Elevator Assembly J-3 2 U40572-000
    40621-00 Control Stick Connector 4 U40621-0
    41051-000 Brass Tie Rod Nipple 9 U41051-000
    41291-000 Pulley Housing 2 U41291-000
    41491-00 Throttle Arm 2 U41491-000
    41881-00 Aileron Hinge 7 U41881-000
    41891-000 Aileron Center Hinge 2 U41891-000
    42792-00 Front Control Stick Lower Stub 3 U42792-000
    451-771 Goodrich Brake Bleeder Tee Fitting 9 B57-239
    750-028 Goodrich Side Rim 4 B11-5
    750-752 Tailwheel Hub 12 U1967A-000
    750-998 RH Brake Pedal Aft 8 U1715A
    750-999 LH Brake Pedal Aft 7 U1715A
    751-376 Piper Firewall Frame Bulkhead 1 U751-376
    752-494 Nut 33 752-494
    80222-03 Clamp 43 U80222-003
    81352-011 Aileron Cable Link 13 U81352-011
    May 2003
    Ambajejus Lake, Maine
    27
    If you still have all of this are you considering selling individual parts yet?
    Dec 2009
    47
    Yes, this is possible for sure, already used many parts for my own SC's
    May 2003
    27
    Parts
    [QUOTE=bertievdbunte;751970]Yes, this is possible for sure, already used many parts for my own SC's
    I am interested in part# 13733-03 and 42792-00 if you still have them.
    Mar 2014
    Lake Metigoshe, ND
    56
    Lower tail wires
    I didn't see any listed, but doesn't hurt to ask. I'm looking for the lower horizontal stabilizer tail wires
    [/QUOTE]
    May 2003
    27
    I see both the front and rear control stick lower stubs
    are still available. How much are you asking for these 2 items?
    Dec 2009
    47
    I will send you a PM
    Quote Originally Posted by Trimcable View Post
    evroosevelt's Avatar
    Dec 2009
    Wilsonville, AL
    149
    How much for the 2 of the U21272-002 Landing gear front fittings?
    EV
    nd
    3,305
    still selling some of these parts?
    Dec 2009
    47
    Yes!
    Feb 2011
    S.E. MO.
    5
    I would be interested in the Rudder cable ( 10865-005 ) and 8 of the Brass tie rod nipples ( U41051-000 ) thanks , Randy.
    Thanks bertievdbunte thanked for this post
